testing autodiscover and exchange coexistence
K
KirkSH
Ok I am attempting to test my autodiscover service in a exchange 2003 and exchange 2010 coexist environment. I have TMG as my reverse proxy back to my cas array. I have a rules in TMG for legacy.domain.com and exch2010.domain.com to publish OWA and Exchange active sync. Legacy points to my exchange 2003 FE server and exch2010 point to my exchange 2010 CAS array. If i want to test autodiscover and the mailbox is still on the exch2003 server should my publishing rule point to the exchange 2003 front end or to my new cas server. Also will the autodiscover service on the TMG server that points to my exch2010 cas array return the info for a milbox that is still on the exch2003 server? Thanks.
Brian Day MCITP
You can't truly test AutoD (Aside from the Test-* cmdlets) until a mailbox is on 2010. Create a test account on 2010, point the autodiscover publishing rule to the 2010 CAS server(s), then test away. :)Microsoft Premier Field Engineer, Exchange
MCSA 2000/2003, CCNA
Diane Poremsky Testing please ignore New Slipstick.com Articles 1
M Validating Form testing 2 Conditions Outlook VBA and Custom Forms 5
D DAG Failover Testing Exchange Server Administration 4
K Edge Hub testing Exchange Server Administration 10
M DR Failover Testing for a DAG in DAC Mode. Errors on Switch Back to Primary Datacentre. Exchange Server Administration 7
B AutoDiscover Forensics Exchange Server Administration 0
EXChange2013 Exchange 2013 AutoDiscover Tweaks? Exchange Server Administration 0
M Outlook 2007 AutoDiscover Using Outlook 0
A Exchange Autodiscover SSL issue Exchange Server Administration 7
M Initial Outlook Configuration with AutoDiscover populates wrong email address Using Outlook 5
N Outlook 2007 Clients Pointed to Wrong Domain Name for Autodiscover Using Outlook 2
C The Autodiscover service couldn't be located. Exchange Server Administration 8
C Exchange server 2010 error "The Autodiscover service couldn't be located." Exchange Server Administration 1
J Autodiscover accounts on exchange 2003 with Outloook 2010 not working Using Outlook 4
Z Autodiscover Points to defunct Exchange 2010 Server Exchange Server Administration 5
M Autodiscover not configuring Outlook Anywhere Using Outlook 10
B Autodiscover error 0x800c8203 and encrypted connection is not available Exchange Server Administration 3
P Autodiscover URLs Exchange Server Administration 15
C Autodiscover Exchange Server Administration 6
I Exchange 2010 Profile AutoDiscover not working for some users Exchange Server Administration 1
S Exhcange 2010 autodiscover virtual directory Exchange Server Administration 4
D External Autodiscover Exchange Server Administration 3
S Exchange 2010 Autodiscover Problems, cannot connect Outlook clients using Autodiscover / Outlook Any Exchange Server Administration 4
G Exchange 2010/Outlook 2007 Can't get autodiscover to work for some users, but others work fine Exchange Server Administration 3
S Autodiscover issue Exchange 2007 Using Outlook 4
P Autodiscover will not work Exchange Server Administration 13
K Exchange 2010 Autodiscover Exchange Server Administration 1
P Autodiscover fails (Exchange 2010) Exchange Server Administration 7
P Autodiscover issues on Exchange 2010 Exchange Server Administration 7
S Exchange 2010 Outlook 2010 Autodiscover fails Exchange Server Administration 22
C Getting Autodiscover to work with other web servers ... Using Outlook 4
C Autodiscover Service Configuration Exchange Server Administration 5
B move mailbox- autodiscover Exchange Server Administration 25
T Autodiscover authentication Exchange Server Administration 2
A autodiscover issue with OL2010 but no issue with OL2007 Exchange Server Administration 10
K Autodiscover and SRV records Using Outlook 10
S Autodiscover redirected Using Outlook 2
C Autodiscover Exchange Server Administration 5
S Autodiscover two AD sites two cas arrays Exchange Server Administration 4
O Autodiscover Exchange Server Administration 4
S Autodiscover FQDN certificate for secondary domain email? Exchange Server Administration 1
K Remove AlternativeMailbox - Autodiscover Exchange Server Administration 5
