Problem with installing Exchange 2010, AD problems?
Drtveit
I'm trying to install Ms Exchange 2010 server, on a Ms Windows 2008 server. This server is member of a AD domain.
I don't get anny error in " Readiness Checks" , but in " Progress" I get this error:
Organization preparation:
Error:
The following error was generated when " $error.Clear(); buildToBuildUpgrade-ExsetDataAtom -AtomName OrgCtChildren -DomainController $RoleDomainController" was run: " An error occurred with error code '2147950602' and message 'The specified directory service attribute or value does not exsist.'." .
What can I do?
Alexei Segundo
Have you already run setup with the /ps (PrepareSchema) switch? If so, what Exchange schema version does your AD show?
If you need it, a useful way to find the schema version is to use adfind.exe from www.joeware.net, e.g.
adfind -schema -f " (&(objectClass=attributeSchema)(name=ms-Exch-Schema-Version-Pt))" rangeupper
Exchange 2010 (RTM) has a value of 14622.
Alexei
Drtveit
Thnx for answer. I used ADSI edit, and I have value 14622.
But, at the current Active Directory Schema Version, it's value " Not set" . Should it not be a number her??
G
Gavin-Zhang
Hi Drtvei,
About how to deploy exchange 2010, I would suggest that you could follow below DOC carefully, it would lead you successfully.
http://technet.microsoft.com/en-us/library/bb691354.aspx
http://technet.microsoft.com/en-us/exdeploy2010/default(EXCHG.140).aspx#Home
What about your AD domain, which OS of your DC, Do you have other exchange server in your domain?
You could learn more refer to the Links above, if you still run into some issue, and then tell us, we could give you more help.
Regards!
Gavin
Drtveit
Hy, thnx for your reply. I have tried all the tricks described in your links, but I have the same error.
I have no other Exchange server in my domains, and my domains and forrest is windows 2003 native. The Schemamaster was in another locations, but I have tried to force server (who I try to install Exchange on) on the same site as Schema master, and I changed Schema master to be on the DC on the same location and site who the new Exchangeserver is on.
I have tried to disable IPv6, and I have tried to enable IPv6 (and with static IPv6 adress). I have also used Google to find all tips and tricks discribed to error 2147950602, but I have the same error.
G
Gulab Mallah
I believe you are getting this error message when you are running Setup.com /ps !
As per you description above you see the value 14622, could you specify the attribute?
Run the command Setup.com /preparead one more time and see what happens.
-Gulab
Drtveit
Yes, I have problems when I run setup /ps. But, I didn't get this error before. My error was in setup /preparead
14625 is my attribute.
G
Gulab Mallah
Okay,
I asked for the name of the attribute on which you are getting this value " 14625"
-Gulab
Drtveit
Idon't now. I get the value 14625 in the error msg when I run setup /ps
In " CN=Schema,CN=Configuration,DC=domain,DC=local" , the objectVersion is set to: " Not set" . Anything wrong here?
K
Kiran Gaikwad
I presume you are installing first exchange server in the org.
Is it possible to chose a different domain controller? ( /DomainController:<FQDN of domain controller> )
In worst case you can use ADSIEdit & remove the existing Exchange specific containers & can attempt installing Exchange again.
Regards,
Kg
Drtveit
Hy,
Yes, that's correct. It's my first Exchangeserver in the org.
I have used to different domain controller, but with same result.
I have also used ADSIEdit and removed two Exchange-folders in:
configuration -> Services
G
Gulab Mallah
It's fine, it should be not set only.
Did you ran setup.com /preparedomain
-Gulab
Drtveit
Yes, have tried that several of times. I get this error:
copying setyp files: completed
organization checks: failed
The active directory myst be modified whit setup /preparead before domains can be prepared for exchange 2010
And, when I run setup /preparead, I get this error:
Preparing Exchange Setup
Copying Setup Files ......................... COMPLETED
No server roles will be installed
Performing Microsoft Exchange Server Prerequisite Check
Organization Checks ......................... COMPLETED
Setup is going to prepare the organization for Exchange 2010 by using 'Setup /P
repareAD'. No Exchange 2007 server roles have been detected in this topology. Af
ter this operation, you will not be able to install any Exchange 2007 server rol
es.
Configuring Microsoft Exchange Server
Organization Preparation ......................... FAILED
ied directory service attribute or value does not exist.'." .
The Exchange Server setup operation did not complete. Visit http://support.micro
soft.com and enter the Error ID to find more information.
Exchange Server setup encountered an error.
Drtveit
If it's help; I run Windows server 2008 R2.
