Outlook 2010 with BCM - Database Connection problems using Windows 7 Clients
C
Cookie02392
We have deployed Outlook 2010 Standard with BCM on 1x Windows 7 Pro box to act as an interim server until we migrate to exchange
2x Vista clients that have been upgraded from office 2007 to office 2010 with bcm can access the shared sql database on the Windows 7 pro box no problem using office LAN.
My own Laptop has had a fresh install of Windows 7/Outlook 2010 with BCM, but cannot connect to the shared sql server via the same LAN.
I can ping the server, browse the shares, even see the MSSMLBIZ share created by BCM.
Message : The computer xxx-Server does not contain and shared Business Contact Manager databases, Please confirm that a shared Buisiness Contact Manager database is stored on the computer.
I have checked the ports are open on 5356, and even disabled wirewalls etc..
Users (using Workgroups) have been replicated from the client machines onto the Windows 7 box acting as a server. permissions have been changed to Administrator after creation of user/temp password in BCM.
I'm now at a loss, as there is limited info on BCM 2010 networking issues.
Any help for a slightly techie appreciated....
Forum Admin BCM Update for Outlook 2010/2013 - Nov 2014 BCM (Business Contact Manager) 14
R BCM is almost at capacity Outlook 2010 BCM (Business Contact Manager) 2
D [SOLVED] Optimizing Outlook 2010 BCM BCM (Business Contact Manager) 2
I Outlook 2010 BCM Mass E-mail feature insists on converting outbound HTML emails to plain text Using Outlook 2
N Receive "Requested Operation Failed" Dialog when trying to add BCM Database in Outlook 2010 Using Outlook 2
B Outlook with BCM 2010 and Windows Mobile will not sync contacts separately Using Outlook 1
J outlook and BCM 2010 have Hyper links fileds Using Outlook 3
M Does a shared Outlook BCM 2007 database work with both Outlook BCM 2007 and 2010 clients? Using Outlook 2
V Outlook 2010 BCM no longer working after several months of successful use. Using Outlook 11
D Moving from Business Contact Manager for Outlook 2007 to BCM 2010 Using Outlook 1
T Import Outlook 2003 .bcm file into Office 2010 Bus. Cont. Mgr. Error: "Input string was not in a cor Using Outlook 6
J Outlook 2010 BCM error message: "The set of folders cannot be opened Store not configured" Using Outlook 7
A Using BCM 2010 mass email - how do you control which outlook email account does the sending? Using Outlook 6
M BCM for Outlook 2010 now on Technet BCM (Business Contact Manager) 2
L Cannot install BCM 2010-"Outlook 2010 Not Installed" but it is! BCM (Business Contact Manager) 1
C BCM for RTM Release of Outlook 2010 BCM (Business Contact Manager) 3
D Win7 x64 - Outlook 2010Beta x64 - BCM 2010 x64 does not install BCM (Business Contact Manager) 1
K Outlook BCM 2010 and Accounting Professional 2009 BCM (Business Contact Manager) 1
