Best Practice for Large Messages NDRs?
I
it-works'
We have EX 2010. When a user sends a large attachement like 50MB it goes to the other user's mailbox but Blackberry rejects it (Blackberry Limit) and the user gets this:
" This message is too large to send. To be able to send it make the message smaller, for example, by removing attachments."
I understand it's a normal behavior because the BB obviously rejects the large attachements. My question is can I disable " this specific NDR" from going back to the senders, while me (admin) being able to keep receiving it?
Any suggestions on best practice would be much appreciated.
Thanks Much!
" #< #5.2.3 smtp;450 5.2.3 Msg Size greater than allowed by Remote Host> #SMTP#"
AndyD_ [MVP]
Why wouldnt you want that NDR to go to the sender?
Not sure what you are asking.
G
Gulab Mallah
As Andy said Why?
Why you want to do it? Any specific reason/
-Gulab
G
Gen Lin
Based on my experience, it is unable to do this on exchange server.
I
it-works'
Sorry for the delay.
{Why wouldnt you want that NDR to go to the sender?}
The senders already know that the bb rejects large attachements, if they send this user 20 emails a day with large attachments this could be annoying.... The emails arrive at the mailbox so they basically disregard this message.
it-works!
Horsepower Email best practice Using Outlook 3
D Exchange Best Practice for DEV/TEST/PROD Exchange Server Administration 2
Rupert Dragwater What is the best way to back up pst Using Outlook 4
Diane Poremsky The Best Outlook Store Add-ins Contest New Slipstick.com Articles 0
X Best utility for repairing PST files? Using Outlook 3
D a suggestion ...sent with the best intentions Using Outlook 1
M How best to track OUTGOING referrals? BCM (Business Contact Manager) 2
M best duplicate contact remover? Using Outlook 6
G what is the best way to organize outlook contacts Using Outlook 1
D What would be the best strategy? Using Outlook 3
J Best way to move form old to new, larger pst? Using Outlook 2
M Best way to move outlook? Using Outlook 1
R Best way to share outlook calendar with 10 laptops Using Outlook 9
N Outlook 2010, Categories, best way to filter contacts? Using Outlook 5
F Best Non MS Exchange 2010 book for beginners? Exchange Server Administration 7
S CAS/MBX reboot best practices. Exchange Server Administration 7
L best rule/macro to send emails from many people/orgs to same folder Using Outlook 3
R Any "Best Practices" for a test/developer Exchange 2010 server? Exchange Server Administration 2
C Best way to effectively back up Outlook Calendar (and save Categories) and Email as well???? Using Outlook 6
R Best practices for creating "Equipment" mailbox resources? Using Outlook 1
M Exchange 2010: What to monitor - best practices Exchange Server Administration 4
K Best case scenerio to reduce disk space usage Exchange Server Administration 5
B Best way to get a pick-list on a form? Outlook VBA and Custom Forms 1
M Best way to distribute VBA project Outlook VBA and Custom Forms 4
T Is Explorer.FolderSwitch the best event for hiding commandbarbutton? Outlook VBA and Custom Forms 5
A Where are the Step by Step Microsoft outlook 2010 practice files? Using Outlook 3
