How tough is it to convert VBA to Addin
Q
QWRkaW5fTm9vYg
Greetings all,
I have built some pretty nice VBA macros for Outlook 2007. I was wondering
if you could give me some idea on how difficult it will be to convert these
to Addins. Also can I do this with VB 6 or VB .Net 2003?
Maybe some step by step tutorials for converting VBA to an addin or other
references would help.
Sorry for the general question.. Just trying to get a feel for the process
before shelling out the money to buy VS. [I currently have VB 6 and VS .Net
2003 Pro]
-Tim
K
Ken Slovak - [MVP - Outlook]
VS 2003 uses Framework 1.1, I'd not bother using it these days when far less
buggy versions are out there. VB6 can certainly be used and the conversion
curve is far easier since that and VBA are very closely related.
I've never seen any step by step guide for a conversion, you basically just
implement the IDTExtensibilty interface in your Connect module and the VBA
code can pretty much be copied and pasted into the addin.
You might want to look at the VB6 addin template I have up at
http://www.slovaktech.com/outlook_2007_templates.htm. That gives you a
framework to start with.
"Addin_Noob" <Addin_Noob> wrote in message
news:7059E96A-5C88-430A-A492-EC3BB9B8CFC0@microsoft.com...
> Greetings all,
> wondering
> these
> process
> .Net
> 2003 Pro]
> -Tim
K Need to convert .mmf file to .pst format Outlook VBA and Custom Forms 4
M Convert Subject Line to Internet Header version of Subject Outlook VBA and Custom Forms 10
P How do I convert outlook “to-do” items to “tasks” Outlook VBA and Custom Forms 1
C convert an .ost to .pst Using Outlook 3
D The way to convert ost to pst Using Outlook 2
sneaky30 convert text to date Outlook VBA and Custom Forms 1
Diane Poremsky Convert an Offline File (.ost) to a Personal File (.pst) New Slipstick.com Articles 0
S How to do I convert OST file to PST? Exchange Server Administration 3
J convert .pst to .eml, how is it possible? Using Outlook 1
M convert/import a customized record into the default "Account" record BCM (Business Contact Manager) 0
V Check/convert to emailaddresses Outlook VBA and Custom Forms 11
R Convert Access table to pst Using Outlook 1
L Convert Distribution List of Contacts to Single Contacts Using Outlook 6
G Is there any way to convert outlook 2003 to outlook 2007 Using Outlook 5
D Outlook contacts no in address book - 2002 pst file convert to 2007 pst file? Using Outlook 0
A Outlook 2003: convert all RTF emails to HTML Outlook VBA and Custom Forms 1
J How to convert BCM contacts to normal Outlook contacts BUT... BCM (Business Contact Manager) 2
G Tasks - convert email to task & attach email Outlook VBA and Custom Forms 6
A Re: Convert Oportunity to Project? BCM (Business Contact Manager) 3
B convert VBA code to Add-in Outlook VBA and Custom Forms 1
K can't get custom form to update multiple contacts using VBA Outlook VBA and Custom Forms 1
S Excel vba code to manage outlook web app Using Outlook 6
