Need Help Urgent !!!- Add Seconde Node To The DAG
  • Thread starter Ahmad Ramadan AbaYazeed
  • Start date
I Need Help Urgently !!!
I am Trying To Achieve High Availability For Mailbox servers by using DAG
i Have 2 Exchange Server, identical in HW, Windows Server 2008 R2, Latest updates.
i installed on the 1st Server Exchange 2010 Mailbox Role, Hub Transport Role And Client Access Server.
Then i Created the DAG and joined the 1st Exchange 2010 Server To The DAG and worked Perfectly.
i doubled check from the Failover Cluster Service and found out the Cluster name, Cluster IP, Node Resources And Ip are Online.
Even the FSW Resoruce is online
on the seconde server i installed only " MAILBOX Role" and when i try to join the server to The DAG i am Getting The Follwoing error
" A Server Side Data Base Availability Group Administrative Problem Failed Error: The Operation Failed with The Follwoing Error Message: Error 0x71a [Remote Procedure Call Was Cancelled] from cli_RpccAddNodeToCluster"
i am so cluless and i tried everything and nothing worked out
what have i done wrong? how to join this 2nd server to the DAG??
Please I Need Help URGENTLY ASAP!!!
Waiting For Any Replies
Thanx
Worth to Mention this is the .LOG File
" add-databaseavailabiltygroupserver started on machine NEWEXCHANGE.
[2010-12-14T13:02:49] add-dagserver started
[2010-12-14T13:02:49] commandline: $scriptCmd = {& $wrappedCmd @PSBoundParameters }
[2010-12-14T13:02:49] Option 'Identity' = 'MONADAG'.
[2010-12-14T13:02:49] Option 'MailboxServer' = 'NEWEXCHANGE'.
[2010-12-14T13:02:49] Option 'DatabaseAvailabilityGroupIpAddresses' = ''.
[2010-12-14T13:02:49] Option 'WhatIf' = ''.
[2010-12-14T13:02:49] Process: w3wp w3wp.exe:5132.
[2010-12-14T13:02:49] User context = 'NT AUTHORITY\SYSTEM'.
[2010-12-14T13:02:49] Member of group 'Everyone'.
[2010-12-14T13:02:49] Member of group 'BUILTIN\Users'.
[2010-12-14T13:02:49] Member of group 'NT AUTHORITY\SERVICE'.
[2010-12-14T13:02:49] Member of group 'CONSOLE LOGON'.
[2010-12-14T13:02:49] Member of group 'NT AUTHORITY\Authenticated Users'.
[2010-12-14T13:02:49] Member of group 'NT AUTHORITY\This Organization'.
[2010-12-14T13:02:49] Member of group 'BUILTIN\IIS_IUSRS'.
[2010-12-14T13:02:49] Member of group 'LOCAL'.
[2010-12-14T13:02:49] Member of group 'IIS APPPOOL\MSExchangePowerShellAppPool'.
[2010-12-14T13:02:49] Member of group 'BUILTIN\Administrators'.
[2010-12-14T13:02:49] Updated Progress 'Validating the parameters.' 2%.
[2010-12-14T13:02:49] Working
[2010-12-14T13:02:49] Mailbox server: value passed in = NEWEXCHANGE, mailboxServer.Name = NEWEXCHANGE, mailboxServer.Fqdn = NEWEXCHANGE.mona.local
[2010-12-14T13:02:49] LogClussvcState: Received an InvalidOperationException for server newexchange.
[2010-12-14T13:02:49] LogClussvcState: clussvc is not installed on NEWEXCHANGE.mona.local. Exception (if any) = none
[2010-12-14T13:02:49] The IP addresses for the DAG are (blank means DHCP): 192.168.0.178
[2010-12-14T13:02:49] Looking up IP addresses for MONADAG.
[2010-12-14T13:02:49] MONADAG = [ 192.168.0.178 ].
[2010-12-14T13:02:49] Looking up IP addresses for newexchange.
[2010-12-14T13:02:49] newexchange = [ 2002:f00:1::f00:1, 192.168.0.54, 15.0.0.1 ].
[2010-12-14T13:02:49] Looking up IP addresses for NEWEXCHANGE.mona.local.
[2010-12-14T13:02:49] NEWEXCHANGE.mona.local = [ 2002:f00:1::f00:1, 192.168.0.54, 15.0.0.1 ].
