Cross AD Site Free Busy / Availability Issue
jeremybnz
Hi all,
I'm having issues with free busy info across a couple of sites, we currently have 3 exchange servers, 2 in site 1 and 1 in site 2.
Its fine within site, but across site it doesn't seem to work, if I run Test-OutlookWebServices -Identity site1user@domain.com -TargetAddress site2user@domain.com I get the following error:
RunspaceId : 0bd689f9-7036-4c95-8369-f7a20a92fe8c
Type : Error
Message : When querying Availability for site2user@domain.com received ErrorProxyRequestProcessingFailed:Syste
m.Web.Services.Protocols.SoapException: The authenticated user doesn't have sufficient privileges to issue
this request.
at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResp
onse response, Stream responseStream, Boolean asyncCall)
at System.Web.Services.Protocols.SoapHttpClientProtocol.EndInvoke(IAsyncResult asyncResult)
at Microsoft.Exchange.InfoWorker.Common.Availability.Proxy.Service.EndGetUserAvailability(IAsyncResult
asyncResult)
at Microsoft.Exchange.InfoWorker.Common.Availability.FreeBusyApplication.EndProxyWebRequest(ProxyWebReq
uest proxyWebRequest, QueryList queryList, Service service, IAsyncResult asyncResult)
at Microsoft.Exchange.InfoWorker.Common.Availability.ProxyWebRequest.EndInvoke(IAsyncResult asyncResult
at Microsoft.Exchange.InfoWorker.Common.Availability.AsyncWebRequest.EndInvokeWithErrorHandling(). The
request information is ProxyWebRequest type = CrossSite, url = https://site2.internaldomain.net/EWS/Exchang
e.asmx
Mailbox list = <Site2 User>SMTP:site2user@domain.com, Parameters: windowStart = 12/13/2010 1:00:00 A
M, windowEnd = 12/13/2010 2:00:00 AM, MergedFBInterval = 30, RequestedView = FreeBusy
., inner exception: The authenticated user doesn't have sufficient privileges to issue this request.
I'm assuming this is because its on a different subnet? I can't get to the EWS on site2 without it prompting me to login so thats likely the issue, how to fix is another story :)
JB.
jeremybnz
Cheers man, but it is prompting for credentials and if I do login it gives me the xml etc :)
jeremybnz
Aha, fixed it!
Get-ClientAccessServer | Add-ADPermission -AccessRights ExtendedRight -ExtendedRights " ms-Exch-EPI-Token-Serialization" -User " OURDOMAIN.COM\Exchange Servers"
Once it replicated to the other site it worked, yay!
D Red cross Using Outlook 1
W installing exchange 2010 with multiple forest (Cross-forest) Exchange Server Administration 2
B Cross Forest Exchange 2007 to Exchange 2010 Mailbox Move question Exchange Server Administration 15
M Cross-Forest Availibility Service Exchange Server Administration 3
D Removing multiple Exchange 2007 servers on the same Domain and site Exchange Server Administration 1
M Exchange 2010 OWA Redirect with Authentication Across AD Site Exchange Server Administration 1
O How do I failover to my DR Site. Exchange Server Administration 13
S DAG Deployment Design with site resiliance Exchange Server Administration 2
X Single AD site with DR Exchange 2010 Exchange Server Administration 6
M SSO to OWA from site using Integrated Authentication Exchange Server Administration 5
N Free/busy publish at http location does not work Using Outlook 1
O Get Outlook on your phone for free - web page pop up Using Outlook 8
W FYI: CodeTwo Sync for iCloud is FREE now! Using Outlook 0
Diane Poremsky Change the All Day Event Default Free/Busy to "Busy" New Slipstick.com Articles 3
A export free / busy from exchange Exchange Server Administration 0
V [FREE OUTLOOK ADDONS] Outlook Freeware! Using Outlook 0
M print free/busy schedule of an user Using Outlook 2
S Is Free/Busy supposed to work in Outlook 2013 not connected to Exchange? Using Outlook 14
S edits to free/busy fielddon't show up in meeting requests Using Outlook 2
J Exchange 2010 free/busy shows hashmarks in scheduling tab when not organizer Exchange Server Administration 6
P Appearance (Width) of Calendar Appointment "Show as (Free/Busy/etc)" Indicator Using Outlook 1
T Outlook 2007 forms: Check boxes and free text boxes not retaining data Using Outlook 1
B Outlook 2003: Meeting Organizer will be set as always free or busy status Using Outlook 1
T Outlook 2003 free busy vfb file creation problem Using Outlook 12
G Synchronize outlook contacts and calendar with other pc for free Using Outlook 4
S You’ve received Free/Busy information from this user Message Using Outlook 10
R Error message "Cannot save free/busy information" when changing or deleting appointments in Outlook. Using Outlook 4
J Legacy SCHEDULE + FREE BUSY system PFs leftover after complete migration Exchange Server Administration 1
L Exchange 2003 to 2010 Migration - Public Folder Replication Failed - Busy/Free Issue Exchange Server Administration 8
K Outlook: Can not save free / busy information error message Using Outlook 2
P outlook 2003 Free Busy and public folde replica move Exchange Server Administration 10
S Error updating public folder with free/busy information on virtual machine server. The error number Using Outlook 2
S Ghost Meeting showing up in Resource Room Free/Busy - Declining New Meeting Requests Exchange Server Administration 3
H Outlook 2010 & 2007 Free/Busy Using Outlook 3
R Exchange 2010 view entire calendar as free/busy Exchange Server Administration 2
M Exchange 2010 cannot see free/busy for Exchange 2003 mailboxes Exchange Server Administration 15
C Outlook Express Message: To free up disk space, Outlook Express can compact message. Using Outlook 2
M Not enough free memory BCM (Business Contact Manager) 11
C Business Contact Manager and Outlook 2007 "not enough free memory BCM (Business Contact Manager) 5
M Out Of Office and Free/Busy no longer work Using Outlook 3
J Outlook 2003 - free/busy cal after 1/1/2008 Using Outlook 13
W "Unable to Clean free/busy information on the server" Using Outlook 2
