Exchange 2010 DAG Witness Server Help
MasterNe0
I have setup 1 Active Directory Server, 2 Server 2008 - Exchange 2010 Servers and a Server 2008 File Server.
I am trying to make my witness server the File Server (Which just have the file server role only). I have given the local administrator group the Echange Trusted Subsystem but when I try to create the DAG group, I get the " The Exchange Trusted Subsystem is not a member of the local Administrators group" warning when I move it. I have attempt this a few times but unable to get pass this error at this point.
Here are my settings:
Witness Server FQDN: fileserver.test.net
Witness Directory: C:\Witness
I have noticed that if I install the HUB transport role onto this fileserver, then I don't get the warning. However this will require another exchange license because it say it has 120 days to be activated which isn't what I need to do.
MasterNe0
I saw that article and no, t didn't help. It specify and so do other articles I have looked up that all I had to do was add the Exchange Trusted Subsystem to the local administrator group for my non-exchange server and it should work.
However I have tried it and I get the " local administrator group does not have the exchange trusted subsystem" in it. I also try adding my file-server directly into the exchange trusted subsystem group but being it has no exchange roles, It would not let me unless I install the HUB transport role, then the error would go away (but then it requires me to activate a exchange license).
T Exchange 2010 DAG Failover Issue - Database Activation Fails because Content Index Catalog Failed Exchange Server Administration 2
J Question of Exchange 2010 DAG Exchange Server Administration 3
K Exchange 2010 DAG Exchange Server Administration 2
S Extend Exchange 2010 DAG accross sites Exchange Server Administration 3
S Exchange 2010 DAG issue Exchange Server Administration 1
Diane Poremsky Organizational Forms Library in Exchange 2010 New Slipstick.com Articles 0
V Recover exchange 2010 edb Exchange Server Administration 2
T Renaming an Resource in Exchange 2010 Exchange Server Administration 1
P Outlook 2010 MS Exchange Calendar to Android- ical or webdav? Using Outlook 1
Fozzie Bear Outlook 2010 or 2013 Dual Configuration Exchange + IMAP Exchange Server Administration 6
H In Exchange 2010, how to block an email containing an attachment that has foreign characters Exchange Server Administration 1
N Outlook 2010 exchange - auto-move emails from @domain Exchange Server Administration 1
V Outlook 2013 cant stay connected to exchange 2010 Exchange Server Administration 5
R Exchange 2013/Outlook 2010 Slow Startups Exchange Server Administration 8
Z Outlook 2010 client to Exchange ,,,,search not working proparly Exchange Server Administration 0
M First post -help with managing two calendars Outlook 2010 /Exchange 2010 Using Outlook 0
T Outlook INBOX emails gone back 2-3 weeks after Exchange Server 2010 Restart Using Outlook 0
C Outlook 2010, two exchange mailboxes configured.Unable to see 2ndrymeeting req Using Outlook 2
C Exchange 2010 / Emails received show with display name and not email address Using Outlook 2
S Unable to send or reeceive email in new Exchange 2010 Exchange Server Administration 0
B Sharing Multiple Outlook 2010 Calendars (Exchange) Exchange Server Administration 4
P can't set IRM configuration in Exchange 2010 Exchange Server Administration 2
B Using hosted exchange to sync outlook 2010 calendars and contacts to BB Z10 Using Outlook 4
S Outlook 2010/Exchange 2010 Multi Mailboxes (Server unavailable) Using Outlook 6
D why do exchange contacts not sync properly from outlook 2011 to outlook 2010 Exchange Server Administration 2
J Exchange 2010 free/busy shows hashmarks in scheduling tab when not organizer Exchange Server Administration 6
C Exchange 2010 - Outlook 2010 - Exchange Server Administration 4
Fozzie Bear Outlook 2010 wont remember Exchange Credentials on log off /shutdown of Win7 Exchange Server Administration 2
T Exchange 2010: 'could not save item' and 'Unknown error' when edit calendars Exchange Server Administration 1
I Shared Contacts in Outlook 2010 and Exchange Server 2010 Using Outlook 4
J OL2003 Public Folder Sync Errors w/ Exchange 2010 Exchange Server Administration 11
B Outlook 2010 won't configure exchange account, 0kb .ost file Exchange Server Administration 5
R Thousand of sync issues on Outlook clients with Exchange 2010 Exchange Server Administration 5
R Create a contacts list on Exchange 2010 Exchange Server Administration 10
T Exchange / Outlook 2010 - How to cancel meetings but retain the calendar entry Using Outlook 4
S Outlook Quick Steps - Exchange 2003 / Exchange 2010 Exchange Server Administration 2
R Sharing Exchange 2010 calendars with people outisde our organization Exchange Server Administration 17
