Autodiscover issues on Exchange 2010
P
parkwaytech
Have an interesting issue. We host an Exchange 2010 environment with 2 servers (CAS\HUB\Mailbox installed on both servers). Only 1 server EXCH is configured for Outlook Anywhere. OWA is working great, and mail can flow both inside and outside the organization. However, Autodiscover seems to be having some issues. Some organizations (we've got several on the servers) connect just fine. Others though fail with the error that an encrypted connection cannot be found. We use an Autodiscover redirect since we host several different domain names for different organizations.
Both servers have Server 2008 R2 with the latest patches. We are not running Exchange 2010 SP1, because the control panel we use doesn't currently support it. However, Exchange 2010 is updated with all the patches (except for SP1). We use a DAG that seems to be working just fine.
This is just the strangest thing is that this only seems to be happening with some accounts. These accounts don't seem to be any different though. When I configure Outlook manually, they work just fine.
[PS] C:\Windows\system32>Test-OutlookWebServices | fl
RunspaceId : 148dbce3-c8a1-4614-9fba-1ed795877420
Type : Information
Message : A valid Autodiscover service connection point was found. The Autodiscover URL on this object is https://EX
CH.mail.****.com/Autodiscover/Autodiscover.xml.
Type : Information
Message : Contacted the Autodiscover service at https://EXCH.mail.****.com/Autodiscover/Autodiscover.xml
Type : Information
Message : [EXCH] The AS is configured for this user in the AutoDiscover response received from https://EXCH.mail.****.com/Autodiscover/Autodiscover.xml.
Type : Information
Message : [EXCH] The OAB is configured for this user in the AutoDiscover response received from https://EXCH.mail.****.com/Autodiscover/Autodiscover.xml.
Type : Information
Message : [EXCH] The UM is configured for this user in the AutoDiscover response received from https://EXCH.mail.****.com/Autodiscover/Autodiscover.xml.
Type : Information
Message : [EXPR] The AS is configured for this user in the AutoDiscover response received from https://EXCH.mail.****.com/Autodiscover/Autodiscover.xml.
Type : Information
Message : [EXPR] The OAB is configured for this user in the AutoDiscover response received from https://EXCH.mail.****.com/Autodiscover/Autodiscover.xml.
Type : Information
Message : [EXPR] The UM is configured for this user in the AutoDiscover response received from https://EXCH.mail.****.com/Autodiscover/Autodiscover.xml.
Type : Success
Message : Autodiscover was tested successfully.
Type : Success
Message : [EXCH] Successfully contacted the AS service at https://exch.mail.****.com/EWS/Exchange.asmx.
The elapsed time was 202 milliseconds.
Type : Success
Message : [EXCH] Successfully contacted the UM service at https://exch.mail.****.com/EWS/Exchange.asmx.
The elapsed time was 15 milliseconds.
Type : Success
Message : [EXPR] Successfully contacted the AS service at https://mail.****.com/ews/exchange.asmx. The e
lapsed time was 124 milliseconds.
Type : Success
Message : [EXPR] Successfully contacted the UM service at https://mail.****.com/ews/exchange.asmx. The e
Type : Success
Message : [Server] Successfully contacted the AS service at https://exch.mail.****.com/ews/exchange.asmx
. The elapsed time was 78 milliseconds.
Type : Success
Message : [Server] Successfully contacted the UM service at https://exch.mail.****.com/ews/exchange.asmx
. The elapsed time was 15 milliseconds.
Type : Error
Message : When contacting https://mail.****.com/rpc received the error The remote server returned an err
or: (503) Server Unavailable.
Type : Error
Message : [EXPR] Error contacting the RPC/HTTP service at https://mail.****.com/rpc. Elapsed time was 15
milliseconds.
Type : Error
Message : When contacting https://exch.mail.****.com/rpc received the error The remote server returned a
n error: (503) Server Unavailable.
Type : Error
Message : [EXPR] Error contacting the RPC/HTTP service at https://exch.mail.****.com/rpc. Elapsed time w
as 15 milliseconds.
