Error in outlook.ost file, scanpst.exe does not work.
G
Gordon B-P
What type of email account?If you find my response helpful, please click on the " Vote as Helpful" button!Thank you!
Brian Tillman
If you actively use Exchange or the Outlook Hotmail Connector, then with Outlook closed, delete the OST and then restart Outlook. the OST will be recreated. If youused to use Exchange but no longer do, then deleting the OST will be the wrong thing to do. Instead, use SCANOST.EXE, which should be in the same place you found SCANPST.
Seabass77
I deleted the OST file, and when I tried to open Outlook again I got the same message. I've also tried scanost.exe and scanpst.exe.
Also, I can't seem to locate the actual .pst file, even after unhiding all files. Is that a problem, or am I not looking in the right area?
I recently suspected a virus and restored to an earlier date. Could a virus potentially delete my .pst file, and could this possibly be the reason I can't open Outlook?
I'm about to try a shut down to see if anything is hanging.
Thank you so much for the help!
Diane Poremsky Error Opening Outlook and Control Panel's Mail Applet New Slipstick.com Articles 0
Diane Poremsky Cannot start Microsoft Office Outlook Error Message New Slipstick.com Articles 0
U .pst file error at opening outlook Using Outlook 1
A Outlook Macro Causing Excel Error Outlook VBA and Custom Forms 0
Diane Poremsky Outlook Error Ox800CCC13 in Windows 10 New Slipstick.com Articles 2
N Outlook 2013 installation error Using Outlook 1
HenWin Outlook 2007 and Comcast certificate error Using Outlook 1
P Encryption Type Error - Verizon and Outlook 2010 Using Outlook 0
M Outlook Email Connection Error Using Outlook 3
T Outlook 2010 sync error Using Outlook 0
H 2010 Outlook 0x800CCC92 Error Using Outlook 2
RBLampert Outlook downloads error out if one particular account is the first to download Using Outlook 0
E Microsoft Office Outlook 2007 Send Error Using Outlook 11
C Error installing BCM: requires outlook BCM (Business Contact Manager) 25
B 0x800CCC0F Error using POP3 in Outlook 2010 and 2013 Using Outlook 1
E Outlook 2013 default file error Using Outlook 1
H Outlook Error message Using Outlook 10
B Outlook to Word Template error Using Outlook 4
J Just installed Outlook 2010 on computer and user is getting a 0x80004005 error Using Outlook.com accounts in Outlook 1
J Outlook 2007 Error sharing Calendar: Error while preparing to send sharing message Using Outlook.com accounts in Outlook 2
J Customizing PST error message in Outlook Using Outlook 8
R Outlook 2013 cannot send email error 0x700700c1 Using Outlook 1
P Error Message “Your Outlook Data File cannot be configured” Using Outlook 5
S Error after enabling 2-step authentication in Outlook.com/Outlook 2013 Using Outlook.com accounts in Outlook 1
Jon Bakrley Outlook 2013 and Exchange 2007, Out of the office error message Using Outlook 8
J New Outlook 2007 form - try to send and get error Operation Failed Outlook VBA and Custom Forms 11
P I'm getting an error when opening Outlook "Mobile me stopped working Using Outlook 1
D outlook keeps crashing with cLucene error Using Outlook 2
T Error" There are no items to show in this view" for Outlook 2007 with 16GB pst Using Outlook 2
A Outlook Error Using Outlook 0
