CAS Array and Outlook 2003 clients
BGM2
I read where the settings in Outlook should be set to either Negotiate Authentication or NTLM and not Kerberos if you are going to use a CAS Array. For Outlook 2007 and 2010 this doesn't seem to be an issue since the default seems to be Negotiate.
In Outlook 2003 SP3 I have 3 possible settings:
Kerberos / NTLM Password Authentication
Kerberos Password Authentication
Password Authentication (NTLM)
If I'm going to use a CAS Array but still have Outlook 2003 clients is Kerberos Password Authentication the only security setting I cannot use?
MMHussain
Hello
Use NTLM authentication for Outlook 2003 and also make sure that Encryption must be enabled in the Outlook profile.
Under the Outlook Profile, choose “more settings” and then choose the Security tab.
Make sure “Enable encryption between Outlook and the Exchange Server” is Connected.
Thanks Mhussain
BGM2
Knew about the encryption and already setup a GPO but didn't know about the authentication method.
BGM2
Okay so looking at this article it appears for Outlook 2003 clients the keberos / NTLM authentication setting is ok. Please let me know if I'm mistaken?
Allen Song
That's indeed the problem. Before Exchange 2010 SP1, the CASARRAY could not work with the kerbose. This is because when Client Access Servers are load balanced, clients are not aware of individual server names. As a result, the mail clients request as a array name.
On the CAS server, the Exchange services run in the local system or network service and authenticate the kerbose in their own account, not the array account. This causes a mismatch and leads to Kerberos authentication failure.
A good news is the SP1 can make this work. You can refer to the below article:
http://technet.microsoft.com/en-us/library/ff808312.aspx
Allen
Allen Song
S Created CAS Array - Outlook certificate error Exchange Server Administration 2
R CAS array not working with Outlook Exchange Server Administration 15
T CAS Array/RPCClientAccessServer and Outlook profile experiences Exchange Server Administration 8
C Reboot a CAS array member causes Outlook 2010 clients to prompt for credentials. Using Outlook 5
K Outlook client on Exchange 2010 changes cas array name to instance-<guid> Using Outlook 21
P DNS Round Robin on CAS Array Exchange Server Administration 5
B After rebooting one of the cas array servers blackbarry stops working Exchange Server Administration 1
B cas array exchnage 2010 not working properly on vm Exchange Server Administration 5
S One CAS Array for mulitple site Exchange Server Administration 2
S CAS Array - NLB - Can't Ping VIP Exchange Server Administration 4
R accessing owa externally and having a cas array internally Exchange Server Administration 9
K CAS array SSL cert -RPC cas certificate warning Exchange Server Administration 3
S What to Use Instead a Hardware-based Load Balancer for an Exchange 2010 CAS Array Exchange Server Administration 21
R cas array owa is slow Exchange Server Administration 5
S Exchange 2010 two datacenters two CAS array Exchange Server Administration 4
B Do we need to create a CAS Array for a single server site? Exchange Server Administration 3
M CAS Array Exchange Server Administration 6
R Installing SP1 on Hub/CAS servers in CAS Array Exchange Server Administration 9
B CAS Array article...? Exchange Server Administration 2
C Cas array question Exchange Server Administration 12
T Rename CAS array Exchange Server Administration 4
S CAS array legacy URL Exchange Server Administration 9
S CAS array in exchange 2003 and exchange 2010 coexsit environment Exchange Server Administration 4
B CAS Array with Hardware Load Balancers Exchange Server Administration 6
A Why not using DAG virtual IP/fqdn for CAS array in two nodes setup? Exchange Server Administration 2
D Cas Array HA 2 sites Exchange Server Administration 15
T CAS array and kerberos authentication to RPC client access service Exchange Server Administration 15
C Watson Error on CAS Exchange Server Administration 1
S Exchange CAS server OAB directory not showing web.config file Exchange Server Administration 3
T RBAC Error on UM/CAS Servers Exchange Server Administration 2