P
parkwaytech
I want to add one note. On some of the the accounts, I am now getting: " The name cannot be resolved. The name cannot be matched to a name in the address list. as the error."
It also appears that this issue is larger, for whatever reason, than it was earlier. I haven't changed a thing, but we now cannot get anyone to connect through Autodiscover. Manual setup still works just fine.
Jonas Andersson [MCITP]
Have you installed RPC feature?
Enabled Outlook Anywhere?
Are you using a SAN/UC cert?
Jonas Andersson MCTS: Microsoft Exchange Server 2007/2010 | MCITP: EMA 2007/2010 | MCSE/MCSA Blog: http://www.testlabs.se/blog
P
parkwaytech
RPC is installed, Outlook anywhere is enabled, and we have a 10 domain UCC cert.
P
parkwaytech
We are not using HMC. I've been through both of those documents.
B AutoDiscover Forensics Exchange Server Administration 0
EXChange2013 Exchange 2013 AutoDiscover Tweaks? Exchange Server Administration 0
M Outlook 2007 AutoDiscover Using Outlook 0
A Exchange Autodiscover SSL issue Exchange Server Administration 7
M Initial Outlook Configuration with AutoDiscover populates wrong email address Using Outlook 5
N Outlook 2007 Clients Pointed to Wrong Domain Name for Autodiscover Using Outlook 2
K testing autodiscover and exchange coexistence Exchange Server Administration 2
C The Autodiscover service couldn't be located. Exchange Server Administration 8
C Exchange server 2010 error "The Autodiscover service couldn't be located." Exchange Server Administration 1
J Autodiscover accounts on exchange 2003 with Outloook 2010 not working Using Outlook 4
Z Autodiscover Points to defunct Exchange 2010 Server Exchange Server Administration 5
M Autodiscover not configuring Outlook Anywhere Using Outlook 10
B Autodiscover error 0x800c8203 and encrypted connection is not available Exchange Server Administration 3
P Autodiscover URLs Exchange Server Administration 15
C Autodiscover Exchange Server Administration 6
I Exchange 2010 Profile AutoDiscover not working for some users Exchange Server Administration 1
S Exhcange 2010 autodiscover virtual directory Exchange Server Administration 4
D External Autodiscover Exchange Server Administration 3
S Exchange 2010 Autodiscover Problems, cannot connect Outlook clients using Autodiscover / Outlook Any Exchange Server Administration 4
G Exchange 2010/Outlook 2007 Can't get autodiscover to work for some users, but others work fine Exchange Server Administration 3
S Autodiscover issue Exchange 2007 Using Outlook 4
P Autodiscover will not work Exchange Server Administration 13
K Exchange 2010 Autodiscover Exchange Server Administration 1
P Autodiscover fails (Exchange 2010) Exchange Server Administration 7
S Exchange 2010 Outlook 2010 Autodiscover fails Exchange Server Administration 22
C Getting Autodiscover to work with other web servers ... Using Outlook 4
C Autodiscover Service Configuration Exchange Server Administration 5
B move mailbox- autodiscover Exchange Server Administration 25
T Autodiscover authentication Exchange Server Administration 2
A autodiscover issue with OL2010 but no issue with OL2007 Exchange Server Administration 10
K Autodiscover and SRV records Using Outlook 10
S Autodiscover redirected Using Outlook 2
C Autodiscover Exchange Server Administration 5
S Autodiscover two AD sites two cas arrays Exchange Server Administration 4
O Autodiscover Exchange Server Administration 4
S Autodiscover FQDN certificate for secondary domain email? Exchange Server Administration 1
K Remove AlternativeMailbox - Autodiscover Exchange Server Administration 5
S Exchange 2010 autodiscover Exchange Server Administration 4
R Autodiscover virtual directory - recreation fails Exchange Server Administration 1
A share one record for autodiscover between exch 2007 and exch 2010 Exchange Server Administration 4
O SSL certificate needed for autodiscover.domain.com Exchange Server Administration 12
C Windows 7/Outlook 2010 vs Windows XP/Outlook 2007 - Autodiscover authentication looping Using Outlook 1