[2010-12-14T13:02:49] DAG MONADAG has 1 servers:
[2010-12-14T13:02:49] DAG MONADAG contains server NEWEXCHANGE2.
[2010-12-14T13:02:49] Updated Progress 'Checking if Mailbox server 'NEWEXCHANGE' is in a database availability group.' 4%.
[2010-12-14T13:02:49] GetRemoteCluster() for the mailbox server failed with exception = An Active Manager operation failed. Error: An error occurred while attempting a cluster operation. Error: Cluster API '" OpenCluster(NEWEXCHANGE.mona.local) failed with 0x424. Error: The specified service does not exist as an installed service" ' failed.. This is OK.
[2010-12-14T13:02:49] Ignoring previous error, as it is acceptable if the cluster does not exist yet.
[2010-12-14T13:02:49] DumpClusterTopology: Opening remote cluster MONADAG.
[2010-12-14T13:02:49] Dumping the cluster by connecting to: MONADAG.
[2010-12-14T13:02:49] The cluster's name is: MONADAG.
[2010-12-14T13:02:49] Groups
[2010-12-14T13:02:49] group: Cluster Group [Cluster Main Group]
[2010-12-14T13:02:49] OwnerNode: NEWEXCHANGE2.mona.local
[2010-12-14T13:02:49] State: Online
[2010-12-14T13:02:49] Resource: File Share Witness [Online, type = File Share Witness, PossibleOwners = NEWEXCHANGE2 ]
[2010-12-14T13:02:49] Resource: Cluster Name [Online, type = Network Name, PossibleOwners = NEWEXCHANGE2 ]
[2010-12-14T13:02:49] NetName = [MONADAG]
[2010-12-14T13:02:49] Resource: IPv4 Static Address 1 (Cluster Group) [Online, type = IP Address, PossibleOwners = NEWEXCHANGE2 ]
[2010-12-14T13:02:49] Address = [192.168.0.178]
[2010-12-14T13:02:49] EnableDhcp = [0]
[2010-12-14T13:02:49] Network = [Cluster Network 1]
[2010-12-14T13:02:49] group: Available Storage [not a CMS]
[2010-12-14T13:02:49] State: Offline
[2010-12-14T13:02:49] Nodes
[2010-12-14T13:02:49] node: NEWEXCHANGE2.mona.local [ state = Up ]
[2010-12-14T13:02:49] Subnets
[2010-12-14T13:02:49] Name(Cluster Network 1), Mask(192.168.0.0/24), Role(ClusterNetworkRoleInternalAndClient)
[2010-12-14T13:02:49] NIC 192.168.0.55 on Node NewExchange2 in State=Up
[2010-12-14T13:02:49] Name(Cluster Network 2), Mask(15.0.0.0/24), Role(ClusterNetworkRoleInternalUse)
[2010-12-14T13:02:49] NIC 15.0.0.2 on Node NewExchange2 in State=Up
[2010-12-14T13:02:49] Opening the cluster on nodes [newexchange2].
[2010-12-14T13:02:50] Other mailbox servers in the DAG are already members of cluster 'MONADAG'
[2010-12-14T13:02:50] The server NEWEXCHANGE does not belong to a cluster, and the other servers belong to MONADAG.
[2010-12-14T13:02:50] Successfully resolved servers based on the AD configuration.
[2010-12-14T13:02:50] The following servers are in the StartedServers list:
[2010-12-14T13:02:50] The following servers are in the StoppedServers list:
[2010-12-14T13:02:50] Verifiying that the members of database availability group 'MONADAG' are also members of the cluster.
[2010-12-14T13:02:50] Verifying that the members of cluster 'MONADAG' are also members of the database availability group.
[2010-12-14T13:02:50] According to GetNodeClusterState(), the server NEWEXCHANGE is NotInstalled.
[2010-12-14T13:02:50] InternalValidate() done.
[2010-12-14T13:02:50] Updated Progress 'Adding server 'NEWEXCHANGE' to database availability group 'MONADAG'.' 6%.
[2010-12-14T13:02:50] Working
[2010-12-14T13:02:50] Updated Progress 'The task is installing the Windows Failover Clustering component on the server NEWEXCHANGE.' 8%.
