Exchange 2007 <-> 2010 OWA not working together redirecting problem
Admin2Go
The Situtation:
I have one AD with two Sites (connected with 34 Mbits) an a coexistence of Exchange 2010 and 2007
Site A.
1 Exchange 2007 Hub Transport witth CAS an Mailserver is connected to the Internet
1 Mailboxcluster
Site B
2 Exchange 2010 with HT, CAS and Mailbox (DAG) (not connected to the Internet)
The Problem:
OWA 2007 (SSL Disabled) is working fine through external IP and internal adress.But I can't conect to Mailboxes on EX2010 in SITE B. HTTP Error 500 or OWA not available , no access through the Internet with CAS of this version possible (translated)
OWAS2010 is working fine internal (not configured external) but I cant access the EX2007 Mailboxes in Site A.
If I do the cmdlet get-virtualdirectory everything seems to be fine.I can open the EX2007 owa on the IE of the EX2010 and vice versa. A Clean Install of EX2007 and EX 2010 (but in the same Site) in ESX worked without this problem.
I need the OWA access primary for mobile phones (only uses the IP withSSL disabled) of the employees so it is neccesary that OWA works for the EX2010 to.
How could I solve the problem. I cant move all the mailboxes from 2007 to 2010 without solving this problem..
Sembee [MVP]
You have to allow both Exchange 2007 and 2010 to be exposed to the Internet.
Then the most effective method is to have users login to Exchange 2010 CAS. They will then be redirected to the legacy URL for Exchange 2007.
This blog posting explains how the redirection works for various scenarios.
http://msexchangeteam.com/archive/2009/12/02/453367.aspx
Simon.
Simon Butler, Exchange MVP
Blog | Exchange Resources
B Outlook 2007 New email notification works intermittently after adding Exchange 2010 Servers Exchange Server Administration 1
M Outlook 2010-Sync with Exchange server 2007 Using Outlook 2
J Suggested times does not work with Outlook 2010 in combination with Exchange 2007 SP2? Using Outlook 2
M Outlook 2010 Connectivity with Exchange 2007 Using Outlook 5
M Outlook 2010 Connectivity with exchange server 2007 Using Outlook 1
A cannot connect outlook 2007 clients to exchange 2010 Exchange Server Administration 3
J Oulook 2007 Vs. Exchange 2010...always asked about login validation... Exchange Server Administration 9
G Share calendar between two Outlook 2010 OR 2007 without exchange where both users can make appointme Using Outlook 1
S Exchange 2010 in 2007 Environment Exchange Server Administration 3
B Blank email list views on Outlook 2010 / 2007 with Exchange 2010 SP1 (on Citrix and Desktops) Using Outlook 7
T How Outlook 2007/2010 choose which Exchange Web Service to use? Using Outlook 1
B Cross Forest Exchange 2007 to Exchange 2010 Mailbox Move question Exchange Server Administration 15
T Re: Outlook Anywhere in Outlook 2010 and Exchange 2007 Using Outlook 3
T Outlook Anywhere in Outlook 2010 and Exchange 2007 Using Outlook 1
N Outlook 2010 Clients can't reply to emails or download offline address book? Hosted Exchange 2007 Using Outlook 5
V Exchange 2007 with Outlook 2010 issue Using Outlook 1
Z Exchange 2007 Transitioning to Exchange 2010 SP 1, and OWA User Redirect or Proxying Exchange Server Administration 1
F Outlook 2007 custom views do not show emails with Exchange 2010 Server Exchange Server Administration 2
F Outlook 2007 custom views do not show emails with Exchange 2010 Server Using Outlook 2
O Outlook 2007 Disconnects from Exchange 2010 Exchange Server Administration 2
M Outlook 2007 (cached mode), Exchange 2010 - Cant download Offline Address Book Exchange Server Administration 6
K Using Microsoft Exchange with Office 2007 conflicts with Office 2010 Home & Student Edition Using Outlook 4
B Re: Exchange 2007 and CAS from Exchange 2010 problem Exchange Server Administration 15
M Re: Exchange 2007 and CAS from Exchange 2010 problem Exchange Server Administration 2
I Exchange 2007 and CAS from Exchange 2010 problem Exchange Server Administration 4
S Outlook 2007, Exchange 2010, Forefront 2010: When using Outlook over http, it loses its connection t Exchange Server Administration 8
B GAL and Free/busy Sharing between Exchange 2010 and Exchange 2007 Exchange Server Administration 1
P How to disable unwanted encoding in Outlook 2010/Exchange 2007? Using Outlook 4
S Exchange 2007 and Excahnge 2010 Mailflow Exchange Server Administration 2
M Public Folders Not Replicating Between Exchange 2007 and 2010 (Migrate/Transitioning 2007 to 2010) Exchange Server Administration 6
A SCOM 2007 R2 not able to see Exchange 2010 mailbox server Exchange Server Administration 4
M Outlook 2010 cannot find suggested times with Exchange 2007. Using Outlook 5
N MS outlook 2010 is keep on prompting user name and password from the EXCHANGE SERVER 2007 SP1 64 BIT Using Outlook 24
S Re: Exchange 2010 and Outlook 2007 folder bug Exchange Server Administration 5
J Unable to access public folders in Outlook 2007 on Exchange 2010. OWA PF works fine Using Outlook 7
S Exchange 2010 Archiving and Outlook 2007 Exchange Server Administration 12
J Exchange 2010 and Outlook 2007 folder bug Exchange Server Administration 12
P Public folder replication between Exchange 2007 and Exchange 2010 Exchange Server Administration 11
R Exchange 2010 RC, Outlook 2007 sending to POP accound results in error (0x800CCC13) Exchange Server Administration 47
norbertlars Exchange 2007 - quota not shown in clients Exchange Server Administration 2
R Outlook 2007 - Shared Accounts and Resources without Exchange Server Using Outlook 0
Diane Poremsky Outlook 2016 & Exchange 2007: Not supported New Slipstick.com Articles 0
D Multiple Exchange Accounts in 2007 Using Outlook.com accounts in Outlook 1
B Old attachments do not open after Exchange 2007 edb recovery. Exchange Server Administration 3
TotallyConfused Godaddy Microsoft exchange 2007 stopped updating Exchange Server Administration 1
