Ex2010: Edge Sync / SynStatus Inconclusive?
G
Gomjaba2008
This is quite random. I tried to re-subscribe, re-create etc. etc. and I can't see what this is happening. Here on the HubTransport server
[PS] C:\Windows\system32>Start-EdgeSynchronization RunspaceId : c6286489-790b-44d5-ace5-61a364a5bf6b Result : Success Type : Recipients Name : edge FailureDetails : StartUTC : 08/12/2010 01:22:36 EndUTC : 08/12/2010 01:22:39 Added : 0 Deleted : 0 Updated : 0 Scanned : 0 TargetScanned : 0 RunspaceId : c6286489-790b-44d5-ace5-61a364a5bf6b Result : Success Type : Configuration Name : edge FailureDetails : StartUTC : 08/12/2010 01:22:36 EndUTC : 08/12/2010 01:22:39 Added : 0 Deleted : 0 Updated : 0 Scanned : 0 TargetScanned : 0
Looks good. Now a normal test
[PS] C:\Windows\system32>Test-EdgeSynchronization RunspaceId : c6286489-790b-44d5-ace5-61a364a5bf6b SyncStatus : Normal UtcNow : 08/12/2010 01:24:46 Name : edge LeaseHolder : CN=MAIL,CN=Servers,CN=Exchange Admin LeaseType : Option FailureDetail : LeaseExpiryUtc : 08/12/2010 01:52:39 LastSynchronizedUtc : 08/12/2010 01:22:39 TransportServerStatus : Skipped TransportConfigStatus : Skipped AcceptedDomainStatus : Skipped RemoteDomainStatus : Skipped SendConnectorStatus : Skipped MessageClassificationStatus : Skipped RecipientStatus : Skipped CredentialRecords : Number of credentials 3 CookieRecords : Number of cookies 2
Looks good too. But testing a specific mailbox gives me the 'inconclusive' error
[PS] C:\Windows\system32>Test-EdgeSynchronization -VerifyRecipient xxx@xxx.com RunspaceId : c6286489-790b-44d5-ace5-61a364a5bf6b SyncStatus : Inconclusive UtcNow : 08/12/2010 01:25:37 Name : edge LeaseHolder : CN=MAIL,CN=Servers,CN=Exchange Administrative Group LeaseType : Option FailureDetail : LeaseExpiryUtc : 08/12/2010 01:52:39 LastSynchronizedUtc : 08/12/2010 01:22:39 TransportServerStatus : Skipped TransportConfigStatus : Skipped AcceptedDomainStatus : Skipped RemoteDomainStatus : Skipped SendConnectorStatus : Skipped MessageClassificationStatus : Skipped RecipientStatus : Synchronized CredentialRecords : Number of credentials 3 CookieRecords : Number of cookies 2
The only two hits on google was to either re-subscribe (done that) and also missing product keys (all fully licensed). Even the Eventlog is as clean as you want it to be
(LeaseHolder lines have been shortened on purpose)
G
Gomjaba2008
Hi Gomjaba,
Any updates on your issue?
Hiya,
before I posted here I found the exact thread as solution which did not work for me. I have re-suscribed but had the same. I have tried to create a certificate but it didn't work either.
I have reinstalled the Edge server with no luck.
Am I supposed to install the SAN certificate from the Hubtransport server on the Edge server or is it / can it use a self signed certificate ?
G
Gomjaba2008
Hi Gomjaba,
Hi Frank,
I have now
1. Created a new certificate on the edge server
2. Re-subscribed
= no go. Still inconclusive
I then even imported the SAN certificate from the Hubtransport server to the edge server and again tried to re-subscribe without any luck. I still get inconclusive when trying to verify a receipient but all other tests are fine.
Do you have any other suggestions ? I really need to get this fixed :(
F
Frank.Wang
Hi Gomjaba,
I test it in my lab, same result with yours.
I research it again. If you run Test-EdgeSynchronization -VerifyRecipient xxx@xxx.com, you should check the result
RecipientStatus : Synchronized as it is a recipient test.
And if you test a non existed user, you will get the RecipientStatus : NotSynchronized-Recipient doesn't exist in source AD.
So you can ingore the SyncStatus : Inconclusive.
By the way, you don't need to import HUB's certificate to EDGE server.
