CAS Array Question
DG1212
Is there a way to prioritize which CAS users connect to in a CAS array? I ideally want users to connect to the on-site CAS unless it goes down for some reason.
DG1212
I'm sorry, I may have not explained myself clearly. We have a single CAS array. The array spans two sites in AD. I would like users to connect to the on-site CAS (CAS Server1) only unless that site goes down and then they would connect to (CAS Server2).
DG1212
So how do you implement a DR solution for CAS across two sites/subnets?
DG1212
Is a CAS array needed if I have a CAS/HT for HA and then I just change then rpcclientaccessserver manually for each database?
TWHarrington
If you want HA for Outlook RPC access, then you need a CAS Array with at least 2 CAS servers in it. If you have to manually change the rpcclientaccessserver parameter maually to whatever CAS server is up, then you have lost your HA. Sure it will work, but you won't have HA.
DG1212
If I end up using the rpcclientaccessserver parameter failover method, what's the best way to update the Outlook clients without having to reconfigure everyone's mail settings to point to the alternate CAS?
TWHarrington
As long as you are using Outlook 2007/2010, autodiscover will reconfigure the Outlook client. But the Outlook client will recieve a message that the administrator has changed some settings and that Outlook will have to be restarted.
MaliStane
You create two cas array. One for Site A and other for Site B. You do not need to use two cas servers to form cas array. But by design, if there is only one CAS server in site, user's will by default use these CAS server.
Allen Song
To achieve HA between the two sites for the CAS, deploy a array per site is necessary.
Allen
Allen Song
T CAS Array/RPCClientAccessServer and Outlook profile experiences Exchange Server Administration 8
A Why not using DAG virtual IP/fqdn for CAS array in two nodes setup? Exchange Server Administration 2
C Watson Error on CAS Exchange Server Administration 1
S Exchange CAS server OAB directory not showing web.config file Exchange Server Administration 3
T RBAC Error on UM/CAS Servers Exchange Server Administration 2
R FQDN of Exchange CAS servers not in SSL cert Exchange Server Administration 2
D CAS Design Question Exchange Server Administration 4
D Exchange 2010 CAS at 2 different Sites Exchange Server Administration 2
T Cas server uninstall failed... Now how to reinstall? Exchange Server Administration 4
S Any system impact if change exchange 2010 CAS/HUB and Mailbox server IP address Exchange Server Administration 1
C CAS Connections overview Exchange Server Administration 9
R Exchange 2010 CAS high availibility cross datacenters Exchange Server Administration 9
S CAS install failed - "Value cannot be null. Parameter name: key" Exchange Server Administration 7
Treebys Array out of bounds .display 2016 Outlook VBA and Custom Forms 3
J Storing userproperties to array Outlook VBA and Custom Forms 4
Dr. Demento Outlook output to array -> Excel & re-format Using Outlook 2
G Array of Outlook 2007 Errors Using Outlook 3
G How to insert a json array into a calendar events Outlook VBA and Custom Forms 1
S MAcro - Need help in getting the recipients in to filed / cc field toput in an array Outlook VBA and Custom Forms 4
H Attachment Array? Outlook VBA and Custom Forms 5
H Using Array for Attachments? Outlook VBA and Custom Forms 1
A message body- find any words in my array? Outlook VBA and Custom Forms 2
D.Moore SendAndReceive question Outlook VBA and Custom Forms 2
N Question Using Outlook 8
CWM030 Email Catagorties question Using Outlook 1
MahdeeyaAbdulla Friend's outlook question Using Outlook 1
rerun101 Question about message options Outlook VBA and Custom Forms 4
