Why does Outlook 2007 generate 3 events for 1 single "Add"?
C
cGtlbGxleQ
Using Windows XP, running Outlook 2007, C#, Visual Studio 2005 with VSTO SE.
I have an Outlook AddIn that monitors calendar Appointments.
The AddIn is working great, but I've noticed a strange anomoly:
If I add a NEW Appointment, I expect to that my "Calendar_ItemAdd" event
handler will fire (only once).
If I change an EXISTING Appointment, I expect that my
"Calendar_ItemChange" event handler will fire (only once).
Real Behavior:
If I add a NEW Appointment, my "Calendar_ItemAdd" event handler fires (as
expected), but then my "Calendar_ItemChange" event fires 15 seconds later,
and then my "Calendar_ItemChange" event fires AGAIN, another 15 seconds later.
I'm confused. Why is Outlook 2007 calling my "Calendar_ItemChange" event
handler, when I create a single, NEW Appointment?
Here's the code that monitors the "OlDefaultFolders.olFolderCalendar" folder:
public class CalendarMonitor
private NameSpace m_session;
private List<string> m_folderPaths;
private List<MAPIFolder> m_calendarFolders;
private List<Items> m_calendarItems;
private List<Items> m_deletedItems;
private MAPIFolder m_deletedItemsFolder;
private MAPIFolder m_calFolder;
public event EventHandler<EventArgs<AppointmentItem>
AppointmentAdded;
AppointmentModified;
public event EventHandler<CancelEventArgs<AppointmentItem>
AppointmentDeleting;
// Constructor
public CalendarMonitor(NameSpace session)
m_folderPaths = new List<string>();
m_calendarFolders = new List<MAPIFolder>();
m_calendarItems = new List<Items>();
m_deletedItems = new List<Items>();
m_session = session;
m_deletedItemsFolder =
session.GetDefaultFolder(OlDefaultFolders.olFolderDeletedItems);
m_calFolder =
session.GetDefaultFolder(OlDefaultFolders.olFolderCalendar);
HookupDefaultCalendarEvents();
} // End constructor CalendarMonitor()
public void Shutdown()
UnhookCalendarEvents();
m_folderPaths.Clear();
m_folderPaths = null;
m_calendarFolders.Clear();
m_calendarFolders = null;
m_calendarItems.Clear();
m_calendarItems = null;
m_deletedItems.Clear();
m_deletedItems = null;
m_session = null;
m_deletedItemsFolder = null;
m_calFolder = null;
AppointmentAdded = null;
AppointmentModified = null;
AppointmentDeleting = null;
} // End Shutdown()
private void HookupDefaultCalendarEvents()
if ((m_calFolder != null) && (m_deletedItemsFolder != null))
HookupCalendarEvents();
} // End HookupDefaultCalendarEvents()
private void HookupCalendarEvents()
if (m_calFolder.DefaultItemType != OlItemType.olAppointmentItem)
throw new ArgumentException("The MAPIFolder 'm_calFolder'
must use AppointmentItems as the default type.");
// Check for duplicate entries. Helps prevent double-ups on
event listeners.
if (m_folderPaths.Contains(m_calFolder.FolderPath) == false)
Items items = m_calFolder.Items;
m_folderPaths.Add(m_calFolder.FolderPath);
Items delItems = m_deletedItemsFolder.Items;
// Storing a reference to the folder and to the items
collection
// keeps folder alive. This keeps the ref count up and
prevents
// the problem of intermittent release of the COM object due
to
// garbage collection, which in turn causes events to NOT
fire.
m_calendarFolders.Add(m_calFolder);
m_calendarItems.Add(items);
m_deletedItems.Add(delItems);
// Now add event listeners.
