Need help w/ Calendar Events not appearing in Outlook 2010
MSM100
I have a Windows PC using XP SP3, Outlook 2010 and an iPhone 4G. I used to sync my PC and iPhone using Apple's Mobileme but I turned off Mobileme recently and now just sync my Outlook calendar and contacts from my PC to my iPhone using a wired sync via iTunes. Since I turned off Mobileme and completed the first wired sync earlier this week I have had some problems with Outlook on my PC. After the first wired sync was performed all Calendar and Contact data on my iPhone are appearing correctly. However, my problems in Outlook on my PC started last night, I had to use the Microsoft Outlook repair tool to fix my Outlook .PST file because Outlook would not open (I fixed that problem) and today no events are showing up in my Outlook 2010 calendar on my PC although the Reminders feature of Outlook is telling me that I have upcoming appointments but nothing shows up in my Outlook Calendar. I can"t even get the standard Outlook calendar to show up. All of my Contacts in Outlook on my PC are appearing correctly. Also, in the Calendar pane in Outlook 2010 in the bottom left corner it shows that there are several thousand events in the Calendar so it seems to me that the data in my Outlook Calendar is there but it is just not being displayed. I have looked at my settings and it doesn"t seem like anything is wrong but I must be missing something. Not sure where I start to fix this problem.
What do I need to do to get the Events to appear again in my Outlook 2010 Calendar on my PC? Thanks in advance for any guidance
Jahawk
Likely the issue you are having is due to the iTunes COM Add-in that is loading with Outlook 2010.
This iTunes COM Add-in works off of your Calendar.
First thing I would do is to turn it off (disable it).
Then see if the contents of your Calendar comes back.
From Outlook 2010:
Click File | Options | Add-ins
Click the Go button to the right of "COM Add-ins"
Uncheck the iTunes Helper entry and click OK
Shutdown and restart Outlook 2010.
Is your standard Calendar opening up? Is everything present?
If it's empty, right-click on the Calendar folder and click Properties. Click Folder Size.
Is there any data in the folder?
If the data has been wiped, will you be able to sync it to your iPhone to recover your Calendar's contents? Any backups of your PST?
If the folder has size, but nothing shows in the Calendar view. Click on the Calendar | Click View | Change View | By Category
Do you see items present when in the By Category view? If you do, then the items have been modified\damaged in some way so that it is not possible to display the Appointments in a Day\Week\Month view.
Also, there's an issue with iTunes COM Add-in that is represented by a longer than normal time for Outlook 2010 to shutdown all the way. That may be what hosed your PST file (file wasn't shutdown properly). Anyways, there will be a fix for that particular issue with Office\Outlook 2010's SP1. -Sorry, no timeframe I can give as to when SP1 will drop.
Lastly, I would strongly suggest you check to make sure you are running the latest firmware and software for your iPhone and Apple's Mobileme. Also check their site to see if this or any other issue you've experienced has been reported by anyone else.
I hope that helps!
Jahawk MSFT
L Need help getting calendar/contacts/tasks/notes back! Using Outlook 3
G Need help configuring a PRF for Outlook 2010 and 2013 Using Outlook 0
K Excel Import Option: Need Help Updating Existing Records BCM (Business Contact Manager) 0
K Need help concerning emails linking to BCM. BCM (Business Contact Manager) 0
J Need help with installation of BCM in Outlook2013 BCM (Business Contact Manager) 5
F Outlook 2010 - Need help with a custom field. Using Outlook 3
P Need help/Gmail accounts show separately/Outlook 2013 Using Outlook 0
J Need Help Extracting Email Content into Excel Specifically the Attachment Name Using Outlook 3
A Need Help with BCM2010 Sharing on outlook 2013 Scenario! BCM (Business Contact Manager) 1
W I Need help with vb.net and outlook 2010 Using Outlook 2
A My move to MS is not going too well: Need Help !!! Using Outlook 14
M Need help with combo boxes in messages! Using Outlook 10
D Need help understanding which pst-file to use! Using Outlook 0
U Need a help please Outlook 2007 crashing Using Outlook 2
Z Need Help Outlook 2007 inbox and address book view Using Outlook 2
B Need help adding a background color to the compact list items in Month view. Calendar Printing Assistant 1
B Need help adding an image next to the Month Name in the header. Calendar Printing Assistant 1
B Ok - a complicated one - but really need help (auto formatting) Using Outlook 9
B OUTLOOK 2000, Need Help ! Outlook Wishlist 1
P To Use BCM or not...I need help BCM (Business Contact Manager) 1
T Need help making RULE to prepend email SUBJECT Using Outlook 3
V Need help on configuring Outook 2003 Rules and Alerts... Using Outlook 2
A Need Help Urgent !!!- Add Seconde Node To The DAG Exchange Server Administration 12
D Need help bulk exporting mailboxes Exchange Server Administration 3
N Need Help with Outlook 2010 Using Outlook 1
G Need help in merging data from multiple .pst data files into one .pst file. Using Outlook 3
F Incoming email titles - i need them back (please help...) Using Outlook 2
B Need help with contact recovery, since trial of Office 2010 has ended. Using Outlook 2
M Need Help on Designing Exchange 2010 Email Solution for 4000 Users Exchange Server Administration 1
S OL2007/XP views will not retain settings. Really need some help here. Using Outlook 2
D Need help repairing Outlook 2010. Using Outlook 2
D Need help with word wrap in Outlook 2010. Using Outlook 5
L Windows Instant Search Indexing not working need help reading Event Log Using Outlook 2
N need help retrieving email from previous Outlook Profile Using Outlook 7
