DAG problem - I´m not able to recover database
Jiří Janata
I had 3 exchange servers. 2 Mailbox servers (with DAG) and 1 CAS + Hub server. One DAG member has failed and my DAG is now not working. If I want to make, database copy on second server, mark as active, I only see, that database is failed (and on first server is Service Down). So, what can I do? Thank you very much.
Mitesh Gosar
Re: DAG problem - I´m not able to recover database
any error in Eventlogs? All Exchange Services are running? File Witness Server is running?
- Mitesh Gosar | Skype:Mitesh.Gosar
Jiří Janata
My first database server has failed. I have now only second database server and CAS+HUB server. On first database server was active database copy and now, I´m not able to activate second database copy, because if I use script for make database active, I will see message, that content index is in a failed state.
G
Gen Lin
1. Make sure the the Witness server is running.
2. Open Failover Clust Manger, please check if the cluster is online.
3. Restart the MSExchange Search service.
4. Run update-mailboxdatabasecopy -catalogonly for the passive database.
Jiří Janata
Cluster is online (only one node is active. second is failed..)
restart MSExchange Search service - ok
if I run update-mailboxdatabasecopy -catalogonly I see this:
A source-side operation failed. Error An error occurred while running prerequisite checks. Error: A source-side operation failed. Error An error occurred while running prerequisite checks. Error: Service 'Microsoft Exchange Search' doesn't appear to be running on server 'EXCHANGEDB1'. Please verify that the server is operating, and that services can be queried remotely... [Database: Mailbox Database 1111212610, Server: EXCHANGEDB2.contoso.local]
+ CategoryInfo : InvalidOperation: (Mailbox Database 1111212610:String) [Update-MailboxDatabaseCopy], See dPrepareException
+ FullyQualifiedErrorId : BAB01148,Microsoft.Exchange.Management.SystemConfigurationTasks.UpdateDatabaseCopy
AndyD_ [MVP]
If you only have one copy of the databse available, then you can't use update-mailboxdatabasecopy to reseed.
Have you tried activiating that passive copy with to skip the index check?
Move-ActiveMailboxDatabase <yourdatabse> -SkipClientExperienceChecks
Jiří Janata
I had run this:
move-activemailboxdatabase " Mailbox Database 1111212610" -skipclientexperiencechecks -activateonserver exchangedb2
and I give this error...
Error: The database action failed. Error: An error occurred while trying to validate the specified database copy for possible activation. Error: Database copy 'Mailbox Database 1111212610' on server 'EXCHANGEDB2.contoso.local' has a copy queue length of 9223372036854774840 logs, which is too high to enable automatic recovery. You can use the Move-ActiveMailboxDatabase cmdlet with the -SkipLagChecks and -MountDialOverride parameters to move the database with loss. If the database isn't mounted after successfully running Move-ActiveMailboxDatabase, use the Mount-Database cmdlet to mount the database. [Database: Mailbox Database 1111212610, Server: exchangedb2.contoso.local
+ CategoryInfo : InvalidOperation: (Mailbox Database 1111212610:ADObjectId) [Move-ActiveMailboxDatabase],
AmDbActionWrapperException
+ FullyQualifiedErrorId : E87B17D3,Microsoft.Exchange.Management.SystemConfigurationTasks.MoveActiveMailboxDatabas
e
AndyD_ [MVP]
I would try what the error suggests:
(Why is the first server still down? Are you unable to bring it back up?)
Jiří Janata
You are GOD!!!!
Thank you very much!!!!
move-activemailboxdatabase " Mailbox Database 1111212610" -skipclientexperiencechecks -activateonserver exchangedb2 -MountDialOverride:BestEffort -SkipLagChecks
Jiří Janata
My first server was in Hyper-V, and your VHD was on failed RAID array...
M Problem removing a mailbox server from a DAG. Exchange Server Administration 1
S DAG question Exchange Server Administration 0
B Two server DAG setup, second server EMC not opening Exchange Server Administration 3
L DAG Requirements Exchange Server Administration 5
G Mount recovery database fails on DAG Exchange Server Administration 3
S Mailbox Stores not mount in Two Member DAG Exchange Server Administration 4
P DAG CONFIGURED Need to change the data base and log file location .What are the risk .And Steps to p Exchange Server Administration 3
A Exchange DAG Exchange Server Administration 1
V mapiexceptioncallfailed: unable to mount database when activate mailboxdatabase in dag Exchange Server Administration 4
S DAG Content Index failed Exchange Server Administration 2
E Outlook 2007 won't connect to 2nd Mailbox Server in a DAG Exchange Server Administration 2
S DAG with Single Network Card Exchange Server Administration 8
T Exchange 2010 DAG Failover Issue - Database Activation Fails because Content Index Catalog Failed Exchange Server Administration 2
L DAG Question - Help Exchange Server Administration 2
A Access a DAG over a virtual lan ip for backup Exchange Server Administration 1
J Question of Exchange 2010 DAG Exchange Server Administration 3
M Hyper-v vSwitches and DAG Networks Exchange Server Administration 7
A Need Help Urgent !!!- Add Seconde Node To The DAG Exchange Server Administration 12
P 2 Member DAG - Members Virtualised running on non Clustered Hosts - supported Configuration? Exchange Server Administration 2
P Two Member DAG - Reboot Witness Server - Effects? Exchange Server Administration 7
K Exchange 2010 DAG Exchange Server Administration 2
S DAG replicaiton and server maintenance Exchange Server Administration 6
J When a database move from active host in a DAG, user are prompted for credentials Exchange Server Administration 8
à Loss the file share witness of DAG Exchange Server Administration 4
S DAG RPCclientAccessServer Exchange Server Administration 5
K msexchangerepl utilizing high CPU in a DAG env Exchange Server Administration 10
S Extend Exchange 2010 DAG accross sites Exchange Server Administration 3
M DAG layout and space question Exchange Server Administration 2
S DAG manually dismount database Exchange Server Administration 4
M Exchange 2010 DAG Witness Server Help Exchange Server Administration 2
S DAG Deployment Design with site resiliance Exchange Server Administration 2
H Shutdown all member in a DAG Exchange Server Administration 2
S Active Passive DAG seperate DNS namespace Exchange Server Administration 7
S Exchange 2010 DAG issue Exchange Server Administration 1
C DAG IP address Exchange Server Administration 9
A Why not using DAG virtual IP/fqdn for CAS array in two nodes setup? Exchange Server Administration 2
A Unable to manage DAG Exchange Server Administration 5
