Exchange 2007 and CAS from Exchange 2010 problem
I
Igor L. Kravchenko
Hello, we have Exchange 2007. Now I installed CAS 2010. When I try to use CAS 2010 to connect using OWA, it works internally. When I try to login when I am outside of the firewall, it prompts me to login. After I entered user name and password, it goes to https://externaldomainname/owa/auth.owa and gives me "page cannot be found" error.
I am working with Microsoft for about a month now and nothing.
Anyone has any ideas? I changed DNS (obviously it is correct because I see 2010 OWA login page), changed Firewall and nothing. I worked with Firewall support and they told me that packets are forwarded to the CAS 2010 server but nothing coming back.
Anyone?
Mitesh Gosar
If you are accessing Exchange 2007 mailbox through Exchange 2010 CAS then your OWA url will be redirect to Exchange 2007 CAS server.
For e.g.: If mailbox on Ex2k7MBX and accessing through Ex 2010 CAS server https://Ex2010CAS.domain.com/owa after login credential your OWA URL will be redirect to Ex 2007 CAS server https://Ex2007CAS.domain.com/owa.
- Mitesh Gosar| Skype:Mitesh.Gosar
Brian Day MCITP
What kind of firewall is in place? What are your ExternalURL values for the 2007CAS servers set to? What Auth type are the OWA vDirs for CAS2007? Is it Exchange 2010 SP1 RU1, or some older version?
I
Igor L. Kravchenko
I will try to answer.
Yes, it redirects to Exchange 2007 CAS server. When I login internally, I can see that URL changes to internal Exchange 2007 CAS server.
We use SonicWall 4060 Pro Enhanced. I worked with support and they are telling me that everything works correct. I have an entry on the firewall for CAS server. All I had to do is to change IP address for that entry.
ExternalURL for 2007 CAS server is empty and it is setup to Integrated Windows Authentication. 2010 CAS server has external URL https://externalurl/owa and it is setup to use form-based authentication.
Version for Exchange 2010 is 14.00.0702.000.
I am working with Microsoft for about a month now. The guy is telling me that everything is setup correctly.
Any ideas?
Brian Day MCITP
Are you trying to force a Proxy to happen instead of a normal single-sign-on redirection to a legacy URL?
B Re: Exchange 2007 and CAS from Exchange 2010 problem Exchange Server Administration 15
M Re: Exchange 2007 and CAS from Exchange 2010 problem Exchange Server Administration 2
H Outlook 2007 periodically disconnects from Exchange 2010 CAS - OWA works Using Outlook 4
H Is possible to have exchange 2007 CAS point to the exchange 2010 CAS? Exchange Server Administration 2
norbertlars Exchange 2007 - quota not shown in clients Exchange Server Administration 2
R Outlook 2007 - Shared Accounts and Resources without Exchange Server Using Outlook 0
Diane Poremsky Outlook 2016 & Exchange 2007: Not supported New Slipstick.com Articles 0
D Multiple Exchange Accounts in 2007 Using Outlook.com accounts in Outlook 1
B Old attachments do not open after Exchange 2007 edb recovery. Exchange Server Administration 3
TotallyConfused Godaddy Microsoft exchange 2007 stopped updating Exchange Server Administration 1
W Sync categories between Exchange and 2007 Exchange Server Administration 1
J Outlook 2013 - Exchange 2007 manage distribution group Exchange Server Administration 1
Jon Bakrley Outlook 2013 and Exchange 2007, Out of the office error message Using Outlook 8
W Moving Exchange 2007 to a different drive/partition? Exchange Server Administration 1
M connection to the microsoft exchange server has been lost. outlook 2007 Exchange Server Administration 0
R Ingest contact PST from exchange 2007 thru client's Outlook via PRF Exchange Server Administration 2
E "Current View" settings across multiple users on same Exchange 2007 account. Using Outlook 1
S Installing Exchange 2007 on Outlook 2007 with a previous POP3 account Using Outlook 1
B Promoting and demoting dns w/ exchange 2007 sp2 environment Exchange Server Administration 1
S Outllook 2007 stops connecting with Exchange after latest MS Updates Using Outlook 2
D Removing multiple Exchange 2007 servers on the same Domain and site Exchange Server Administration 1
A Identifiying who changed or updated an appointment in Exchange 2007 Exchange Server Administration 7
S Outlook 2007 Rules randomly stopping working (non-Exchange Server) Using Outlook 6
T Multiple Mailboxes not Synchronizing with Exchange 2007 Exchange Server Administration 0
M Outlook 2007 "cannot open your default email folders.microsoft exchange is not available" on XP is n Using Outlook 1
M Outlook Anywhere not working for Exchange Server 2007 Using Outlook 7
X Exchange 2007 Outlook Anywhere Clients unable to retrieve GAL Using Outlook 9
B Outlook 2007 New email notification works intermittently after adding Exchange 2010 Servers Exchange Server Administration 1
C Exchange 2007 Shell command to find users who are members of Recipient Administrator Exchange Server Administration 3
M Outlook 2010-Sync with Exchange server 2007 Using Outlook 2
J outlook 2011 for mac not connecting to exchange 2007, previous entourage does & i can ping the serve Using Outlook 1
J Suggested times does not work with Outlook 2010 in combination with Exchange 2007 SP2? Using Outlook 2
M Outlook 2010 Connectivity with Exchange 2007 Using Outlook 5
M Outlook 2010 Connectivity with exchange server 2007 Using Outlook 1
A cannot connect outlook 2007 clients to exchange 2010 Exchange Server Administration 3
D How to push a second outlook 2007 'private' calendar on exchange 2007 to my mobile phone. Using Outlook 1
V Daylight savings times X Exchange 2007 pop3 Using Outlook 2
M Appointments with more than one day are not shown correctly at iPhone after Service Pack 3 for Exchange 2007 Using Outlook 2
S Can not find a mailbox - Exchange 2007 Exchange Server Administration 1
M Outlook Mail Format Options - Grayed out 2003 office/outlook in exchange 2007 mail organisation. Using Outlook 3
R Unable to use Public Folders on Exchange 2007 via OLK2007 Using Outlook 2
P Problems with shared Calendars in an Exchange 2007 and Outlook 2007 environment Using Outlook 1