I have used ADSIEdit after I get this errors. It's not all " folders" that contains any objects (cn=First Organization,CN=Microsoft Exchange,CN=Services,CN=Configuration,DC=mydomain,DC=no).
And here is even more errors, from the ExchangeSetup log-file:
[01.11.2010 18:20:19] [2] ScCreateOrgLevelAddressTypeObj (f:\08.03.0083\sources\dev\admin\src\libs\exsetup\dsmisc.cxx:841)
Error code 0X8007200A (8202): The specified directory service attribute or value does not exist.
[01.11.2010 18:20:19] [2] Leaving ScCreateOrgLevelAddressTypeObj
[01.11.2010 18:20:19] [2] CAtomOrgCtChildren::ScCreateProxyDLLObjects (f:\08.03.0083\sources\dev\admin\src\udog\exsetdata\components\server\a_orgctchildren.cxx:1067)
[01.11.2010 18:20:19] [2] Leaving CAtomOrgCtChildren::ScCreateProxyDLLObjects
[01.11.2010 18:20:19] [2] CAtomOrgCtChildren::ScAddDSObjects (f:\08.03.0083\sources\dev\admin\src\udog\exsetdata\components\server\a_orgctchildren.cxx:216)
[01.11.2010 18:20:19] [2] Leaving CAtomOrgCtChildren::ScAddDSObjects
[01.11.2010 18:20:19] [2] mode = 'Install' (61953) CBaseAtom::ScSetup (f:\08.03.0083\sources\dev\admin\src\udog\setupbase\basecomp\baseatom.cxx:535)
[01.11.2010 18:20:19] [2] ScSetupAtom (f:\08.03.0083\sources\dev\admin\src\udog\exsetdata\exsetds.cxx:897)
[01.11.2010 18:20:19] [2] Leaving ScSetupAtom
[01.11.2010 18:20:19] [2] [ERROR] An error occurred. The error code was 2147950602. The message was The specified directory service attribute or value does not exist..
G
Gavin-Zhang
Per your above description, I want to verify what about your whole scenario, topology and so on.
1. Do you have several sites?
2. Do you have root domain and subdomians, or just have one domain with several sites?
3. Do you have exchange system installed in your datacenter?
4. How do you force your SCHEMA FSMO role onto the new sever in your site, could you please confirm that?
5. Do you use the account with enough permission do the operation
6. Do you install the exchange 2010 server on the box which has DC installed in the local? It is strong not recommended.
Note, One domain org could only has one schema master FSMO. So please confirm that you have AD scenario configured correctly and then deploy the exchange 2010.
If you it is done, you just could install prequests kb/role/feature on the windows 2008 R2 box, and then use the UI setup, it would prepare the schema/domain and so on automatically, no need use the command to do that, it would more easy than that.
Regards!
Gavin
Drtveit
Yes, for the moment, 7 sites.
I have 1 forrest with 2 child domains, everyone have more than 1 sites
No, I don't
I'm not sure what you meen, but I transfered the Schema role to the DC server (at the same location as Exchange) thru " Active Diretory Domains and Trust" -tool in MMc.
Yes, It's the global administration account (enteprice admin, schema admin, domain admin, etc)
No, I have another box that have DC. I cann't install DC at windows 2008 (Errormsg says I have to use adprep on the main DC, but when I try that, I get msg that says I already have used adprep...).
I have installed all KB that I can find on the internett. I also have all updates from Windows update.
When I read about other similar problems on the Internett, I'm thinking about to sinarios:
1. Is it some problems adding groups to the DC?
2. Is it some problems adding to the domain configuration? (I mentioned that is kind of empty in the domain configuration cn=configuration,dc=domain. Its alomst only containers)
G
Gavin-Zhang
Hi Drtveit,
If it is a subdomain, I would suggest you do the prepare in the root domain firstly.
Regards!
Gavin
C Now the problem I see is that I get an error when installing the Exchange 2010 SP 1. I attach a scre Exchange Server Administration 10
R Problem installing Unified Messaging on Exchange 2010 SP1 Exchange Server Administration 3
A Problem installing SP1 for Exchange 2010 Exchange Server Administration 8
M Is there any problem in installing MS exchange server in India with SMS sysnc options enabled? Exchange Server Administration 3
G Problem with Outlook 2010 after installing update to Word Perfect X5 Using Outlook 4
J Problem with Word 2010 and Outlook 2010 after installing today's MS updates Using Outlook 1
J Problem installing the web based Microsoft Agent Communications Pa Outlook VBA and Custom Forms 1
C Problem installing VSTO AddIn on Vista Outlook VBA and Custom Forms 3
