Autodiscover will not work
P
parkwaytech
We've got 2 Exchange 2010 servers both running Server 2008 R2 64-bit. Each server has the HUB/Mailbox/CAS roles installed. We are load balancing through DNS round robin and use a DAG, as well. OWA works fine, and we use a GoDaddy UCC certificate with all of the domains name added to it. Outlook can be configured manually just fine. But Autodiscover fails. When I run a test from Outlook 2010, below is the result I get. I tested using another domain name that uses Autodiscover redirect (hence the lack of SRV records), but the results are the same even for our primary domain. Our DNS settings look correct on the server, so I'm not sure what is causing the issue. I'd appreciate any suggestions. Thanks for looking.
3544 1552642 11/15/10 16:52:37 Autodiscover to https://winstonemail.com/autodiscover/autodiscover.xml starting
3544 1553033 11/15/10 16:52:38 Autodiscover to https://winstonemail.com/autodiscover/autodiscover.xml Failed (0x800C8203)
3544 1553033 11/15/10 16:52:38 Autodiscover to https://autodiscover.winstonemail.com/autodiscover/autodiscover.xml starting
3544 1574113 11/15/10 16:52:59 Autodiscover to https://autodiscover.winstonemail.com/autodiscover/autodiscover.xml Failed (0x800C8203)
3544 1574113 11/15/10 16:52:59 Local autodiscover for winstonemail.com starting
3544 1574113 11/15/10 16:52:59 Local autodiscover for winstonemail.com Failed (0x8004010F)
3544 1574113 11/15/10 16:52:59 Redirect check to http://autodiscover.winstonemail.com/autodiscover/autodiscover.xml starting
3544 1574233 11/15/10 16:52:59 Autodiscover URL redirection to https://mail.watercoolersuite.com/autodiscover/autodiscover.xml
3544 1574233 11/15/10 16:52:59 Autodiscover to https://mail.watercoolersuite.com/autodiscover/autodiscover.xml starting
3544 1574594 11/15/10 16:52:59 Autodiscover XML Received
3544 1574604 11/15/10 16:52:59 Autodiscover to https://mail.watercoolersuite.com/autodiscover/autodiscover.xml Failed (0x800C8203)
3544 1574604 11/15/10 16:52:59 Srv Record lookup for http://autodiscover.winstonemail.com/autodiscover/autodiscover.xml Failed (0x800C8203)
3544 1574604 11/15/10 16:52:59 Srv Record lookup for winstonemail.com starting
3544 1574854 11/15/10 16:52:59 Srv Record lookup for winstonemail.com Failed (0x8007251D)
Brian Day MCITP
Are you aware of the pitfalls of using DNS round robin?Microsoft Premier Field Engineer, Exchange
MCSA 2000/2003, CCNA
P
parkwaytech
We sure are. We have even tried removing the other DNS records so that we are only pointing to one CAS server. No luck there either.
Justin.King
It looks like you are redirecting autodiscover.domain to mail.domain? The error code is some kind of certificate problem .... client certificate not set to ignore .... certificate name not in the UCC ...
> .. redirecting autodiscover used to always cause me all sorts of wierd problems for so long ago i stopped doing it and made sure autodiscover could resolve directly to the server... but with your error code I'd check those names closely.
if you dont have autodiscover in the cert name anywhere, try setting up an SRV record and point that at mail.domain ... I'm personally suspicious of the cert and the A records.
Justin.King
By steve's analysis I'd chekc to make sure it's set to ignore client certificates ...
P
parkwaytech
Appreciate everyone's suggestions. Here is the XML output from a test I just did.
---BEGIN XML-
<?xml version=" 1.0" encoding=" utf-8" ?>
<Autodiscover xmlns=" http://schemas.microsoft.com/exchange/autodiscover/responseschema/2006" >
<Response>
<Error Time=" 17:20:54.1485584" Id=" 2751842875" >
<ErrorCode>500</ErrorCode>
<Message>The e-mail address cannot be found.</Message>
<DebugData />
</Error>
</Response>
</Autodiscover>
----END XML----
Steve Goodman
Does it do the same thing with an email address (that's listed in EMC as an email address) for watercoolersuite.com?
Steve Goodman
P
parkwaytech
Steve,
Thanks for the reply. Here is what I get when running the Outlook autoconfiguration test with a watercoolersuite.com address:
2912 383211 11/15/10 17:41:08 Autodiscover to https://autodiscover.watercoolersuite.com/autodiscover/autodiscover.xml Failed (0x800C8203)
2912 383211 11/15/10 17:41:08 Local autodiscover for watercoolersuite.com starting
2912 383221 11/15/10 17:41:08 Local autodiscover for watercoolersuite.com Failed (0x8004010F)
2912 383221 11/15/10 17:41:08 Redirect check to http://autodiscover.watercoolersuite.com/autodiscover/autodiscover.xml starting
2912 383271 11/15/10 17:41:08 Srv Record lookup for http://autodiscover.watercoolersuite.com/autodiscover/autodiscover.xml Failed (0x80004005)
2912 383271 11/15/10 17:41:08 Srv Record lookup for watercoolersuite.com starting
2912 383271 11/15/10 17:41:08 Srv Record lookup for watercoolersuite.com Failed (0x8004010F)
I ran the Autodiscover test at testexchangeconnectivity.com and it passed.