G
Gomjaba2008
Hi Gomjaba,
Hiya,
thank you very much Frank for testing this yourself as well. Importing the SAN certificate was a desperate attempt lol
Being microsoft partner we had quite a few tickets left anyway so I just opened a ticket and went through some tests with the technician. He also confirmed that this is expected as the Edge server syncronizes the changes every 5 minutes so it will always be inconclusive.
He also tested the Edge server, sending emails back and forth etc. and it is all working as expected so I am now a bit more comfortable in putting the server into production.
Thank you for your help.
J ex2010 edge transport - inbound from internet Exchange Server Administration 7
M How do I get a copy of the NDRs sent to an administrator in EX2010 Exchange Server Administration 4
N EX2010 SP1 RU2 - High CPU Usage - Exchange Search Servuce Exchange Server Administration 4
M Recommended Reboots for EX2010 Exchange Server Administration 6
R cannot uninstall EX2003 after transition to EX2010 Exchange Server Administration 6
L Following migration from EX2k3 to Ex2010 meeting requests do not appear as tentative Exchange Server Administration 2
A EX2010 ERROR Exchange Server Administration 4
M EX2007 - EX2010 - Public Folder Migration, some items are missing with MSExchange Store Driver 1020 Exchange Server Administration 1
P Ex2010 active sync Exchange Server Administration 4
R Transition from Ex2003 to Ex2010 Exchange Server Administration 11
P Migrating Exchange 2007 to 2010 no mail going between servers or out from the Ex2010 servrer Exchange Server Administration 6
E OWA not working "out of the box" with Ex2010 (or after SP1, or after SP1 RU1)! Exchange Server Administration 3
P Migration Ex2003 to Ex2010 problem, cannot see old mailboxes/users Exchange Server Administration 32
J EX2010 to 2003 does not work with Outlook but does with OWA Exchange Server Administration 2
Y Public Folders move from EX2007 to EX2010 Exchange Server Administration 2
R Ex2003 to Ex2010 Migration - how to remove orphaned public folder replicas on Ex2003? Exchange Server Administration 19
A Does I need to move & upgrade Default Address Lists from EX2003 to EX2010 Server Exchange Server Administration 12
A not able to change password by EX2010 OWA for few user's Exchange Server Administration 26
M outlook client gives security alert after setting up EX2010 owa on server Exchange Server Administration 7
M Mailbox Database failover in Ex2010 RC Exchange Server Administration 7
J Edge + TMG 2010 No email inbound/outbound and cannot telnet to port 25 on TMG Exchange Server Administration 0
J CPA cuts off left edge of printed Calendar. Ex. January the J is cut off. Calendar Printing Assistant 11
S Configure Exchange Edge 2010 on TMG in DMZ Exchange Server Administration 1
S Edge Transport 3rd party mail filter before Exchange 2010 Exchange Server Administration 5
M join internet domain without edge server to the internal DC domain Exchange Server Administration 4
S Edge 2010 and Forefront 2010 in DMZ Exchange Server Administration 12
S Edge 2010 and TMG on the same box Exchange Server Administration 1
S Forefront TMG Management Control 2010 on Edge Server. Exchange Server Administration 1
S how to print all emails sent and received via edge in 2010 Exchange Server Administration 13
M Re: How to force routing between two internal smtp domains across Two Edge servers Exchange Server Administration 7
M How to force routing between two internal smtp domains across Two Edge servers Exchange Server Administration 3
K Edge to Hub to Exchange 2003 Exchange Server Administration 4
K Edge SyncStatus: Inconclusive Exchange Server Administration 2
T Prerequisites softwares for installing exchange 2010 edge transport server on windows 2008 R2 Exchange Server Administration 1
N Exchnage 2010 Hub Cas Edge Server Recovery Exchange Server Administration 3
K Edge Hub testing Exchange Server Administration 10
R Exchange 2010 Edge Transport server not passing emails... Exchange Server Administration 7
A Hub 2010 to Edge 2007 ( Last Error: 421 4.4.2 Connection dropped due to ConnectionReset ) Exchange Server Administration 3
P Exchange 2010 Edge Transport Delays mail Exchange Server Administration 5
H Setting up an Edge Transport Server - Exch 2010 Exchange Server Administration 11
Z Hub Transport and Edge is not working as it should Exchange Server Administration 12
L Plethora of Event ID FAILs on the Edge Transport Exchange Server Administration 4
L Exchange server 2010 edge to hub-transport routing error Exchange Server Administration 9
