Outlook 2010 does not save "sent" messages
trekman rml
Newly installed Outlook 2010 sends and receives mail OK, but does not save a copy of sent messages. I checked all " sent" folders and came up empty. However, a search of all email did show specific sent messages in a sent folder. Somehow I cannot see these messages in any regular folder view.
Outlook is configured in options to save sent messages.
I
Ivanmor
Hey Trekman!
If you close outlook, the from the Run option the start menu, relaunch outlook with the /clearviews switch
outlook.exe /cleanviews this should restore you messages!
cheers,
-ivanmor
O Outlook 2010 does not open MS Word attachments Using Outlook 1
H Reocurring outlook appointment (office 2010) does not update Outlook.com Using Outlook 3
F Outlook 2010 contact e-mail Display as: does not show contact name Using Outlook 2
P Reply All does not work in Outlook 2010 Cached mode Using Outlook 4
E Does Outlook 2010 support searching multiple .pst files simultaneously? Using Outlook 0
D Outlook 2010 randomly does not receive emails Using Outlook 3
D Does anyone understand Outlook 2010??? Using Outlook 1
C Outlook 2010 - Your network adapter does not have a default gateway. Using Outlook 1
S Outlook 2010 Journal does not record activities on Office 2007 files Using Outlook 1
J Suggested times does not work with Outlook 2010 in combination with Exchange 2007 SP2? Using Outlook 2
B outlook 2010 Search does not show recent messages Using Outlook 4
C Outlook 2010 does not Clean Messages from Server Using Outlook 1
M iPad does not Sync with Microsoft Outlook 2010 Contacts, Calendar, Etc. Using Outlook 2
J __This is on outlook 2010...I can receive but does not send out.__ Using Outlook 2
C Managed Folder does not show up in Outlook in Exchange 2010 Sp1 Rollup 1 Exchange Server Administration 3
D Win7 x64 - Outlook 2010Beta x64 - BCM 2010 x64 does not install BCM (Business Contact Manager) 1
