exchange 2010 OWA and exchange 2003 coexist
K
KirkSH
The forums and the whitepapers all state that you have to enable forms based authentication on the Exchange 2003 virtual directory called exchange on both the Exchange 2003 FE and Exchange 2003 BE for single sign on when using the CAS array url for accessing OWA internally. So if you do this i would assume we would get only one login when we go to the CAS domain url. If i have to enter two then i would assume one of the virtual directories is still set the other way. is there another of the virtual directories that needs to be set this way? Thanks
S Signature size limit for OWA / Exchange 2010 Exchange Server Administration 10
M Exchange 2010 OWA Redirect with Authentication Across AD Site Exchange Server Administration 1
M Exchange OWA 2010 acting quirky. Exchange Server Administration 2
M Integrated OCS with Exchange 2010 OWA didn't work over ISA server Exchange Server Administration 4
M Exchange 2010 OWA '403 Access Denied' Exchange Server Administration 3
D Exchange 2010 SP1 OWA "reply" or "forward" error Exchange Server Administration 3
A OWA redirection in exchange 2010 and 2003 Exchange Server Administration 1
F Exchange 2010 - OWA 15 min auto logoff Exchange Server Administration 1
K exchange 2010 OWA and exchange 2003 coexist Exchange Server Administration 1
à owa and powershell take times on exchange 2010 Exchange Server Administration 8
S Exchange 2010 OWA Search only returns 2 days worth Using Outlook 2
A Exchange 2007 <-> 2010 OWA not working together redirecting problem Exchange Server Administration 1
D Is there a way to turn off "group by conversation" by default in OWA Exchange 2010? Using Outlook 2
S Exchange 2010 SP1 OWA Error Exchange Server Administration 2
T Exchange 2010: attachments are not visible in outlook, but visible in OWA Using Outlook 1
Z Exchange 2007 Transitioning to Exchange 2010 SP 1, and OWA User Redirect or Proxying Exchange Server Administration 1
S Exchange 2010 - owa/auth.owa Bad Request Exchange Server Administration 3
Y public calendar using OWA on exchange 2010 Exchange Server Administration 7
A Cannot delete mail in OWA only after upgrading Exchange Server 2010 to SP1 Exchange Server Administration 30
J Unable to access public folders in Outlook 2007 on Exchange 2010. OWA PF works fine Using Outlook 7
M No more blue OWA default theme (Exchange 2010) Exchange Server Administration 8
E Java script issue OWA Exchange 2010 Exchange Server Administration 5
R Exchange 2010 RC OWA can't login Exchange Server Administration 29
Diane Poremsky Organizational Forms Library in Exchange 2010 New Slipstick.com Articles 0
V Recover exchange 2010 edb Exchange Server Administration 2
T Renaming an Resource in Exchange 2010 Exchange Server Administration 1
P Outlook 2010 MS Exchange Calendar to Android- ical or webdav? Using Outlook 1
Fozzie Bear Outlook 2010 or 2013 Dual Configuration Exchange + IMAP Exchange Server Administration 6
H In Exchange 2010, how to block an email containing an attachment that has foreign characters Exchange Server Administration 1
N Outlook 2010 exchange - auto-move emails from @domain Exchange Server Administration 1
V Outlook 2013 cant stay connected to exchange 2010 Exchange Server Administration 5
R Exchange 2013/Outlook 2010 Slow Startups Exchange Server Administration 8
Z Outlook 2010 client to Exchange ,,,,search not working proparly Exchange Server Administration 0
M First post -help with managing two calendars Outlook 2010 /Exchange 2010 Using Outlook 0
T Outlook INBOX emails gone back 2-3 weeks after Exchange Server 2010 Restart Using Outlook 0
C Outlook 2010, two exchange mailboxes configured.Unable to see 2ndrymeeting req Using Outlook 2
C Exchange 2010 / Emails received show with display name and not email address Using Outlook 2
S Unable to send or reeceive email in new Exchange 2010 Exchange Server Administration 0
