Active Sync proxying not works in a Exchange 2010/2007 Coexistence
F
fgeo-ch
Hello
We have the following Configuration on our Exchange 2010/2007 Coexistence Infrastructure:
2 x Exchange 2007 CAS/HUB Servers (Hardware LB oldmail.domain.ch)
2 x Exchange 2010 SP1 CAS/HUB Servers (Hardware LB mail.domain.ch)
1 x Exchange 2007 CCR Cluster
2 x Exchange 2010 SP1 DAG Members
Synchronising EAS Devices via CAS1 2010 works, the devices can do proxy or redirect to CAS1 2007 or CAS2 2007 for Mailboxes on 2007 CCR Cluster.
Synchronising EAS Devices via CAS2 2010 does not work, no proxy or redirect is possible. Both the Servers CAS1 2010 and CAS2 2010 have the same EAS and IIS configuration.
CAS 2010 Servers Microsoft-Server-ActiveSync URLs:
InternalUrl : https://mail.domain.ch/Microsoft-Server-ActiveSync
ExternalUrl : https://mail.domain.ch/Microsoft-Server-ActiveSync
CAS 2007 Servers Microsoft-Server-ActiveSync URLs::
InternalUrl : https://oldmail.domain.ch/Microsoft-Server-ActiveSync
ExternalUrl : https://oldmail.domain.ch/Microsoft-Server-ActiveSync
IIS Logs on CAS1 2010 generate the following error:
2010-10-22 11:58:27 130.92.13.19 POST /Microsoft-Server-ActiveSync/default.eas User=ex2010test&DeviceId=Appl7S0396LLA4S&DeviceType=iPhone&Cmd=Sync&Log=PrxTo:eek:ldmail.domain.ch_LdapC1_Error:ConnectFailure_Mbx:ex2007ccr.domain.ch_Budget:(D)Conn%3a1%2cHangingConn%3a0%2cAD%3a%24null%2f%24null%2f0%25%2cCAS%3a%24null%2f%24null%2f0%25%2cAB%3a%24null%2f%24null%2f0%25%2cRPC%3a%24null%2f%24null%2f0%25%2cFC%3a%24null%2f0%2cPolicy%3aDefaultThrottlingPolicy%5Fbfadef95-5b87-4e1a-9eb1-52f3f6197b54%2cNorm_ 443 domain.ch\ex2010test 130.92.x.x Apple-iPhone3C1/802.117 500 0 0 42089
Does anyone has an Idea?
Thanks for any Help, fgeo-ch
F
fgeo-ch
I solved the Problem by reinstalling RU1 for Exchange 2010 SP1 on the CAS1 2010 box!
A CAS Proxying with Active Sync when migrate from Exchange 2007 to 2010 Exchange Server Administration 1
W active sync Using Outlook 2
E Using with Active Sync, Outlook become unresponsive Using Outlook 5
K publish exchange active sync behind TMG Exchange Server Administration 4
S Active Sync Device ID Using Outlook 2
P Ex2010 active sync Exchange Server Administration 4
R Hi, Is Outlook 2010 compatible thru active sync with Windows Mobile 6.1 Professional. Using Outlook 4
S Exchange 2010 - Active Sync issue - Samsung Galaxy S Exchange Server Administration 2
P Exchange 2010 SP1 and HTC Desire Active-Sync Exchange Server Administration 5
A Active sync problem - related to improper decomission of Exchange 2007 when migrating to Exchange 2010 Exchange Server Administration 2
G Error Active Sync in Exchange Server 2010 Exchange Server Administration 12
P Automate Outlook Start - No Active Explorer Object Found Using Outlook 10
S Active Directory Management Tools for Administrators New Slipstick.com Articles 0
Diane Poremsky Import Images into the Active Directory New Slipstick.com Articles 0
S How to send an OUTLOOK task to a contact out of my active directory? Using Outlook 2
E Outlook rule only active certain times of day Using Outlook 6
R HELP!!! Email template with active excel spreadsheet Using Outlook 1
C active/passive broadband connections to maintain various IT services Exchange Server Administration 2
R Went from outlook 2003 to 2010 - can't retrieve active for contacts Using Outlook 0
J Setup mail for Exchange 2010 through Active Directory on Server 2008 R2 Standard Exchange Server Administration 3
T Copied Contact Does Not Update With Active Directory Information Changes Immediately. How Do I Force Update? Using Outlook 1
B Re: Exchange OOF / EWS Problem - The user and the mailbox are in different Active Directory sites Exchange Server Administration 0
M 'Send link by E-mail' doesn't provide active link.__ Using Outlook 1
J When a database move from active host in a DAG, user are prompted for credentials Exchange Server Administration 8
D Using Inbox as 'Active' tray, with both incoming and 'sent' mail, with senders and receivers displayed. Using Outlook 1
U Outlook 2010 Ignore Conversation Feature, list of Active Ignored Using Outlook 1
D how to give perrmission on calender to user in ACTIVE DIRECTORY Using Outlook 0
J OWA not working when active database moved Exchange Server Administration 3
S Web Links are not active when using Outlook Web Access 2007 Using Outlook 1
P How can I convert an Outlook 2010 folder to a .pdf with active links like I could in Outlook 2007? Using Outlook 3
T The Microsoft Exchange Active Directory Topology service on server localhost can't be contacted via Exchange Server Administration 2
P Will 'ldap modify' command work on some Active Directory fields? Using Outlook 2
S Active Passive DAG seperate DNS namespace Exchange Server Administration 7
B Active Active Site Resilience Exchange Server Administration 3
E Event ID 9514 - Two objects in Active Directory have the same proxy address Exchange Server Administration 3
C Active Directory error applying Exchange 2010 SP1 Exchange Server Administration 4
E Transfer calendar from a .pst to a user's active exchange account? Using Outlook 7
M Active Manager operation failed to mount DB Error Id: 50A399C7, ErrorId: BF128831 Exchange Server Administration 10
O Exchange 2010 Service Pack 1 Active Directory Schema Exchange Server Administration 1
K An Active Manager operation fail Exchange Server Administration 6
A No Word e Outlook 2010 não funciona o rolamento de página (scroll active) com mouse. Como corrigir Using Outlook 1
T Active Directory domain 'FECR' has an unrecognized Exchange signature. Current DomainPrep version: 1 Exchange Server Administration 2
M DAG Active/Active Exchange Server Administration 2
B DAG with active passive database configuration Exchange Server Administration 13
S Outlook reply window default tabs have changed from message being active, to now File being active. Using Outlook 1
C Active Directory does not exist or cannot be contacted Exchange Server Administration 12
A Active task for selected days options Outlook Wishlist 1
T Exchange 2010 servers can't communicate with Active Directory Exchange Server Administration 4
L VBA Processing of Active E-Mail Message Outlook VBA and Custom Forms 2