items.ItemChange +=
new
ItemsEvents_ItemChangeEventHandler(Calendar_ItemChange);
items.ItemAdd +=
new ItemsEvents_ItemAddEventHandler(Calendar_ItemAdd);
delItems.ItemAdd +=
new ItemsEvents_ItemAddEventHandler(Calendar_ItemDelete);
private void UnhookCalendarEvents()
foreach (Items curItem in m_calendarItems)
curItem.ItemChange -=
new
curItem.ItemAdd -=
foreach (Items curItem in m_deletedItems)
curItem.ItemAdd -=
private void Calendar_ItemAdd(object item)
if (item is AppointmentItem)
// Verify that our event handler is defined.
if (this.AppointmentAdded != null)
// Notify "Add" event listener.
this.AppointmentAdded(this,
new
EventArgs<AppointmentItem>((AppointmentItem)item));
private void Calendar_ItemChange(object item)
if (this.AppointmentModified != null)
// Notify "Modify" event listener.
this.AppointmentModified(this,
new
private void Calendar_ItemDelete(object item)
if (this.AppointmentDeleting != null)
CancelEventArgs<AppointmentItem> args =
new
CancelEventArgs<AppointmentItem>((AppointmentItem)item);
this.AppointmentDeleting(this, args);
} // End class CalendarMonitor
public class EventArgs<T> : EventArgs
private T m_value;
public EventArgs(T aValue)
m_value = aValue;
public T Value
get { return m_value; }
set { m_value = value; }
K
Ken Slovak - [MVP - Outlook]
Your Delete signature is incorrect, no item is passed to tell you what was
deleted.
What exactly is being done when ItemAdd fires, are you doing anything with
that item and its properties?
"pkelley" <pkelley> wrote in message
news:F78BEA67-B35A-4F8B-B01F-986C5D8131AA@microsoft.com...
> SE.
> Real Behavior:
> (as
> later.
> folder:
> AppointmentAdded;
> // Constructor
> m_calFolder =
> m_session = null;
> m_calFolder = null;
> } // End Shutdown()
> event listeners.
> collection
> prevents
> due
> to
> fire.
> items.ItemChange +=
> new
> items.ItemAdd +=
> delItems.ItemAdd +=
> new
> new
> curItem.ItemAdd -=
> curItem.ItemAdd -=
> new
> new
> new
> new
> private T m_value;
> m_value = aValue;
> public T Value
Dmitry Streblechenko
Why are you suprised? Something modifies an item after it is created...
Dmitry Streblechenko (MVP)
> SE.
> Real Behavior:
> (as
> later.
> folder:
> AppointmentAdded;
> // Constructor
> m_calFolder =
> m_session = null;
> m_calFolder = null;
> } // End Shutdown()
> event listeners.
> collection
> prevents
> due
> to
> fire.
> items.ItemChange +=
> new
> items.ItemAdd +=
> delItems.ItemAdd +=
> new
> new
> curItem.ItemAdd -=
> curItem.ItemAdd -=
> new
> new
> new
> new
> private T m_value;
> m_value = aValue;
> public T Value
C
cGtlbGxleQ
With regard to Delete:
In the constructor method "CalendarMonitor" I get a handle to the deleted
items folder.
Then in "HookupCalendarEvents()" I'm trying to handle the ItemAdd event of
the deleted
items folder so whenever an item is moved to the deleted items folder the
"Calendar_ItemDelete" event
handler fires and "Calendar_ItemDelete" is passed the item added to the
delete folder.
Also, in the constructor "CalendarMonitor" I get a handle to the calendar
folder.
Then in "HookupCalendarEvents()" I handle the ItemAdd and ItemChange events
of the calendar
folder.
In all three cases, Calendar_ItemChange, Calendar_ItemAdd,
Calendar_ItemDelete seem to receive
the proper Item for processing. Do you still see something I'm missing? If
yes, what would you
do to handle the ItemAdd event to the deleted items folder?
