Autodiscover two AD sites two cas arrays
skipster
how would i configure autodiscover in DNS for a DAG that was ACtive\ACtive meaning live mailboxes in each datacenter? i would want users who have mailboxes in ADsiteA to be pointed to the casarrayA that lives in ADsiteA for autodiscover, and for users who have mailboxes in ADsiteB i want them pointed to cassarraB that lives in ADsiteB. If my internal domain name is mydomain.com, and i have a DNS zone called "mydomain.com" and i create an A record called autodiscover.mydomain.com then what casarray would i point this ip address to?Bulls on Parade
Sembee [MVP]
The autodiscover URL is only used by external clients, or clients that are not members of the domain.
Internal clients that are members of the domain get their information from the domain, not from the autodiscover URL.
However you can point autodiscover at any CAS Exchange server, because the amount of data it transfers is tiny, a few kb, as it is just XML configuration information.
Simon.
Simon Butler, Exchange MVP
Blog | Exchange Resources
skipster
I understand that the *URL*is only used for external cleints, however internal clients will query AD for this record (as you mentioned) but the record for autodiscover service in AD is a url. So knowing this if the autodiscover url or scp (serivce connection point ) was mail.mydomain.com/autodiscover/autodiscover.xml then i would need to point this record to my NLB cas array. I agree that the traffic is tiny, so it doesnt matter to much what NLB cas servers i point the record to. However if a user connects to the nlb cas array for autodiscover in AD siteA but there mailbox is located in AD siteB would the nlb cas servers in AD site A proxy the request to the NLB cas servers in AD siteB?
Thanks again
Bulls on Parade
Sembee [MVP]
I don't believe that autodiscover is proxied, because the data is being pulled off the domain.
All autodiscover is doing is telling the Outlook client where to look. Given the traffic is so small, there is little point in proxying it - it would save a couple of kb at most.
Simon.
Allen Song
First, Outlook will query the AD to get all available SCP objects, then sorts the SCP record into In-site, Out-of site based on the Outlook physical location. Then it will use the autodiscover of that site to get the relevant configuration directly.
For example, TestA is the mailbox of the Site B, log on the Outlook in Site A. It will use the autodiscover of the Site A to get the basic information and relevant services URL from the AD directly. But for the Free/Busy and OOF, it will proxy the request from the Site A to Site B.
Allen
Allen Song
B AutoDiscover Forensics Exchange Server Administration 0
EXChange2013 Exchange 2013 AutoDiscover Tweaks? Exchange Server Administration 0
M Outlook 2007 AutoDiscover Using Outlook 0
A Exchange Autodiscover SSL issue Exchange Server Administration 7
M Initial Outlook Configuration with AutoDiscover populates wrong email address Using Outlook 5
N Outlook 2007 Clients Pointed to Wrong Domain Name for Autodiscover Using Outlook 2
K testing autodiscover and exchange coexistence Exchange Server Administration 2
C The Autodiscover service couldn't be located. Exchange Server Administration 8
C Exchange server 2010 error "The Autodiscover service couldn't be located." Exchange Server Administration 1
J Autodiscover accounts on exchange 2003 with Outloook 2010 not working Using Outlook 4
Z Autodiscover Points to defunct Exchange 2010 Server Exchange Server Administration 5
M Autodiscover not configuring Outlook Anywhere Using Outlook 10
B Autodiscover error 0x800c8203 and encrypted connection is not available Exchange Server Administration 3
P Autodiscover URLs Exchange Server Administration 15
C Autodiscover Exchange Server Administration 6
I Exchange 2010 Profile AutoDiscover not working for some users Exchange Server Administration 1
S Exhcange 2010 autodiscover virtual directory Exchange Server Administration 4
D External Autodiscover Exchange Server Administration 3
S Exchange 2010 Autodiscover Problems, cannot connect Outlook clients using Autodiscover / Outlook Any Exchange Server Administration 4
G Exchange 2010/Outlook 2007 Can't get autodiscover to work for some users, but others work fine Exchange Server Administration 3
S Autodiscover issue Exchange 2007 Using Outlook 4
P Autodiscover will not work Exchange Server Administration 13
K Exchange 2010 Autodiscover Exchange Server Administration 1
P Autodiscover fails (Exchange 2010) Exchange Server Administration 7
P Autodiscover issues on Exchange 2010 Exchange Server Administration 7
S Exchange 2010 Outlook 2010 Autodiscover fails Exchange Server Administration 22
C Getting Autodiscover to work with other web servers ... Using Outlook 4
C Autodiscover Service Configuration Exchange Server Administration 5
B move mailbox- autodiscover Exchange Server Administration 25
T Autodiscover authentication Exchange Server Administration 2
A autodiscover issue with OL2010 but no issue with OL2007 Exchange Server Administration 10
K Autodiscover and SRV records Using Outlook 10
S Autodiscover redirected Using Outlook 2
C Autodiscover Exchange Server Administration 5
O Autodiscover Exchange Server Administration 4
S Autodiscover FQDN certificate for secondary domain email? Exchange Server Administration 1
K Remove AlternativeMailbox - Autodiscover Exchange Server Administration 5
S Exchange 2010 autodiscover Exchange Server Administration 4
R Autodiscover virtual directory - recreation fails Exchange Server Administration 1
A share one record for autodiscover between exch 2007 and exch 2010 Exchange Server Administration 4
O SSL certificate needed for autodiscover.domain.com Exchange Server Administration 12
C Windows 7/Outlook 2010 vs Windows XP/Outlook 2007 - Autodiscover authentication looping Using Outlook 1
