Need Help on Designing Exchange 2010 Email Solution for 4000 Users
Maksudur Rahman
Project Background:
I am trying to design a Exchange 2010 Email Solution with High availability feature covering a DC and DR Site for 4000 users.
The solution will implement archival and replication feature.
One FC SAN storage will be allocated for DC and also one for DR for storage consodilation that will be connected to:
Oracle Database Servers, Application Servers, E-Mail Servers , Domain Controller Servers, Web Servers, Anti-Virus Servers, Proxy Servers, Backup Servers (to be configured across DC and DR Sites)
Dark Fiber connectivity and WAN Connectivity will be established between DC and DR.
Things that I Considered for far for Designing:
I want to propose 4 Servers in DC: 2 Servers for CAS Array, HUB Array and Edge Array + 2 Servers for acting Mailbox Server(s) at DC and an identical quantity in DR.
Exchange Replication will be through 3rd Party Software to FC SAN Storage from DC and DR.
Exchange Archival will be through 3rd Party Software to FC SAN Storage in DC, later to be stored in Tape Library in DC .
I want to propose 2 Servers for acting as Mailbox Server(s) to create redundant sets of 01 Mailbox (Note: There will be 01 mailbox database to cover 4000 users (covering both head office & remote branch office users).
I want to propose 2 Servers for CAS Array, HUB Array and Edge Array for High Availability.
I want to propose 01 Hardware Network Load Balancer Device for DC and 01 for DR.
My Queries:
Query A:
Can I recommend CAS Array, HUB Array & Edge Array be configured all-together on 2 (two) servers (for higher availability of CAS,HUB and Edge)?
Query B:
Which connectivity option shall I recommend/consider in my design:
Option A: a direct connectivity of the mailbox server(s) to CAS/HUB/Edge servers through dedicated NIC Cards placed in these Servers
Option B: All servers are to connected through a Gigabit Switch?
Query C:
Where will I place the hardware NLB for load-balancing in case of Option A and Option B mentioned under Query B:
Please Help Me.
You can also reach me at my alternate email address: maksud1982@gmail.com
G
Gavin-Zhang
Hi Maksudur,
Per your description, it is big project, right? and you have little knowledge about the exchange server 2010, right?
I would suggest that you could turn to help from MS partner or call MS support, you will get more help and good suggestion from their, because it is difficult to describle a detailed planning for you on the forum, yet, just my suggestion, it will reduce the cost time on the planning and deployment on the project. :)
Query A:Can I recommend CAS Array, HUB Array & Edge Array be configured all-together on 2 (two) servers (for higher availability of CAS,HUB and Edge)?
Answer: you could install the edge server on any other cas/hub/mailbox/um server, you could install the cas and hub on one box, you also have two boxs act as a cas array, note: you just need manually configure the cas array, hub and edge server both all could achieve HA by default.
Query B:Which connectivity option shall I recommend/consider in my design:Option A: a direct connectivity of the mailbox server(s) to CAS/HUB/Edge servers through dedicated NIC Cards placed in these ServersOption B: All servers are to connected through a Gigabit Switch?
Answer: you could use a gigabit Switch connect all the servers
Query C:Where will I place the hardware NLB for load-balancing in case of Option A and Option B mentioned under Query B
A: If you use third pary LB, there are some DOC from their vender, you could according to those.
Best regards!
Gavin
N Outlook 2007/2010 , need help designing HTML signature that elegantly degrades to plain text Using Outlook 1
G Need help configuring a PRF for Outlook 2010 and 2013 Using Outlook 0
K Excel Import Option: Need Help Updating Existing Records BCM (Business Contact Manager) 0
K Need help concerning emails linking to BCM. BCM (Business Contact Manager) 0
J Need help with installation of BCM in Outlook2013 BCM (Business Contact Manager) 5
F Outlook 2010 - Need help with a custom field. Using Outlook 3
L Need help getting calendar/contacts/tasks/notes back! Using Outlook 3
P Need help/Gmail accounts show separately/Outlook 2013 Using Outlook 0
J Need Help Extracting Email Content into Excel Specifically the Attachment Name Using Outlook 3
A Need Help with BCM2010 Sharing on outlook 2013 Scenario! BCM (Business Contact Manager) 1
W I Need help with vb.net and outlook 2010 Using Outlook 2
A My move to MS is not going too well: Need Help !!! Using Outlook 14
M Need help with combo boxes in messages! Using Outlook 10
D Need help understanding which pst-file to use! Using Outlook 0
U Need a help please Outlook 2007 crashing Using Outlook 2
Z Need Help Outlook 2007 inbox and address book view Using Outlook 2
B Need help adding a background color to the compact list items in Month view. Calendar Printing Assistant 1
B Need help adding an image next to the Month Name in the header. Calendar Printing Assistant 1
B Ok - a complicated one - but really need help (auto formatting) Using Outlook 9
B OUTLOOK 2000, Need Help ! Outlook Wishlist 1
P To Use BCM or not...I need help BCM (Business Contact Manager) 1
T Need help making RULE to prepend email SUBJECT Using Outlook 3
V Need help on configuring Outook 2003 Rules and Alerts... Using Outlook 2
A Need Help Urgent !!!- Add Seconde Node To The DAG Exchange Server Administration 12
M Need help w/ Calendar Events not appearing in Outlook 2010 Using Outlook 1
D Need help bulk exporting mailboxes Exchange Server Administration 3
N Need Help with Outlook 2010 Using Outlook 1
G Need help in merging data from multiple .pst data files into one .pst file. Using Outlook 3
F Incoming email titles - i need them back (please help...) Using Outlook 2
B Need help with contact recovery, since trial of Office 2010 has ended. Using Outlook 2
S OL2007/XP views will not retain settings. Really need some help here. Using Outlook 2
D Need help repairing Outlook 2010. Using Outlook 2
D Need help with word wrap in Outlook 2010. Using Outlook 5
L Windows Instant Search Indexing not working need help reading Event Log Using Outlook 2