With regard to the ItemAdd Event, the Event Handlers are in my "ThisAddIn"
class:
public partial class ThisAddIn
#region Instance Variables
private Outlook.Inspectors m_Inspectors; // Outlook
inspectors collection
private Outlook.NameSpace m_nameSpace;
internal static List<OutlookInspector> m_Windows; // List of tracked
inspector windows
internal static Office.IRibbonUI m_Ribbon; // Ribbon UI
reference
private CalendarMonitor m_monitor; // Calendar
appointment events.
private Outlook.AppointmentItem m_olAppointment;
#endregion
#region VSTO Startup and Shutdown methods
private void ThisAddIn_Startup(object sender, System.EventArgs e)
// Initialize variables
m_Inspectors = this.Application.Inspectors;
m_nameSpace = this.Application.GetNamespace("MAPI");
m_Windows = new List<OutlookInspector>();
m_monitor = new CalendarMonitor(this.Application.Session);
// Wire up event handlers
m_monitor.AppointmentAdded +=
new
EventHandler<EventArgs<Microsoft.Office.Interop.Outlook.AppointmentItem>>(Monitor_AppointmentAdded);
m_monitor.AppointmentDeleting +=
new
EventHandler<CancelEventArgs<Microsoft.Office.Interop.Outlook.AppointmentItem>>(Monitor_AppointmentDeleting);
m_monitor.AppointmentModified +=
new
EventHandler<EventArgs<Microsoft.Office.Interop.Outlook.AppointmentItem>>(Monitor_AppointmentModified);
m_Inspectors.NewInspector +=
new
Outlook.InspectorsEvents_NewInspectorEventHandler(Inspectors_NewInspector);
private void ThisAddIn_Shutdown(object sender, System.EventArgs e)
// Unhook event handlers
if (m_odbcForm != null)
m_odbcForm.ODBCConnectionStatus -=
new
EventHandler<EventArgs<bool>>(SetODBCConnectionStatus);
m_monitor.AppointmentAdded -=
new
m_monitor.AppointmentDeleting -=
new
m_monitor.AppointmentModified -=
new
m_monitor.Shutdown();
m_odbcForm.FormShutdown();
m_Inspectors.NewInspector -= new
Microsoft.Office.Interop.Outlook.InspectorsEvents_NewInspectorEventHandler(Inspectors_NewInspector);
// Dereference objects
m_Inspectors = null;
m_Windows.Clear();
m_Windows = null;
m_Ribbon = null;
m_nameSpace = null;
m_monitor = null;
m_olAppointment = null;
#endregion
#region Methods
/// <summary
/// Looks up the window wrapper for a given window object
/// </summary
/// <param name="window">An outlook inspector window</param
/// <returns></returns
internal static OutlookInspector FindOutlookInspector(object window)
foreach (OutlookInspector inspector in m_Windows)
if (inspector.Window == window)
return inspector;
return null;
/// <summary
/// Iterates through a list of Appointment "Outlook.Recipients" and
/// has Microsoft Exchange identify their SMTP email addresses.
/// This routine then concatenates the email address to the end of a
/// string and separates each email address using a semi-colon ";"
/// followed by a space " " character.
/// The returned string is trimmed of spaces (and tabs) leaving a
/// string containing email addresses separated and terminated by
/// a semi-colon ";"
/// </summary
/// <param name="recipients">A collection of Recipient
objects.</param
/// <returns>A string object containing Appointment Attendee email
addresses.
