CAS Array Questions
DG1212
I have two question regarding CAS arrays:
1) Can a DAG and CAS array (NLB) exisit on the same Exchange 2010 SP1 server?
2) How can I make the DAG/CAS failover a manual process?
Jonas Andersson [MCITP]
1. Have been answered earlier
2. You can use DAC mode withing the DAG
http://technet.microsoft.com/en-us/library/ff625233.aspx
Copy and paste from the link above:
Enhanced Datacenter Activation Coordination Mode Support
Exchange 2010 RTM includes a configuration mode for DAG site resilience support called Datacenter Activation Coordination (DAC) mode. In DAC mode, Exchange cmdlets can be used to perform a data center switchover. In the RTM version, DAC mode is limited to DAGs with at least three members that have at least two or more members in the primary data center.
In Exchange 2010 SP1, DAC mode has been extended to support two-member DAGs that have each member in a separate data center. DAC mode support for two-member DAGs uses the witness server to provide additional arbitration. In addition, DAC mode has been extended to support DAGs that have all members deployed in a single Active Directory site, including single Active Directory sites that have been extended to multiple locations.
Jonas Andersson MCTS: Microsoft Exchange Server 2007/2010 | MCITP: EMA 2007/2010 | MCSE/MCSA Blog: http://www.testlabs.se/blog
P DNS Round Robin on CAS Array Exchange Server Administration 5
B After rebooting one of the cas array servers blackbarry stops working Exchange Server Administration 1
R cas array owa is slow Exchange Server Administration 5
T CAS Array/RPCClientAccessServer and Outlook profile experiences Exchange Server Administration 8
C Reboot a CAS array member causes Outlook 2010 clients to prompt for credentials. Using Outlook 5
K Outlook client on Exchange 2010 changes cas array name to instance-<guid> Using Outlook 21
A Why not using DAG virtual IP/fqdn for CAS array in two nodes setup? Exchange Server Administration 2
D Cas Array HA 2 sites Exchange Server Administration 15
C Watson Error on CAS Exchange Server Administration 1
S Exchange CAS server OAB directory not showing web.config file Exchange Server Administration 3
T RBAC Error on UM/CAS Servers Exchange Server Administration 2
R FQDN of Exchange CAS servers not in SSL cert Exchange Server Administration 2
D CAS Design Question Exchange Server Administration 4
D Exchange 2010 CAS at 2 different Sites Exchange Server Administration 2
T Cas server uninstall failed... Now how to reinstall? Exchange Server Administration 4
S Any system impact if change exchange 2010 CAS/HUB and Mailbox server IP address Exchange Server Administration 1
B Re: Exchange 2007 and CAS from Exchange 2010 problem Exchange Server Administration 15
M Re: Exchange 2007 and CAS from Exchange 2010 problem Exchange Server Administration 2
I Exchange 2007 and CAS from Exchange 2010 problem Exchange Server Administration 4
M CAS Issue: OWA/Outlook remote users cannot login Exchange Server Administration 1
C CAS Proxy problem Exchange Server Administration 5
K Exchange 2010 OWA redirection between 2 CAS Servers Exchange Server Administration 5
S exchange 2010 cas memory usage Exchange Server Administration 2
P Exchange 2010 SP1 Cross Site CAS connection disable Exchange Server Administration 2
H Outlook 2007 periodically disconnects from Exchange 2010 CAS - OWA works Using Outlook 4
C CAS Connections overview Exchange Server Administration 9
