Exchange 2010 upgrade with SP1, language pack issue
G
GerhardW
I have an Echange 14.0 (Build639.21) and try to upgrade it to Exchange SP1. I originally installed straight from the DVD selecting the option language packs for the DVD. I did not install Uniformed Messaging role on any server.
When running the upgrade to Exchnage SP1 I get errors on the readiness check:
Error:
Language packs are installed on this server and must be upgraded with the Exchange binaries. Please specify a language bundle with the upgrade operation.
Click here for help... http://technet.microsoft.com/en-US/library/ms.exch.err.default(EXCHG.141).aspx?v=14.1.218.11&e=ms.exch.err.Ex28883C&l=0&cl=cp
I was reading for hours through technet and other posts and can not figure this out and how to handle the issue.
Any advise is greatly appreciated.
AndyD_ [MVP]
When you run the SP1 install, what happens if you choose to install all the languages?
G
GerhardW
Well when selecting all the languages and then downloading from the website the language pack got the upgrade going.
Just for interest, why did this change it?
Gerhard Waterkamp ACSLA Inc.
AndyD_ [MVP]
Not sure if something changed, but I recommend installing all the languages simply because it takes a small footprint on disk and there are no performance considerations.
B Re: Upgrade windows server 2008 std R2 to Windows server 2008 Ent R2 with exchange 2010 Exchange Server Administration 1
D Ms Exchange 2010 - Sp1 Upgrade at Prerequisites on Hub Transport Role Exchange Server Administration 8
M how to upgrade exchange 2010 to exchange 2010 sp1 Exchange Server Administration 2
M Cant get Exchange 2010 Update Roll up 4 to install. Error: the upgrade patch cannot be installed by Exchange Server Administration 8
L Since Exchange 2010 SP1 upgrade, Mail Submission service is restarting every 24 hours in the early m Exchange Server Administration 11
I Exchange 2010 UCM not accepting calls from Nortel CS 1000 after upgrade to SP1 Exchange Server Administration 1
J Exchange 2010 UCM rejecting calls from CUCM 7x after SP1 upgrade Exchange Server Administration 10
J Re: MSExchange ADAccess 2937 Validation after Exchange 2010 RTM -> SP1 upgrade Exchange Server Administration 9
Diane Poremsky Organizational Forms Library in Exchange 2010 New Slipstick.com Articles 0
V Recover exchange 2010 edb Exchange Server Administration 2
T Renaming an Resource in Exchange 2010 Exchange Server Administration 1
P Outlook 2010 MS Exchange Calendar to Android- ical or webdav? Using Outlook 1
Fozzie Bear Outlook 2010 or 2013 Dual Configuration Exchange + IMAP Exchange Server Administration 6
H In Exchange 2010, how to block an email containing an attachment that has foreign characters Exchange Server Administration 1
N Outlook 2010 exchange - auto-move emails from @domain Exchange Server Administration 1
V Outlook 2013 cant stay connected to exchange 2010 Exchange Server Administration 5
R Exchange 2013/Outlook 2010 Slow Startups Exchange Server Administration 8
Z Outlook 2010 client to Exchange ,,,,search not working proparly Exchange Server Administration 0
M First post -help with managing two calendars Outlook 2010 /Exchange 2010 Using Outlook 0
T Outlook INBOX emails gone back 2-3 weeks after Exchange Server 2010 Restart Using Outlook 0
C Outlook 2010, two exchange mailboxes configured.Unable to see 2ndrymeeting req Using Outlook 2
C Exchange 2010 / Emails received show with display name and not email address Using Outlook 2
S Unable to send or reeceive email in new Exchange 2010 Exchange Server Administration 0
B Sharing Multiple Outlook 2010 Calendars (Exchange) Exchange Server Administration 4
P can't set IRM configuration in Exchange 2010 Exchange Server Administration 2
B Using hosted exchange to sync outlook 2010 calendars and contacts to BB Z10 Using Outlook 4
S Outlook 2010/Exchange 2010 Multi Mailboxes (Server unavailable) Using Outlook 6
D why do exchange contacts not sync properly from outlook 2011 to outlook 2010 Exchange Server Administration 2
J Exchange 2010 free/busy shows hashmarks in scheduling tab when not organizer Exchange Server Administration 6
C Exchange 2010 - Outlook 2010 - Exchange Server Administration 4
Fozzie Bear Outlook 2010 wont remember Exchange Credentials on log off /shutdown of Win7 Exchange Server Administration 2
T Exchange 2010: 'could not save item' and 'Unknown error' when edit calendars Exchange Server Administration 1
I Shared Contacts in Outlook 2010 and Exchange Server 2010 Using Outlook 4
J OL2003 Public Folder Sync Errors w/ Exchange 2010 Exchange Server Administration 11
B Outlook 2010 won't configure exchange account, 0kb .ost file Exchange Server Administration 5
R Thousand of sync issues on Outlook clients with Exchange 2010 Exchange Server Administration 5
R Create a contacts list on Exchange 2010 Exchange Server Administration 10
T Exchange / Outlook 2010 - How to cancel meetings but retain the calendar entry Using Outlook 4
S Outlook Quick Steps - Exchange 2003 / Exchange 2010 Exchange Server Administration 2
R Sharing Exchange 2010 calendars with people outisde our organization Exchange Server Administration 17