/// For Example:
/// "myEmail@company.com; hisEmail@company.com;
etcEmail@company.com;"
/// </returns
private string
GetAttendees(Microsoft.Office.Interop.Outlook.Recipients recipients)
string attendees = null;
Microsoft.Office.Interop.Outlook.ExchangeUser exUser = null;
string smtpAddr = null;
foreach (Microsoft.Office.Interop.Outlook.Recipient recipient in
recipients)
exUser = recipient.AddressEntry.GetExchangeUser();
if (exUser == null)
smtpAddr = recipient.Address;
else
smtpAddr = exUser.PrimarySmtpAddress;
attendees += (smtpAddr + "; ");
if (attendees != null)
return attendees.Trim();
else
return "none@dtint.com;";
private string GetFromEMailAddress(string fromName)
string emailAddr = "none@dti.com";
Outlook.Recipient recip = m_nameSpace.CreateRecipient(fromName);
Outlook.ExchangeUser exchgUser =
recip.AddressEntry.GetExchangeUser();
if (exchgUser != null)
emailAddr = exchgUser.PrimarySmtpAddress;
return emailAddr;
#endregion
#region Event Handlers
private void SetODBCConnectionStatus(object sender, EventArgs<bool
connected)
m_odbcIsActive = connected.Value;
if (m_ribbon != null)
m_ribbon.SetConnectedToDB(m_odbcIsActive);
private void Monitor_AppointmentAdded(object sender,
EventArgs<Outlook.AppointmentItem> appt)
string formatStr;
string msg;
if (m_ribbon.isDTIAssignment())
if ((appt.Value.Subject != null) && (appt.Value.Location !=
null))
string dbAction = "NEW";
string attendees = GetAttendees(appt.Value.Recipients);
string fromEMailAddr =
GetFromEMailAddress(appt.Value.Organizer);
m_odbcForm.Do_eBudgetSQL(dbAction,
appt.Value.Subject, appt.Value.Location,
fromEMailAddr,
attendees, appt.Value.StartUTC.ToString(),
appt.Value.EndUTC.ToString(),
appt.Value.Body);
else
formatStr = "DTI Appointments require Subject and
Location. ADD to Cache ignored.";
msg = System.String.Format(formatStr,
appt.Value.Subject);
MessageBox.Show(msg);
private void Monitor_AppointmentDeleting(object sender,
CancelEventArgs<Outlook.AppointmentItem> appt)
string formatStr;
string msg;
null))
string dbAction = "DELETE";
fromEMailAddr,
appt.Value.Body);
else
Location. DELETE from Cache ignored.";
// We could prevent the delete from happening if we wanted to,
// but we don't so allow the delete to occur.
appt.Cancel = false;
/// <summary
/// This method is called immediately following the "Add" event of
/// a Calendar AppointmentItem.
/// This method is also called immediately following the
"Modification"
/// event of a Calendar AppointmentItem.
/// </summary
/// <param name="sender">The sending object</param
/// <param name="appt">The calendar appointment record
modified</param
private void Monitor_AppointmentModified(object sender,
string formatStr;
string msg;
null))
string dbAction = "CHANGE";
fromEMailAddr,
appt.Value.Body);
else
Location. CHANGE Cache value ignored.";
/// <summary
/// The NewInspector event fires whenever a new inspector is
displayed. We use
/// this event to add our custom button to appointment item
inspectors.
/// </summary
/// <param name="Inspector"></param
private void Inspectors_NewInspector(Outlook.Inspector Inspector)
try
// Debug.WriteLine("Inspectors_NewInspector");
OutlookItem olItem = new OutlookItem(Inspector.CurrentItem);
// Make sure this is an appointment item
if (olItem.Class == Outlook.OlObjectClass.olAppointment)
m_olAppointment =
(Outlook.AppointmentItem)Inspector.CurrentItem;
m_ribbon.setApptItem(m_olAppointment);
// Check to see if this is a new window
// we don't already track
OutlookInspector existingWindow =
FindOutlookInspector(Inspector);
// If the m_Windows collection does not
// have a window for this Inspector,
// we should add it to m_Windows
if (existingWindow == null)
OutlookInspector window = new
window.Close += new EventHandler(WrappedWindow_Close);
window.InvalidateControl +=
new
EventHandler<EventArgs<string>>(WrappedWindow_InvalidateControl);
m_Windows.Add(window);
catch (Exception ex)
Debug.WriteLine(ex.Message);
void WrappedWindow_InvalidateControl(object sender,
EventArgs<string> e)
if (m_Ribbon != null)
m_Ribbon.InvalidateControl(e.Value);
void WrappedWindow_Close(object sender, EventArgs e)
OutlookInspector window = (OutlookInspector)sender;
window.Close -= new EventHandler(WrappedWindow_Close);
m_Windows.Remove(window);
#endregion
#region VSTO generated code
/// <summary
/// Required method for Designer support - do not modify
/// the contents of this method with the code editor.
