Exchange 2010 CAS/HT/Mailbox moved - best practice/steps for decommissioning 2007
smurfman
Just finished the co-existance steps for Exch 2010 and Exch 2007 in my domain. Moved all the mailboxes, reconfigured HT, verified that all mail is flowing to my new exch 2010 server for about a week now - even found a few notification servers around the network sending SMTP messages to my exchange box.
It has come the time to start thinking about decommissioning the old 2007 box - I do not want it sitting on the network much longer.
Here is my question:
Where would I find the steps I should to shutdown the Exch 2007 box and have it un-registered from the AD - or cold they be outined here for me?
Tom Vanopoulos
If all the mailboxes and Public Folders have been moved over to the Exchange 2010 servers and if you confirmed that all the mail flow is going through Exchange 2010 now.
Then a simple removal from the add\remove programs will uninstall Exchange 2007. This should completely remove the Exchange server from the organization.
You can take a look at the following article.
http://technet.microsoft.com/en-us/library/bb123893(EXCHG.80).aspx
MCITP: Enterprise Messaging Administrator 2007/2010 | MCITP: Server Administrator | MCTS: Windows Server 2008 Applications Infrastructure, Configuring | MCP | MCDST
smurfman
Thanks Tom, apparently from another forum post - there was no way to move the public mailbox folder - so I had to create a new one.
I am not even sure if it was being used.
The link is perfect!
Brian Day MCITP
Don't forget to run ExBPA as it may catch a few things that aren't obvious to do. :)Microsoft Premier Field Engineer, Exchange
MCSA 2000/2003, CCNA
D Exchange 2010 CAS at 2 different Sites Exchange Server Administration 2
S Any system impact if change exchange 2010 CAS/HUB and Mailbox server IP address Exchange Server Administration 1
B Re: Exchange 2007 and CAS from Exchange 2010 problem Exchange Server Administration 15
R Exchange 2010 CAS high availibility cross datacenters Exchange Server Administration 9
Diane Poremsky Organizational Forms Library in Exchange 2010 New Slipstick.com Articles 0
V Recover exchange 2010 edb Exchange Server Administration 2
T Renaming an Resource in Exchange 2010 Exchange Server Administration 1
P Outlook 2010 MS Exchange Calendar to Android- ical or webdav? Using Outlook 1
Fozzie Bear Outlook 2010 or 2013 Dual Configuration Exchange + IMAP Exchange Server Administration 6
H In Exchange 2010, how to block an email containing an attachment that has foreign characters Exchange Server Administration 1
N Outlook 2010 exchange - auto-move emails from @domain Exchange Server Administration 1
V Outlook 2013 cant stay connected to exchange 2010 Exchange Server Administration 5
R Exchange 2013/Outlook 2010 Slow Startups Exchange Server Administration 8
Z Outlook 2010 client to Exchange ,,,,search not working proparly Exchange Server Administration 0
M First post -help with managing two calendars Outlook 2010 /Exchange 2010 Using Outlook 0
T Outlook INBOX emails gone back 2-3 weeks after Exchange Server 2010 Restart Using Outlook 0
C Outlook 2010, two exchange mailboxes configured.Unable to see 2ndrymeeting req Using Outlook 2
C Exchange 2010 / Emails received show with display name and not email address Using Outlook 2
S Unable to send or reeceive email in new Exchange 2010 Exchange Server Administration 0
B Sharing Multiple Outlook 2010 Calendars (Exchange) Exchange Server Administration 4
P can't set IRM configuration in Exchange 2010 Exchange Server Administration 2
B Using hosted exchange to sync outlook 2010 calendars and contacts to BB Z10 Using Outlook 4
S Outlook 2010/Exchange 2010 Multi Mailboxes (Server unavailable) Using Outlook 6
D why do exchange contacts not sync properly from outlook 2011 to outlook 2010 Exchange Server Administration 2
J Exchange 2010 free/busy shows hashmarks in scheduling tab when not organizer Exchange Server Administration 6
C Exchange 2010 - Outlook 2010 - Exchange Server Administration 4
Fozzie Bear Outlook 2010 wont remember Exchange Credentials on log off /shutdown of Win7 Exchange Server Administration 2
T Exchange 2010: 'could not save item' and 'Unknown error' when edit calendars Exchange Server Administration 1
I Shared Contacts in Outlook 2010 and Exchange Server 2010 Using Outlook 4
J OL2003 Public Folder Sync Errors w/ Exchange 2010 Exchange Server Administration 11
B Outlook 2010 won't configure exchange account, 0kb .ost file Exchange Server Administration 5
R Thousand of sync issues on Outlook clients with Exchange 2010 Exchange Server Administration 5
R Create a contacts list on Exchange 2010 Exchange Server Administration 10
T Exchange / Outlook 2010 - How to cancel meetings but retain the calendar entry Using Outlook 4
S Outlook Quick Steps - Exchange 2003 / Exchange 2010 Exchange Server Administration 2