[2010-12-14T13:03:25] The following log entry comes from a different process, run on machine 'NEWEXCHANGE'. BEGIN
[2010-12-14T13:03:25] [2010-12-14T13:02:50] Updated Progress 'The task is installing the Windows Failover Clustering component on the server newexchange.' 2%.
[2010-12-14T13:03:25] Updated Progress 'The task has installed the Windows Failover Clustering component.' 4%.
[2010-12-14T13:03:25] Working
[2010-12-14T13:03:25] The preceding log entry comes from a different process, run on machine 'NEWEXCHANGE'. END
[2010-12-14T13:03:25] Updated Progress 'The task has installed the Windows Failover Clustering component.' 10%.
[2010-12-14T13:03:25] DumpClusterTopology: Opening remote cluster MONADAG.
[2010-12-14T13:03:25] Dumping the cluster by connecting to: MONADAG.
[2010-12-14T13:03:25] The cluster's name is: MONADAG.
[2010-12-14T13:03:25] Groups
[2010-12-14T13:03:25] group: Cluster Group [Cluster Main Group]
[2010-12-14T13:03:25] OwnerNode: NEWEXCHANGE2.mona.local
[2010-12-14T13:03:25] State: Online
[2010-12-14T13:03:25] Resource: File Share Witness [Online, type = File Share Witness, PossibleOwners = NEWEXCHANGE2 ]
[2010-12-14T13:03:25] Resource: Cluster Name [Online, type = Network Name, PossibleOwners = NEWEXCHANGE2 ]
[2010-12-14T13:03:25] NetName = [MONADAG]
[2010-12-14T13:03:25] Resource: IPv4 Static Address 1 (Cluster Group) [Online, type = IP Address, PossibleOwners = NEWEXCHANGE2 ]
[2010-12-14T13:03:25] Address = [192.168.0.178]
[2010-12-14T13:03:25] EnableDhcp = [0]
[2010-12-14T13:03:25] Network = [Cluster Network 1]
[2010-12-14T13:03:25] group: Available Storage [not a CMS]
[2010-12-14T13:03:25] State: Offline
[2010-12-14T13:03:25] Nodes
[2010-12-14T13:03:25] node: NEWEXCHANGE2.mona.local [ state = Up ]
[2010-12-14T13:03:25] Subnets
[2010-12-14T13:03:25] Name(Cluster Network 1), Mask(192.168.0.0/24), Role(ClusterNetworkRoleInternalAndClient)
[2010-12-14T13:03:25] NIC 192.168.0.55 on Node NewExchange2 in State=Up
[2010-12-14T13:03:25] Name(Cluster Network 2), Mask(15.0.0.0/24), Role(ClusterNetworkRoleInternalUse)
[2010-12-14T13:03:25] NIC 15.0.0.2 on Node NewExchange2 in State=Up
[2010-12-14T13:03:25] Updated Progress 'Windows Failover Clustering is now installed. Running additional checks.' 12%.
[2010-12-14T13:03:25] Updated Progress 'Checking if Mailbox server 'NEWEXCHANGE' is in a database availability group.' 14%.
[2010-12-14T13:03:25] GetRemoteCluster() for the mailbox server failed with exception = An Active Manager operation failed. Error: An error occurred while attempting a cluster operation. Error: Cluster API '" OpenCluster(NEWEXCHANGE.mona.local) failed with 0x6d9. Error: There are no more endpoints available from the endpoint mapper" ' failed.. This is OK.
[2010-12-14T13:03:25] Ignoring previous error, as it is acceptable if the cluster does not exist yet.
[2010-12-14T13:03:25] Opening the cluster on nodes [newexchange2].
[2010-12-14T13:03:25] Other mailbox servers in the DAG are already members of cluster 'MONADAG'
[2010-12-14T13:03:25] The server NEWEXCHANGE does not belong to a cluster, and the other servers belong to MONADAG.
[2010-12-14T13:03:25] Successfully resolved servers based on the AD configuration.
[2010-12-14T13:03:25] The following servers are in the StartedServers list:
[2010-12-14T13:03:25] The following servers are in the StoppedServers list:
[2010-12-14T13:03:25] Verifiying that the members of database availability group 'MONADAG' are also members of the cluster.
[2010-12-14T13:03:25] Verifying that the members of cluster 'MONADAG' are also members of the database availability group.
[2010-12-14T13:03:25] According to GetNodeClusterState(), the server NEWEXCHANGE is NotConfigured.
