Public Folders Not Replicating Between Exchange 2007 and 2010 (Migrate/Transitioning 2007 to 2010)
  • Thread starter Migration xchange 07 to 2010 Public folder issue
  • Start date
I open the Public folder consol through Exchange emc. Select my xchange 2007 server>Public Folders>Default Public Folder>Properties>Replication>add the exchange2010 pf database> i face following error i just enter the 2/3 lines only
the following error(s) occurred while saving changes:
Set-publicfolder -----------Failed
Error:
Cannot sae the object \namethefolder" Make sure that you specified the correct Identity and that you have the necessary permissions to save it.
MapiExceptionNotFound: Unable to set properties on object
(hr=0x8004010f, ec=2147221233)
Dignostic Context:
Lid: 45095.EcDoRpcExt2 Called{lenght=317
P
Paul Cunningham
On the Exchange 2010 server open the Exchange Management Console and navigate to <drive where Exchange is installed>:\Program Files\Microsoft\Exchange Server\V14\Scripts
The Powershell script " AddReplicatoPFRecursive.ps1" lets you add the new server as a replica to some or all of the Public Folders in your tree.
For example this command will ad the new server as a replica for all public folders.
> \AddReplicatoPFRecursive.ps1 -TopPublicFolder -ServertoAdd <Exchange 2010 Server>
Be aware this can take some time to complete depending on the number of public folders you have. It can also generate a lot of disk IO on the source and destination servers, as well as a lot of transaction logging on the destination server (so watch your free disk space closely).
Paul Cunningham (MCITP) Get more Exchange tips and tutorials at: http://exchangeserverpro.com
Thanks your reply, i already run this script and face this problem.
d:\program files\microsoft\exchange server\v14\scripts>.\AddreplicatoPFRecursive.ps1 -TopPublicFolder -ServertoAdd <server name for 2010>
Error Show after run this script.
Cannot save the object ,\pf name' Make sure that you specified the correct identity and that you have the necessary permissions to save it.
+ CategoryInfo : NotSpecified: <0:Int32> [Set-PublicFolder], MapiObjectNotFoundException
+ FullyQualifiedErrorId : 9fA31BCF, Microsoft.Exchange.Management.MapiTasks.SetPublicFolder
+ FullyQualifiedErrorId : 614EE0D1, Microsoft.Exchange.Management.MapiTasks.SetPublicFolder
Cannot save the object ,\pf name' &ndash;Migration, .Make sure that you specified the correct identity and that you have the necessary permissions to save it.
+ FullyQualifiedErrorId :, BA79DF9C, Microsoft.Exchange.Management.MapiTasks.SetPublicFolder
Note:I am using my domain admin login and also add all exchange 2010 group as member.
N
Novak Wu
To troubleshoot the issue, please perform the following steps.
1. Please open Queue Viewer and verify whether there is any failed message in Queue. If so, please clear it.
2. Install Service Pack 1 on Exchange 2010.
3. Please refer to the following article to increase the logging level for Replication and upload the Event Log to Skydrive (www.skydrive.live.com) for research.
http://blogs.technet.com/b/ferris/archive/2010/05/03/howto-increase-the-logging-levels-in-exchange-2003-2007-and-2010.aspx
Novak Wu
Thanks for your reply; i already update exchange sp1 before migration. and there is no message in Queue viewer 2010 and 2007. And i try to access this site they not work (www.skydrive.live.com)
Please advise me the next step.
Regards,
Imran Nawaz
N
Novak Wu
I'm sorry for delay. Alternatively, please just send the log file to me directly. I will be glad to assist you to analysis the error message.
Hi Novak,
i email you please reply my email.
regards.
I Public Folders not replicating between Ex 2003 and Ex 2010 Exchange Server Administration 7
C Outlook 2016: Searching in all (+public) folders Outlook VBA and Custom Forms 9
L Public folders permissions Exchange Server Administration 1
Diane Poremsky Mail-enable Exchange Public Folders New Slipstick.com Articles 0
J Favorites in Public Folders issue Outlook VBA and Custom Forms 0
V Macro to open Public Folders subfolder? Outlook VBA and Custom Forms 1
M Codetwo Public Folders structure for vba Outlook VBA and Custom Forms 13
E Outlook 2007 Saves .MSG E-Mails with attachment from Public Folders as RTF Using Outlook 0
C How do I share/post my calendar to public folders Exchange Server Administration 3
T managing contacts in public folders Using Outlook 4
C Custom form with custom colour category visible to all users in public folders Using Outlook 1
L Public folders suddenly gone in outlook 2k7 Using Outlook 1
K Clearing/Deleting all Public Folders through VBA Using Outlook 3
J Change the subject line of messages in public folders Using Outlook 3
J Public folders woes (script to change subject line of messages) Exchange Server Administration 0
B Initial "Connecting" to public folders on startup Using Outlook 8
Z update individuals in public folders Outlook Wishlist 1
Z update individuals in public folders Exchange Server Administration 1
B Permissions - Outlook Public Folders Are Being Deleted Using Outlook 1
R public folders Using Outlook 2
T Public folders in outlook 2010 Using Outlook 1
R Change Public Folders Label in Folder List Using Outlook 1
B Public Folders Replica(s) - is there only one if there are multiple sites? Exchange Server Administration 6
V Uninstall ONLY Exchange 2010 but leave Exchange 2003 server in place - Public Folders Question Exchange Server Administration 5
I outlook unable to view public folders and autodiscovery not working Using Outlook 1
H Exchange 2003 to 2010 Transition, Public Folders Exchange Server Administration 2
R Unable to use Public Folders on Exchange 2007 via OLK2007 Using Outlook 2
J Why did the relative root path of the Exchange public folders change from \\Public Folders\All Publi Exchange Server Administration 1
S auto move mails from mailboxes to public folders Exchange Server Administration 6
T Exchange 2010 Public Folders Database Size Discrepancy Exchange Server Administration 4
B Searching across public folders in EXCHANGE 2007 Exchange Server Administration 2
A Are Public Folders Contacts available through activesync for Windows Phone 7, Iphone, etc? Exchange Server Administration 3
P Outlook 2011 Does not Sync Public Folders (Exchange 2007) Using Outlook 2
J Public Folders: Outlook 2007 gets "The set of folder could not be opened. The attempt to log on to M Using Outlook 2
Y Cannot open the Public Folders aftering installing Security Updates 2288953 Using Outlook 5
J Unable to access public folders in Outlook 2007 on Exchange 2010. OWA PF works fine Using Outlook 7
A Mark all as read for public folders Using Outlook 14
D Exchange 2010 Restore Public Folders? Exchange Server Administration 3
R Can BCM use Public Folders and Exchange for multi-user/ BCM (Business Contact Manager) 1
F Open task from is own status report in Public Folders Outlook VBA and Custom Forms 3
U Drops filters for published views in public folders.Inserts DASL Outlook VBA and Custom Forms 1
M Moving folders within Public Folders Outlook VBA and Custom Forms 1
A Created a personal group that now appears to be a public group Using Outlook 3
