Exchange 2010 / 2003 OWA Problem
Junaid Saeed Uppal
Hi All,
I have just configured the first Exchange 2010 server in my envoirnment -
I currently have Exchange 2003 running as a primary server. The problem is that - when i try to logon to OWA using 2010 hosted mailbox - it works perfectly fine - and i can logon as well , but when i try to login using a mailbox hosted on 2003 server - it gives me the following error
" Your request couldn't be completed because no server with the correct security settings was found to handle the request. If the problem continues, contact your helpdesk."
I tried setting up the Set-OWAVirtualDirectory as well but i get the following answer
" [PS] C:\Windows\system32>Set-OWAVirtualDirectory MERCURY\OWA* -Exchange2003URL http://mail1.afghan-wireless.com/exchange WARNING: The command completed successfully but no settings of 'MERCURY\owa (Default Web Site)' have been modified. [PS] C:\Windows\system32>"
Looking forward for the reply.
Busbar [MVP]
N
Novak Wu
Please ensure that you have FBA enabled on front-end and CAS server and you have publish the legacy URL with proper certificate installed.
For more information, please refer to the following article:
http://technet.microsoft.com/en-us/library/ee332348.aspx
If the issue persists, please check whether there is any error message in Event Viewer when trying to open OWA. Also, please type the cmdlet Get-OWAVirtualDirectory |fl and post the results here.
S Outlook Quick Steps - Exchange 2003 / Exchange 2010 Exchange Server Administration 2
T Outlook 2010/Exchange 2003: Meeting Organizer doesn't show Using Outlook 1
B Move mailbox from Exchange 2003 to 2010 Exchange Server Administration 2
S New Outlook 2003 Clients with Existing Exchange 2010 error's Exchange Server Administration 6
V Uninstall ONLY Exchange 2010 but leave Exchange 2003 server in place - Public Folders Question Exchange Server Administration 5
S exchange 2003 org to exchange 2010 org Exchange Server Administration 2
A OWA redirection in exchange 2010 and 2003 Exchange Server Administration 1
H Exchange 2003 to 2010 Transition, Public Folders Exchange Server Administration 2
K exchange 2010 OWA and exchange 2003 coexist Exchange Server Administration 1
A I have purchased a replacement computer and installed Outlook 2010. My server is a 2003 small business exchange server. How can I access the calenda Using Outlook 1
M Exchange 2010 Outlook Web App via Exchange 2003 Front End Server Exchange Server Administration 1
J Exchange server 2003 to 2010 Exchange Server Administration 1
L Exchange 2003 to 2010 Migration - Public Folder Replication Failed - Busy/Free Issue Exchange Server Administration 8
D Outlook 2003 is getting an error when trying to open an exchange 2010 mailbox Exchange Server Administration 5
D Unable to search contacts in Outlook 2003 - Exchange 2010 Using Outlook 2
J Understanding Exchange 2010 <-> Exchange 2003 Connectors....help... Exchange Server Administration 4
W Outlook 2010 Free/Busy Data not updated\viewable - Exchange 2003 SP2 Using Outlook 2
D Exchange 2003 to Exchange 2010 mail stuck in Exchange 2003 Local Delivery Queue Exchange Server Administration 10
S garbage mail recieved from Exchange 2010 HUB to Exchange 2003 user. Exchange Server Administration 2
I Copying mailboxes from Exchange 2003 to Exchange 2010 Exchange Server Administration 3
J Autodiscover accounts on exchange 2003 with Outloook 2010 not working Using Outlook 4
J Migration Exchange 2003 to 2010: OUT OFFICE ISSUE Exchange Server Administration 8
B Exchange 2003 -> 2010 Issues + Public Folder Issues Exchange Server Administration 9
B Outlook 2010 unable to connect to a remote Microsoft Exchange 2003 server Using Outlook 8
M Exchange 2010 and 2003 Public folder replication Exchange Server Administration 16
G Outlook 2003 displaying x400 instead of E-mail address when viewing Exchange 2010 GAL Exchange Server Administration 6
M Upgrading Exchange 2010 from 2003 can send email, but cannot receive Exchange Server Administration 5
M migrate from exchange 2003 to 2010 Exchange Server Administration 6
R Outlook 2003 - Exchange 2010 global address list not updating Using Outlook 3
F Exchange 2003 to Exchange 2010 Public Folder Replica Pains Exchange Server Administration 14
M Exchange 2010 cannot see free/busy for Exchange 2003 mailboxes Exchange Server Administration 15
R OAB generation on Exchange 2010 within a Coexistence 2003/2010 Exchange Server Administration 13
G exchange 2010 and 2003 co-existence Exchange Server Administration 12
J Exchange 2003 to Exchange 2010 migration. Public folder permission issues Exchange Server Administration 7
J SBS 2003 Migration to Server 2008 R2 &amp; Exchange 2010 Exchange Server Administration 10
B Outlook 2003 and Exchange 2010 Exchange Server Administration 3
Diane Poremsky Organizational Forms Library in Exchange 2010 New Slipstick.com Articles 0
V Recover exchange 2010 edb Exchange Server Administration 2
T Renaming an Resource in Exchange 2010 Exchange Server Administration 1
P Outlook 2010 MS Exchange Calendar to Android- ical or webdav? Using Outlook 1
Fozzie Bear Outlook 2010 or 2013 Dual Configuration Exchange + IMAP Exchange Server Administration 6
H In Exchange 2010, how to block an email containing an attachment that has foreign characters Exchange Server Administration 1
