Exchange 2010 SP1 Cross Site CAS connection disable
P
PPATIL
Exchange 2010 SP1 (Single DAG spread across two AD Sites).
i believe in SP1, by default a CAS in one site allows Outlook to use them to connect to a DB in a different site. I believe there is a way to disable this functionality and force Outlook to connect to a CAS in the site where DB is active.
I can't seem to find how to disable the CAS cross site database connectivity option. Some articles refer to this being a function of activation preference but not sure what that means.
Question - how do i configure CAS (or a CAS Array) to NOT allow connections to a DB in a different site?
TIA
Prakash
Brian Day MCITP
You can't, this functionality didn't make the SP1 RTM cut. If you see it in any documentation it can be ignored.Microsoft Premier Field Engineer, Exchange
MCSA 2000/2003, CCNA
P
PPATIL
ok. Do you know if this is functionality is planned / scheduled at all ? (SP2 or other updates)
Prakash
K Backup recommendation for Exchange 2010 SP1 on Hyperv 2008 R2 Exchange Server Administration 3
F AD RMS with Exchange 2010 SP1 Exchange Server Administration 4
D Exchange Server 2010 SP1 Hosted Mode, service@ mailbox creation Exchange Server Administration 1
I Event ID 2937 after update to Exchange 2010 SP1 ArbitrationMailbox Exchange Server Administration 4
M Exchange 2010 SP1 Hosted Mode - how to move mailbox from old organization? Exchange Server Administration 1
P Journaling deployment Exchange 2010 SP1 RU1 Exchange Server Administration 1
I Event ID 2937 after update to Exchange 2010 SP1 Exchange Server Administration 8
G Exchange 2010 upgrade with SP1, language pack issue Exchange Server Administration 5
R Dynamic DNS update requirement for Exchange 2010 (SP1 RU1) on server 2008 r2 Exchange Server Administration 8
A NetBackup 7.0 configuration for Exchange 2010 SP1 Exchange Server Administration 3
D Exchange 2010 SP1 OWA "reply" or "forward" error Exchange Server Administration 3
K Question about Exchange 2010 SP1 RU2 update Exchange Server Administration 3
J Exchange 2010 SP1 fails at Mailbox Error Unable to load exrpc32.dll Exchange Server Administration 4
D Exchange 2010 SP1 Policy to Delete mail in deleted items older than 30 days Exchange Server Administration 2
à Validating build of Exchange 2010 SP1 Exchange Server Administration 1
D Exchange 2010 SP1 topology prep error Exchange Server Administration 3
I Exchange 2010 sp1 Address Book service won't start after static RPC port reconfiguration Exchange Server Administration 2
D Installing SP1 for Exchange 2010 Exchange Server Administration 2
B Blank email list views on Outlook 2010 / 2007 with Exchange 2010 SP1 (on Citrix and Desktops) Using Outlook 7
S Exchange 2010 SP1 OWA Error Exchange Server Administration 2
P Mircrosoft Exchange 2010 SP1 Email Purge Exchange Server Administration 2
P Error 4999 after Exchange 2010 SP1 - No BES server Exchange Server Administration 12
D Upgraded to Exchange 2010 SP1 and now random Outlook clients are requesting authentication Exchange Server Administration 1
Q Don't have right permissions to assign "send as" rights in Exchange 2010 SP1 Exchange Server Administration 7
M Exchange 2010 SP1 Event id 9040 : Unable to save watermarks Exchange Server Administration 5
C Exchange 2010 SP1 "RPC can't be started because of the EMSMDB interface is already registered by Exchange Server Administration 4
N Failed Exchange 2010 SP1 Installation PowerShell "unauthorized operation" Exchange Server Administration 2
L Does Exchange 2010 SP1 update any Schema objects Exchange Server Administration 2
T After updating Exchange 2010 from RTM to SP1, OWA clients cannot move or delete emails Using Outlook 4
A Exchange 2010 SP1 RU1 Calendar Retention Exchange Server Administration 1
M Do Database Storage Limits in Exchange 2010 SP1 affect Archive mailboxes? Exchange Server Administration 5
L Exchange 2010 SP1 Pre-Req error Exchange Server Administration 2
W Exchange 2010 SP1 Install- Required HotFixes Exchange Server Administration 3
N Second Mailbox, Mails stuck in Outbox Outlook 2010, Exchange 2010 SP1 Using Outlook 8
S Determine Managed Folder Policy for Mailbox in Powershell Exchange 2010 SP1 Exchange Server Administration 4
C Installing Exchange 2010 SP1 in a Sub domain... Exchange Server Administration 5
K Exchange 2010 SP1 RU1 - Get-PublicFolderDatabase bug / documentation issue? Exchange Server Administration 6
D Ms Exchange 2010 - Sp1 Upgrade at Prerequisites on Hub Transport Role Exchange Server Administration 8
C Managed Folder does not show up in Outlook in Exchange 2010 Sp1 Rollup 1 Exchange Server Administration 3
J After Applying Exchange 2010 Sp1 Rollup the Build numbers in EMC remain unchanged 14.1.218.15 Exchange Server Administration 1
M how to upgrade exchange 2010 to exchange 2010 sp1 Exchange Server Administration 2
J Mailbox Export Import issue on Exchange 2010 SP1 Exchange Server Administration 4
