How to enable Outlook Anywhere for domain joined clients, enable Exchange ActiveSync, but disable OA
G
GauteA
Outlook 2007 on domain joined clients to connect to Exchange 2010 SP1 (autodiscovery and mail.domain.com published addresses) for Outlook Anywhere.
No support for mail on non domain joined clients (e.g. home PCs), but since autodiscovery is available for OA - how can that be blocked?
Exchange ActiveSync to be supported as well.
regards
Gaute
Michel de Rooij
OA is meant to the requirement for VPN, so there's limited functionality to block it - only on user level using things like
Set-CASMailbox -Identity <MailID> -MAPIBlockOutlookRpcHttp:$false
OA uses RPC over HTTP which travels over port 443 so you can't block that. Note that RPC/HTTP uses the /rpc and /rpccert virtual folders. You can try blocking those on your reverse proxy to block access from the outside world, but that would also mean no access for travelling people accessing outlook using domain joined clients.
An area I'm thinking of is client certificates. This comes down to putting client certificates on your clients and requiring them on your reverse proxy. But AFAIK Outlook doesn't understand the IIS request for a client certificate
Michel de Rooij,
MCITP Ent.Msg 2007+2010| MCTS W2008, Ex2007+2010 Conf, OCS2007 Conf | MCSE+Msg2k3 | MCSE+Inet2k3 | Prince2 Fnd | ITIL
I blog on http://eightwone.wordpress.com/ and tweet on http://twitter.com/mderooij
M SRV records to enable auto discover for Outlook Anywhere Using Outlook 8
M Outlook Anywhere - Enable both NTLM and Basic Authentication Exchange Server Administration 8
Sarge USMC how do I enable hyperlinks in Outlook 2013 Using Outlook 1
D How To Enable Undo in Outlook 2007 Tasks Using Outlook 2
S Outlook 2010: How do you enable Contacts' Activities to search archive folders Using Outlook 6
Z Patch / hotfix enable Outlook 2007 to work with Exchange 2010 Archiving Exchange Server Administration 2
I Outlook 2007 Macro/VBE disables How to enable Using Outlook 5
W Outlook was in use; when tried to open today it would not open; pop up with info about e-mails with macros; prompted to enable macros, when doing so; Using Outlook 3
M Enable to access outlook 2003 even in safe mode and is giving an error message that Business Contact Manager has encountered a problem Using Outlook 2
C How do I enable a link in an e-mail in Outlook 2007? Using Outlook 4
J Office Ultimate- My outlook doesn't have BCM, how do I enable? BCM (Business Contact Manager) 1
Diane Poremsky Mail-enable Exchange Public Folders New Slipstick.com Articles 0
R Enable Office 365 Exchange Online Archive New Slipstick.com Articles 0
R Enable Office 365 Exchange Online Archive Using Outlook 6
K Macro won't consistently re-enable Outlook VBA and Custom Forms 2
A how to install or enable categories in OL 2013 for calendar and contacts Using Outlook 5
D How do I mail-enable a Public Folder Sub-folder in exchnage 2007 using shell ? Exchange Server Administration 0
H enable textboxes and buttons from received email Using Outlook 1
J OL2003 Macro disables itself - looking for way to automate 'enable' Using Outlook 2
C Enable or install Digital ID for Exchange Users on SBS 2008 Exchange Server Administration 2
S vb.net exchange 2010 problem with enable-mailbox command Exchange Server Administration 2
P Exchange 2010 - Enable Spam filtering on Hub Transport Server Exchange Server Administration 3
C Enable EmailAddressPolicy via Exchange Shell Exchange Server Administration 2
C How to allow admins to enable ActiveSync and edit address book information in EMC Exchange Server Administration 3
J cannot enable embedded links within received e mails, message sysy this function is disabled please contact your system administrator Using Outlook 1
M OWA (2003,2007,2010) How to enable or Disable efficiently in Bulk range Like Database/Storage Group/Server Exchange Server Administration 3
Z How to enable Content Filtering for Inbound and Outbound Emails on Exchange 2007? Exchange Server Administration 4
D OAB Offline Address Book generation server and enable web distribution on the Exchange 2010 Client Access server Exchange Server Administration 6
R How do I re-enable the confirmation dialog? Using Outlook 4
J Re-enable the junk mail notification. Using Outlook 6
A how to enable macro for addin Outlook VBA and Custom Forms 3
J Enable Sonicwall Outlook VBA and Custom Forms 1
S How do I enable administrator access in Business Contact Manager? BCM (Business Contact Manager) 1
S How to enable scripts to run in a custom form which is forwarded ? Outlook VBA and Custom Forms 1
K How do I eliminate the "Enable Macro" selection? Outlook VBA and Custom Forms 16
C Eliminate need for "Enable Macro" selection Outlook VBA and Custom Forms 7
P outlook 2008 search box criteria couldn't be saved Using Outlook 1
pcunite Outlook 2019/O365 Build 13127.20408 errors when using MAPI calls Using Outlook 0
D Outlook 2010 Outlook in Windows 10 keeps asking for user name and password repeatedly Using Outlook 0
J How do I disable advertising in Outlook 2019? Using Outlook 5