P
parkwaytech
Steve,
Yes, it is set to ignore client certificates, and our UCC certificate has all of the domain names included in it.
Steve Goodman
Is there any more info in the XML output?
Steve Goodman
G
Gavin-Zhang
Hi Parkwaytech,
Per the information above, It seems some issue with the autodiscover service on the server. Some suggetions:
1. I would run EXBPA and confirm whether there are some information regarding to the autodiscover.
2. Then I would check the autodiscover directory through:
get-autodiscovervirtualdirectory |fl
3. I would check the scp record through the adsiedit
4. if we confirm all the previous steps all right, I would check the cert for the exchange server, using
get-exchangecertificate
5. above check would also confirm the autodiscover work well in your internal domain
6. for external users using the autodiscover, please confirm the cert SAN contains the autodiscover.domain.com, it is not recommended use other alias for it
7. check the autodiscover record could be NSLOOKUP successfully throgh the internet.
Some information for you:
http://technet.microsoft.com/en-us/library/aa995928.aspx
Regards!
Gavin
B AutoDiscover Forensics Exchange Server Administration 0
EXChange2013 Exchange 2013 AutoDiscover Tweaks? Exchange Server Administration 0
M Outlook 2007 AutoDiscover Using Outlook 0
A Exchange Autodiscover SSL issue Exchange Server Administration 7
M Initial Outlook Configuration with AutoDiscover populates wrong email address Using Outlook 5
N Outlook 2007 Clients Pointed to Wrong Domain Name for Autodiscover Using Outlook 2
K testing autodiscover and exchange coexistence Exchange Server Administration 2
C The Autodiscover service couldn't be located. Exchange Server Administration 8
C Exchange server 2010 error "The Autodiscover service couldn't be located." Exchange Server Administration 1
J Autodiscover accounts on exchange 2003 with Outloook 2010 not working Using Outlook 4
Z Autodiscover Points to defunct Exchange 2010 Server Exchange Server Administration 5
M Autodiscover not configuring Outlook Anywhere Using Outlook 10
B Autodiscover error 0x800c8203 and encrypted connection is not available Exchange Server Administration 3
P Autodiscover URLs Exchange Server Administration 15
C Autodiscover Exchange Server Administration 6
I Exchange 2010 Profile AutoDiscover not working for some users Exchange Server Administration 1
S Exhcange 2010 autodiscover virtual directory Exchange Server Administration 4
D External Autodiscover Exchange Server Administration 3
S Exchange 2010 Autodiscover Problems, cannot connect Outlook clients using Autodiscover / Outlook Any Exchange Server Administration 4
G Exchange 2010/Outlook 2007 Can't get autodiscover to work for some users, but others work fine Exchange Server Administration 3
S Autodiscover issue Exchange 2007 Using Outlook 4
K Exchange 2010 Autodiscover Exchange Server Administration 1
P Autodiscover fails (Exchange 2010) Exchange Server Administration 7
P Autodiscover issues on Exchange 2010 Exchange Server Administration 7
S Exchange 2010 Outlook 2010 Autodiscover fails Exchange Server Administration 22
C Getting Autodiscover to work with other web servers ... Using Outlook 4
C Autodiscover Service Configuration Exchange Server Administration 5
B move mailbox- autodiscover Exchange Server Administration 25
T Autodiscover authentication Exchange Server Administration 2
A autodiscover issue with OL2010 but no issue with OL2007 Exchange Server Administration 10
K Autodiscover and SRV records Using Outlook 10
S Autodiscover redirected Using Outlook 2
C Autodiscover Exchange Server Administration 5
S Autodiscover two AD sites two cas arrays Exchange Server Administration 4
O Autodiscover Exchange Server Administration 4
S Autodiscover FQDN certificate for secondary domain email? Exchange Server Administration 1
K Remove AlternativeMailbox - Autodiscover Exchange Server Administration 5
S Exchange 2010 autodiscover Exchange Server Administration 4
R Autodiscover virtual directory - recreation fails Exchange Server Administration 1
A share one record for autodiscover between exch 2007 and exch 2010 Exchange Server Administration 4
O SSL certificate needed for autodiscover.domain.com Exchange Server Administration 12
C Windows 7/Outlook 2010 vs Windows XP/Outlook 2007 - Autodiscover authentication looping Using Outlook 1