/// </summary
private void InternalStartup()
this.Startup += new System.EventHandler(ThisAddIn_Startup);
this.Shutdown += new System.EventHandler(ThisAddIn_Shutdown);
#endregion
> deleted.
> > SE.
> > Real Behavior:
> > (as
> > later.
> > folder:
> > AppointmentAdded;
> > // Constructor
> > m_calFolder =
> > m_session = null;
> > m_calFolder = null;
> > } // End Shutdown()
> > event listeners.
> > collection
> > prevents
> > due
> > to
> > fire.
> > items.ItemChange +=
> > new
> > items.ItemAdd +=
> > delItems.ItemAdd +=
> > new
> > new
> > curItem.ItemAdd -=
> > curItem.ItemAdd -=
> > new
> > new
> > new
> > new
> > private T m_value;
> > m_value = aValue;
> > public T Value
C
cGtlbGxleQ
Just seems strang that within 15 seconds of the initial ADD, I get two
modifications to the item. I guess if the modification to the item is due to
some time-stamp being posted by Exchange, I can understand that. It would
make sense.
> > SE.
> > Real Behavior:
> > (as
> > later.
> > folder:
> > AppointmentAdded;
> > // Constructor
> > m_calFolder =
> > m_session = null;
> > m_calFolder = null;
> > } // End Shutdown()
> > event listeners.
> > collection
> > prevents
> > due
> > to
> > fire.
> > items.ItemChange +=
> > new
> > items.ItemAdd +=
> > delItems.ItemAdd +=
> > new
> > new
> > curItem.ItemAdd -=
> > curItem.ItemAdd -=
> > new
> > new
> > new
> > new
> > private T m_value;
> > m_value = aValue;
> > public T Value
K
I'm not going to even try analyzing all that code.
ItemAdd() provides you with an item, as does ItemChange(), ItemRemove() does
not. If what you were doing was adding an ItemAdd() handler for Deleted
Items then I misread your code, if it was an ItemRemove() event handler no
item would be supplied.
news:32D5569A-8519-4A72-AE5D-7A6B768DDFA8@microsoft.com...
> items folder.
> of
> the deleted
> delete folder.
> folder.
> events
> of the calendar
> folder.
> If
> yes, what would you
> class:
> tracked
> inspector windows
> reference
> appointment events.
> #endregion
> new
> new
> new
> new
> new
> new
> new
> new
> m_Windows.Clear();
> m_Windows = null;
> m_Ribbon = null;
> m_nameSpace = null;
> m_monitor = null;
> #endregion
> #region Methods
> /// <summary
> /// </summary
> window)
> return inspector;
> return null;
> /// <summary
> a
> /// </summary
> objects.</param
> addresses.
> /// For Example:
> /// </returns
> private string
> in
> recipients)
> if (exUser == null)
> else
> else
> return emailAddr;
> #endregion
> connected)
> string formatStr;
> string msg;
> null))
> fromEMailAddr,
> appt.Value.Body);
> else
> string formatStr;
> string msg;
> null))
> fromEMailAddr,
> appt.Value.Body);
> else
> /// <summary
> "Modification"
> /// </summary
> modified</param
> string formatStr;
> string msg;
> null))
> fromEMailAddr,
> appt.Value.Body);
> else
> /// <summary
> displayed. We use
> inspectors.
> /// </summary
> try
> m_olAppointment =
> window.Close += new
> new
> #endregion
> /// <summary
> /// </summary
> #endregion
C
cGtlbGxleQ
Sorry for overwhelming you with too much code. I get a little intense
sometimes.
I was trying to answer your question, "What exactly is being done when
ItemAdd fires, are you doing anything with that item and its properties?"
The code shows it all.
Anyway, thank you for spending some time on this. You have been helpful.
> > items folder.
> > of
> > the deleted
> > delete folder.
> > folder.
> > events
> > of the calendar
> > folder.
> > If
> > yes, what would you
> > class:
> > tracked
> > inspector windows
> > reference
> > appointment events.
