exchange 2010 OWA and exchange 2003 coexist
K
KirkSH
Ok so i want to setup the redirect for my clients to access OWA whether they are on Exch2010 or exch2003. I know the command " Set-OWAVirtualDirectory <CAS2010>\OWA* -Exchange2003URL https://legacy.contoso.com/exchange " will set the CAS server to redirect the user to exchange 2003 if their mailbox resides on exchange 2003. My question is if i redirect via TMG/ISA and would you need to worry about internal url or external url? Also what if i use a CAS Array do i run this command on each member of this array and is this command possible to do through the Console? Thanks
Steve Goodman
Hiya,
Yes the command above should be correct.
The InternalURL and ExternalURL values should be correct regardless of whether you use TMG as these values will be given by services such as Autodiscover to find services, and for redirection etc.
When you mention CAS Array you may be confusing terms. The CAS array is used as a endpoint for Outlook Clients and provides a MAPI proxy in between the clients and the actual Mailbox servers. But what I think you are asking is which servers to set these values on. Without knowing your topology it's hard to answer, but based on what you have said it sounds like you need to do this against each client access servers' set of IIS web sites (OWA, ECP, OAB, EWS etc).
Steve
Steve Goodman
S Signature size limit for OWA / Exchange 2010 Exchange Server Administration 10
M Exchange 2010 OWA Redirect with Authentication Across AD Site Exchange Server Administration 1
M Exchange OWA 2010 acting quirky. Exchange Server Administration 2
M Integrated OCS with Exchange 2010 OWA didn't work over ISA server Exchange Server Administration 4
M Exchange 2010 OWA '403 Access Denied' Exchange Server Administration 3
D Exchange 2010 SP1 OWA "reply" or "forward" error Exchange Server Administration 3
A OWA redirection in exchange 2010 and 2003 Exchange Server Administration 1
F Exchange 2010 - OWA 15 min auto logoff Exchange Server Administration 1
K exchange 2010 OWA and exchange 2003 coexist Exchange Server Administration 1
à owa and powershell take times on exchange 2010 Exchange Server Administration 8
S Exchange 2010 OWA Search only returns 2 days worth Using Outlook 2
A Exchange 2007 <-> 2010 OWA not working together redirecting problem Exchange Server Administration 1
D Is there a way to turn off "group by conversation" by default in OWA Exchange 2010? Using Outlook 2
S Exchange 2010 SP1 OWA Error Exchange Server Administration 2
T Exchange 2010: attachments are not visible in outlook, but visible in OWA Using Outlook 1
Z Exchange 2007 Transitioning to Exchange 2010 SP 1, and OWA User Redirect or Proxying Exchange Server Administration 1
S Exchange 2010 - owa/auth.owa Bad Request Exchange Server Administration 3
Y public calendar using OWA on exchange 2010 Exchange Server Administration 7
T After updating Exchange 2010 from RTM to SP1, OWA clients cannot move or delete emails Using Outlook 4
S Exchange 2010 owa https not working Exchange Server Administration 5
J Exchange 2010 / 2003 OWA Problem Exchange Server Administration 2
B 500 error after authenticating in OWA - Exchange 2010 Using Outlook 1
S Outbox not displayed in Exchange 2010 OWA Exchange Server Administration 5
K Exchange 2010 OWA redirection between 2 CAS Servers Exchange Server Administration 5
H Exchange 2010 - Blank e-mail body in Outlook but typically viewable in OWA Exchange Server Administration 6
C Manage OWA access during the migration from Exchange 2003 to Exchange 2010 (Resource Forest) Exchange Server Administration 4
H Outlook 2007 periodically disconnects from Exchange 2010 CAS - OWA works Using Outlook 4
S Exchange 2010 OWA error 404 with IE 8 Exchange Server Administration 1
K Outlook 2010 on Exchange - 'Sent Items' box always empty on client, but populated in OWA Using Outlook 5
A Exchange 2010 OWA Document Access Exchange Server Administration 3
M block individual IP to Exchange 2010 owa Exchange Server Administration 3
E How to set Kerberos Authentication for OWA on Exchange 2010. Using Outlook 2
J "Clip" icon appear in Microsoft Outlook 2010 / Exchange 2007 OWA Message, but no attachment inside Using Outlook 4
B Exchange 2010 OWA not working on client- Ex2k7 worked Using Outlook 4
J Exchange 2010 CAS Server OWA Redirection to Exchange 2003 Fail Exchange Server Administration 4
S custom look for OWA in exchange 2010 Exchange Server Administration 4
B Exchange 2010 Migration - OWA not working Exchange Server Administration 2
K Some user cannot delete email in OWA Exchange 2010 SP1 Exchange Server Administration 5
R OWA ISSUE Exchange 2010 co-existance with Exchange 2003 Exchange Server Administration 3
M use owa rtm theme in exchange 2010 sp1 ? Exchange Server Administration 5
M owa old theme from exchange 2010 rtm Using Outlook 1
T Exchange 2010 public folders cannot be opened from Outlook, but can from OWA Exchange Server Administration 2
L new install Exchange 2010 OWA web page not formatting correctly/unusable Exchange Server Administration 2
M Cannot Change the branding logo in exchange 2010 SP1 owa default theme Exchange Server Administration 6
