Exchange 2010/Outlook 2007 Can't get autodiscover to work for some users, but others work fine
G
Geekgrrl570
I have Exchange 2010 Version: 14.01.0218.013 running on Windows 2008 R2. All computers are in the domain and all are local to the Exchange server. We have a couple users that can't download the OAB. This is in their sync logs:
10:24:19 Microsoft Exchange offline address book
10:24:19 Not downloading Offline address book files. A server (URL) could not be located.
10:24:19 0X8004010F
I tested autodiscover on one users machine and compared it with a user that is working, identical OS (Win7) and Outlook version. I used the test autoconfiguration check from the outlook task tray icon and the user that is not working finds the SCP, and gets the proper URL but can't connect to it to get the xml file. The system that works pulls down the same url and it works fine.
I tested the user that isn't working on another machine and got the same error, which leads me to believe that it may be some kind of permissions issue with their account, but we have roaming profiles so I can't tell if it's that or not. If I log into the users machine that doesn't work using my credentials and getting my profile, it again works fine, so it's not just the system.
I tested the non working user account in EMS with test-outlookwebservices -identity user@corp.com and all tests succeeded.
Since it works for other identical users, it can't be that autodiscover is not configured correctly. Other than recreating the users profile and testing that, I can't figure out what else to do. This users profile is pretty big and if I can I would rather not have to create a new profile for them.
Any ideas?
P Outlook 2010 MS Exchange Calendar to Android- ical or webdav? Using Outlook 1
Fozzie Bear Outlook 2010 or 2013 Dual Configuration Exchange + IMAP Exchange Server Administration 6
N Outlook 2010 exchange - auto-move emails from @domain Exchange Server Administration 1
V Outlook 2013 cant stay connected to exchange 2010 Exchange Server Administration 5
R Exchange 2013/Outlook 2010 Slow Startups Exchange Server Administration 8
Z Outlook 2010 client to Exchange ,,,,search not working proparly Exchange Server Administration 0
M First post -help with managing two calendars Outlook 2010 /Exchange 2010 Using Outlook 0
T Outlook INBOX emails gone back 2-3 weeks after Exchange Server 2010 Restart Using Outlook 0
C Outlook 2010, two exchange mailboxes configured.Unable to see 2ndrymeeting req Using Outlook 2
B Sharing Multiple Outlook 2010 Calendars (Exchange) Exchange Server Administration 4
B Using hosted exchange to sync outlook 2010 calendars and contacts to BB Z10 Using Outlook 4
S Outlook 2010/Exchange 2010 Multi Mailboxes (Server unavailable) Using Outlook 6
D why do exchange contacts not sync properly from outlook 2011 to outlook 2010 Exchange Server Administration 2
C Exchange 2010 - Outlook 2010 - Exchange Server Administration 4
Fozzie Bear Outlook 2010 wont remember Exchange Credentials on log off /shutdown of Win7 Exchange Server Administration 2
I Shared Contacts in Outlook 2010 and Exchange Server 2010 Using Outlook 4
B Outlook 2010 won't configure exchange account, 0kb .ost file Exchange Server Administration 5
R Thousand of sync issues on Outlook clients with Exchange 2010 Exchange Server Administration 5
T Exchange / Outlook 2010 - How to cancel meetings but retain the calendar entry Using Outlook 4
S Outlook Quick Steps - Exchange 2003 / Exchange 2010 Exchange Server Administration 2
A Exchange 2010 Outlook 2010 and Local Failures sync issue Exchange Server Administration 5
B Exchange 2010 / Outlook 2010 - Group Folder issues Exchange Server Administration 6
T Outlook 2010/Exchange 2003: Meeting Organizer doesn't show Using Outlook 1
C Outlook/Exchange 2010 Recover Deleted Items to original folder Using Outlook 2
R Change Outlook 2010 Exchange server address via registry or script Using Outlook 5
T Outlook 2010 Mutliple Exchange Accounts SET UP QUESTIONS Using Outlook 4
M How to Configure Multiple Exchange Accounts in Outlook 2010 Using Outlook 2
M Outlook 2010 stopped connecting with Exchange server Using Outlook 1
S New Outlook 2003 Clients with Existing Exchange 2010 error's Exchange Server Administration 6
N Exchange 2010 RPC Over HTTPS, outlook keep trying port 135 Exchange Server Administration 9
E Outlook 2010 stopped work with Exchange 2010 Exchange Server Administration 1
T How to Assign Retention Tags for Notes Items in Exchange/Outlook 2010? Exchange Server Administration 0
J Exchange 2010 + Disable ActiveSync/Outlook Anywhere/POP/IMAP/ By Default Exchange Server Administration 5
B Outlook 2007 New email notification works intermittently after adding Exchange 2010 Servers Exchange Server Administration 1
M Outlook 2010-Sync with Exchange server 2007 Using Outlook 2
S Exchange 2010 outlook 2010 outlook anywhere cached mode Exchange Server Administration 2
J Suggested times does not work with Outlook 2010 in combination with Exchange 2007 SP2? Using Outlook 2
M Outlook 2010 Connectivity with Exchange 2007 Using Outlook 5
M Outlook 2010 auto setup of Exchange account Using Outlook 1
O No SSL-IMAP connection Outlook <-> Exchange 2010 after latest client updates? Using Outlook 3
A outlook 2010, windows 7, exchange server: "The action cannot be completed. The connection to Micro Using Outlook 1
M Outlook 2010 Connectivity with exchange server 2007 Using Outlook 1