> > #endregion
> > new
> > new
> > new
> > new
> > new
> > new
> > new
> > new
> > m_Windows.Clear();
> > m_Windows = null;
> > m_Ribbon = null;
> > m_nameSpace = null;
> > m_monitor = null;
> > #endregion
> > #region Methods
> > /// <summary
> > /// </summary
> > window)
> > return inspector;
> > return null;
> > /// <summary
> > a
> > /// </summary
> > objects.</param
> > addresses.
> > /// For Example:
> > /// </returns
> > private string
> > in
> > recipients)
> > if (exUser == null)
> > else
> > else
> > return emailAddr;
> > #endregion
> > connected)
> > string formatStr;
> > string msg;
> > null))
> > fromEMailAddr,
> > appt.Value.Body);
> > else
> > string formatStr;
> > string msg;
> > null))
> > fromEMailAddr,
> > appt.Value.Body);
> > else
> > /// <summary
> > "Modification"
> > /// </summary
> > modified</param>
L Outlook 2007 does not start with Apple iCloud-Add-In activated Using Outlook 2
K Outlook 2007 Calendar - Time spinner does not function correctly Using Outlook 1
E Double clicking on from email address does no longer open corresponding contact in Outlook 2007 Using Outlook 7
B Importing Contacts Does Not Use Defined Custom Form in Outlook 2007 Outlook VBA and Custom Forms 1
G What does 'daily limit has been reached' mean in Outlook 2007? BCM (Business Contact Manager) 1
H Where does Outlook 2007 save the default reminder settings? Outlook VBA and Custom Forms 1
B Outlook 2007 Custom Form does not display in 2003 Outlook VBA and Custom Forms 3
D Outlook 2016: /altvba startup switch does not work Using Outlook 2
C Unchecking "Send immediately when connected" does not work on apps that call Outlook Using Outlook 1
G Outlook does not show new appointments in To-Do-Bar Using Outlook 0
A Does Outlook import Gmail Archive? Using Outlook 1
1Firefly Outlook 2013 Converstation preview does not show my last reply Exchange Server Administration 1
T outlook 2013 does not mark multiple forward messages as forward Using Outlook 2
M does outlook 2013/365 on mac support custom forms? Outlook VBA and Custom Forms 1
H Outlook.com calendar does not update from Outlook 2013 Home Premium Using Outlook 1
M Incoming invites to my imap account does not sync to outlook.com Using Outlook.com accounts in Outlook 29
S Outlook 2013 To Do Task does not minimize. Using Outlook 0
D Outlook 2013 deletes emails, does not send them to Deleted Items or Trash Using Outlook 2
O Outlook 2010 does not open MS Word attachments Using Outlook 1
M Outlook Appointment item does not show the item outside the date range Using Outlook 2
H Reocurring outlook appointment (office 2010) does not update Outlook.com Using Outlook 3
F Outlook 2010 contact e-mail Display as: does not show contact name Using Outlook 2
P Reply All does not work in Outlook 2010 Cached mode Using Outlook 4
R Outlook 2013 does not show in default programs - how do I search Using Outlook 1
U How does outlook desktop work with outlook.com Using Outlook 5
V Outlook Calendar No Reminders Show up but does on iPhone Using Outlook 0
V Outlook Calendar No Reminders Show up but does on iPhone Using Outlook 2
Fozzie Bear How does Outlook 2003 deals with IMAP configuration Using Outlook 8
J Does Outlook 2003 run on Windows 8 Professional? Using Outlook 2
E Does Outlook indexing work across multiple servers? Using Outlook 0
E Does Outlook 2010 support searching multiple .pst files simultaneously? Using Outlook 0
J Outlook 2003 does not send or receive imap mail from server Using Outlook 0
S Compiler Error: Does not like Outlook.CommandBarControls.CommandBarControlPtr.Add Outlook VBA and Custom Forms 1
T Outlook's button 'Attach File' does not work Outlook VBA and Custom Forms 7
N why does vb not recognise outlook code? Outlook VBA and Custom Forms 1