[2010-12-14T13:03:25] Updated Progress 'Adding server 'NEWEXCHANGE' to the cluster.' 16%.
[2010-12-14T13:13:25] The operation wasn't successful because an error was encountered. You may find more details in log file " C:\ExchangeSetupLogs\DagTasks\dagtask_2010-12-14_13-02-49.066_add-databaseavailabiltygroupserver.log" .
[2010-12-14T13:13:25] WriteError! Exception = Microsoft.Exchange.Cluster.Replay.DagTaskOperationFailedException: A server-side database availability group administrative operation failed. Error: The operation failed with message: Error 0x71a (The remote procedure call was cancelled) from cli_RpccAddNodeToCluster ---> Microsoft.Exchange.Rpc.RpcException: Error 0x71a (The remote procedure call was cancelled) from cli_RpccAddNodeToCluster
at ThrowRpcException(Int32 rpcStatus, String message)
at Microsoft.Exchange.Rpc.RpcClientBase.ThrowRpcException(Int32 rpcStatus, String routineName)
at Microsoft.Exchange.Rpc.Cluster.ReplayRpcClient.RpccAddNodeToCluster(String newNode, String& verboseLog)
at Microsoft.Exchange.Cluster.Replay.ReplayRpcClientWrapper.<>c__DisplayClass26.<RunAddNodeToCluster>b__24()
at Microsoft.Exchange.Cluster.Replay.ReplayRpcClientWrapper.<>c__DisplayClass32.<RunRpcOperationDbName>b__30()
at Microsoft.Exchange.Data.Storage.Cluster.HaRpcExceptionWrapperBase`2.ClientRetryableOperation(String serverName, RpcClientOperation rpcOperation)
--- End of inner exception stack trace -
at Microsoft.Exchange.Data.Storage.Cluster.HaRpcExceptionWrapperBase`2.ClientHandleRpcException(RpcException ex, String serverName)
at Microsoft.Exchange.Cluster.Replay.ReplayRpcClientWrapper.RunRpcOperationDbName(String serverName, String databaseName, Int32 timeoutMs, ReplayRpcClient& rpcClient, IHaRpcExceptionWrapper rpcExceptionWrapperInstance, InternalRpcOperation rpcOperation)
at Microsoft.Exchange.Cluster.Replay.ReplayRpcClientWrapper.RunRpcOperation(String serverName, Nullable`1 dbGuid, Int32 timeoutMs, ReplayRpcClient& rpcClient, IHaRpcExceptionWrapper rpcExceptionWrapperInstance, InternalRpcOperation rpcOperation)
at Microsoft.Exchange.Cluster.Replay.ReplayRpcClientWrapper.RunAddNodeToCluster(AmServerName serverName, AmServerName newNode, String& verboseLog)
at Microsoft.Exchange.Management.SystemConfigurationTasks.AddDatabaseAvailabilityGroupServer.JoinNodeToCluster()
[2010-12-14T13:13:25] Updated Progress 'Done!' 100%.
[2010-12-14T13:13:25] COMPLETED
add-databaseavailabiltygroupserver explicitly called CloseTempLogFile().Ahmad Ramadan AbaYazeed
Thnx For the reply
1- i am sure about the same OSm Sp's on both nodes
2- i alreadr disabled IP V6 on both NIC " Lan & Heartbeat" on both nodes
3- i have Symantec endpoint as an antivirus on both nodes actually i tried to disable and stop all the AV services on the Troubled Node but it didnt work
i will try to Uninstall it from Both nodes and will try again
but in case it didnt work, Dont u have any other ideas or solutions???
C
Chris Morgan -
I wouldnt remove IPv6 from a 2010 box. If it was 2007 yes. But MSFT tests all their applications now with IPv6 enabled. I havent run into a scenario with 2010 yet that I have found to be an IPv6 issue.
Make sure you check the binding order of your NICs as this could cause the issue:
To Check your network binding order on Windows 2008 perform the following:
Click on Start Locate Network and right click, select Properties On the Network and Sharing Center locate Manage network connections and click it On the Menu bar click Advanced and select Advanced Settings Move your Production NIC to the Top. The Private NIC (Heartbeat) should come Second, Remote Access Connections last. (If you"re using ISCSI it should come after the private network) Click OK and you"re done!
