FQDN of Exchange CAS servers not in SSL cert
RVT
I have a client that does not own the Domain Name of the internal AD Domain. So we had to remove the FQDNs of the CAS servers while retaining mail, Legacy, and autodiscover. What are the potential issues by not including the internal CAS FQDNs in the cert?
AndyD_ [MVP]
That depends :)
What FQDN do end-users, both internal and external, connect to when they access the Client Access Servers?
TWHarrington
To add to Andy...if you cannot put the internal names in the cert, then you will have to implement split DNS (if you haven't already done so). This means creating an internal DNS zone for your external namespace. In the inside network, the FQDNs resolve to an internal address of the CAS and on the internet, the same fqdns will resolve to public IPs. You will have to set both the InternalURL and ExternalURL paramenters for each of the CAS virtual directories to the external fqdn name. This will usually be your owa.domain.com address. Also include autodiscover.domain.com in your cert and you should be set.
Again, all this depends on your overall architecture and design. But you can get away with not including the internal CAS server names in your cert.
D Don't understand certificates and FQDN's in exchange 2010 Exchange Server Administration 4
M Outlook 2003 & msstd:FQDN of RPC Proxy Server & GPO $ wildcard certificate Using Outlook 2
A Why not using DAG virtual IP/fqdn for CAS array in two nodes setup? Exchange Server Administration 2
I outlook 2016 manual exchange config Using Outlook 0
Fozzie Bear Office 365 Home Premium with Exchange Online email accounts Using Outlook 3
S What is /O=FIRST ORGANIZATION/OU=EXCHANGE ADMINISTRATIVE GROUP(***************)/CN=RECIPIENTS/CN=... Using Outlook 5
Commodore Microsoft Exchange Add-in Using Outlook 2
D Winmail.dat with MS Exchange Personal and Outlook.com Using Outlook.com accounts in Outlook 5
I Outlook 2013 Transition to Exchange - weirdnesses Using Outlook.com accounts in Outlook 4
E you don't have permission to perform this action exchange 2016 Exchange Server Administration 0
Diane Poremsky Set Another Data File as Default When Using an Exchange Account New Slipstick.com Articles 0
PMR0001 Exchange cf Exchange ActiveSync Exchange Server Administration 1
PMR0001 Mydomain Outlook.com and Exchange post EAS Using Outlook 1
F Contacts folders not syncing with hosted exchange Using Outlook 3
L Receiving work/Exchange email to my personal email Using Outlook 2
R Outlook 2016 - How to change password in MS Exchange email client Using Outlook 0
