CAS Array and NLB
BJ Small
Hello all, not strickly an exchange 2010 question but for any one who has a CAS array definitely related
I am trying to configure a CAS array using NLB. All is configured however we cannot ping the virtual IP from across the switch.
Config is as follows:
Node 1 MEXCASHUB1 NIC 1 PROD = 10.10.10.50 default gateway 10.10.10.1 and NIC 2 NLB 192.168.1.1 no default gateway
Node 2 MEXCASHUB2 NIC 1 PROD = 10.10.10.51 default gateway 10.10.10.1 and NIC 2 NLB 192.168.1.2 no default gateway
DNS record for CAS Array = mailcasarray 10.10.10.100 this is also the info for the NLB VIP
The NLB is up and running and converged
Problem I cannot ping the VIP from the across the switch. I can ping it from each of the nodes in the cluster. But a client device cannot ping. They get destination host unreachable.
What is the best way to resolve this issue?
E
Ed Crowley [MVP]
It's expected that you can ping the VIP from the nodes since that address gets added to the network configurtion. Do an IPCONFIG /ALL and see.
Can the ping the individual hosts? If not, then maybe your Windows Firewall is blocking PING.
Can you get to the default IIS web page by both hostname and VIP name or IP address?
http://servername
http://load_balanced_VIP_name_or_address
Ed Crowley MVP " There are seldom good technological solutions to behavioral problems."
BJ Small
from each host in the NLB i can get to the default page, i get an SSL error, but yes i can.
from non-NLB nodes i cannot do any of the above. i think need to add teh Virtual MAC of the NLB to the directly attached switch.
T CAS Array/RPCClientAccessServer and Outlook profile experiences Exchange Server Administration 8
A Why not using DAG virtual IP/fqdn for CAS array in two nodes setup? Exchange Server Administration 2
C Watson Error on CAS Exchange Server Administration 1
S Exchange CAS server OAB directory not showing web.config file Exchange Server Administration 3
T RBAC Error on UM/CAS Servers Exchange Server Administration 2
R FQDN of Exchange CAS servers not in SSL cert Exchange Server Administration 2
D CAS Design Question Exchange Server Administration 4
D Exchange 2010 CAS at 2 different Sites Exchange Server Administration 2
T Cas server uninstall failed... Now how to reinstall? Exchange Server Administration 4
S Any system impact if change exchange 2010 CAS/HUB and Mailbox server IP address Exchange Server Administration 1
C CAS Connections overview Exchange Server Administration 9
R Exchange 2010 CAS high availibility cross datacenters Exchange Server Administration 9
S CAS install failed - "Value cannot be null. Parameter name: key" Exchange Server Administration 7
Treebys Array out of bounds .display 2016 Outlook VBA and Custom Forms 3
J Storing userproperties to array Outlook VBA and Custom Forms 4
Dr. Demento Outlook output to array -> Excel & re-format Using Outlook 2
G Array of Outlook 2007 Errors Using Outlook 3
G How to insert a json array into a calendar events Outlook VBA and Custom Forms 1
S MAcro - Need help in getting the recipients in to filed / cc field toput in an array Outlook VBA and Custom Forms 4
H Attachment Array? Outlook VBA and Custom Forms 5
H Using Array for Attachments? Outlook VBA and Custom Forms 1
A message body- find any words in my array? Outlook VBA and Custom Forms 2