Chris Morgan
NIC Binding order is correct on both nodes
the LAN 1st then the Heartbeat
and still the problems exists
AndyD_ [MVP]
Have you run ExBpa against the servers? How about the Windows Firewall ? Is it enabled or disabled?
That error indicates a timeout for some reason.
Another option is to see if you can add the node via the Cluster Tools and then re-run Add-DatabaseAvailbilityGroupServer for that node if that is successful.
(Advice provided as is!) :p
1-no i didnt Run the ExBpa
2- windows Firewall is Enabled and i cannot Disable it coz if i did it i will lose all conectivity
3- do you mean add the node normally from Failover cluster servicev then run the command shell?
actually i didnt do it, but i will do it but in case it didnt work? any other solutions??
AndyD_ [MVP]
1. I would
2. Why would you lose connectivity if you disabled the firewall? And I dont mean stopping the service, I mean disabling it with netsh advfirewall set Allprofiles state off
(assuming domain policies allow. )
3- Yes. With the Failover Cluster Manager or Windows Cluster PS commands
i will try to disable the Windows Firewall as u mentioned and also i will try to manually join the node to the cluster then re-run adding the server to the Dag from Power shell
but why this problem happens? and in case that after doing the above mentioned and didnt work, what would be the solution??????
AndyD_ [MVP]
Well, that I cant answer. If those solutions do not work you do not get any better suggestions here, a call to Microsoft support may be in order.
Justin.King
Quick comment:
The log you dumped just shows the major steps, the actual process it failed on is dumped to:
May want to dig through that for a more definative reason for failure.
the log file that u mentioned is the one that i already showed before above my friendAhmad Ramadan AbaYazeed
G Need help configuring a PRF for Outlook 2010 and 2013 Using Outlook 0
K Excel Import Option: Need Help Updating Existing Records BCM (Business Contact Manager) 0
K Need help concerning emails linking to BCM. BCM (Business Contact Manager) 0
J Need help with installation of BCM in Outlook2013 BCM (Business Contact Manager) 5
F Outlook 2010 - Need help with a custom field. Using Outlook 3
L Need help getting calendar/contacts/tasks/notes back! Using Outlook 3
P Need help/Gmail accounts show separately/Outlook 2013 Using Outlook 0
J Need Help Extracting Email Content into Excel Specifically the Attachment Name Using Outlook 3
A Need Help with BCM2010 Sharing on outlook 2013 Scenario! BCM (Business Contact Manager) 1
W I Need help with vb.net and outlook 2010 Using Outlook 2
A My move to MS is not going too well: Need Help !!! Using Outlook 14
M Need help with combo boxes in messages! Using Outlook 10
D Need help understanding which pst-file to use! Using Outlook 0
U Need a help please Outlook 2007 crashing Using Outlook 2
Z Need Help Outlook 2007 inbox and address book view Using Outlook 2
B Need help adding a background color to the compact list items in Month view. Calendar Printing Assistant 1
B Need help adding an image next to the Month Name in the header. Calendar Printing Assistant 1
B Ok - a complicated one - but really need help (auto formatting) Using Outlook 9
B OUTLOOK 2000, Need Help ! Outlook Wishlist 1
P To Use BCM or not...I need help BCM (Business Contact Manager) 1
T Need help making RULE to prepend email SUBJECT Using Outlook 3
V Need help on configuring Outook 2003 Rules and Alerts... Using Outlook 2
M Need help w/ Calendar Events not appearing in Outlook 2010 Using Outlook 1
D Need help bulk exporting mailboxes Exchange Server Administration 3
N Need Help with Outlook 2010 Using Outlook 1
G Need help in merging data from multiple .pst data files into one .pst file. Using Outlook 3
F Incoming email titles - i need them back (please help...) Using Outlook 2
B Need help with contact recovery, since trial of Office 2010 has ended. Using Outlook 2
M Need Help on Designing Exchange 2010 Email Solution for 4000 Users Exchange Server Administration 1
S OL2007/XP views will not retain settings. Really need some help here. Using Outlook 2
D Need help repairing Outlook 2010. Using Outlook 2
D Need help with word wrap in Outlook 2010. Using Outlook 5
L Windows Instant Search Indexing not working need help reading Event Log Using Outlook 2
N need help retrieving email from previous Outlook Profile Using Outlook 7
