Exchange OWA 2010 acting quirky.
  • Thread starter Michael R. Mastro II
  • Start date
I am having a wierd problem with OWA 2010. When trying to use it from two machines external to the domain it does two different things. The first machine is a 32-bit laptop running Windows 7 Ultimate with IE8. This works when connecting to OWA and has no problems, even when I went to IE9 it had no problems. The other machine is a 64 bit desktop running Windows 7 Ultimate x64 with IE8. When I try to use OWA with this computer it goes to this:
Error Code: 403 Forbidden. The server denied the specified Uniform Resource Locator (URL). Contact the server administrator. (12202)
Now at first I figure it was IE issue, so I checked the settings side-by-side of both computers, IE is set up exactly the same. I am using the same URL on both so why does one work and the other not work? I am fine that the laptop works, it means I can travel and not have to worry.
The other issue is prior to getting OWA to work right with TMG and publish outside the network, OWA worked fine internally, bringing up the OWA form to login. Now that it works externally, it will not work internally. It brings up the Windows Identity prompt then fails for a corruption. Is this a setting, gone awry? Looking at the Exchange 2010 CAS server it shows OWA for Basic authentication as the only thing checked, same for ECP.
C
Christian Weihs
Jonas Andersson [MCITP]
S Signature size limit for OWA / Exchange 2010 Exchange Server Administration 10
M Exchange 2010 OWA Redirect with Authentication Across AD Site Exchange Server Administration 1
M Integrated OCS with Exchange 2010 OWA didn't work over ISA server Exchange Server Administration 4
M Exchange 2010 OWA '403 Access Denied' Exchange Server Administration 3
D Exchange 2010 SP1 OWA "reply" or "forward" error Exchange Server Administration 3
A OWA redirection in exchange 2010 and 2003 Exchange Server Administration 1
F Exchange 2010 - OWA 15 min auto logoff Exchange Server Administration 1
K exchange 2010 OWA and exchange 2003 coexist Exchange Server Administration 1
à owa and powershell take times on exchange 2010 Exchange Server Administration 8
S Exchange 2010 OWA Search only returns 2 days worth Using Outlook 2
A Exchange 2007 <-> 2010 OWA not working together redirecting problem Exchange Server Administration 1
D Is there a way to turn off "group by conversation" by default in OWA Exchange 2010? Using Outlook 2
S Exchange 2010 SP1 OWA Error Exchange Server Administration 2
T Exchange 2010: attachments are not visible in outlook, but visible in OWA Using Outlook 1
Z Exchange 2007 Transitioning to Exchange 2010 SP 1, and OWA User Redirect or Proxying Exchange Server Administration 1
S Exchange 2010 - owa/auth.owa Bad Request Exchange Server Administration 3
Y public calendar using OWA on exchange 2010 Exchange Server Administration 7
T After updating Exchange 2010 from RTM to SP1, OWA clients cannot move or delete emails Using Outlook 4
S Exchange 2010 owa https not working Exchange Server Administration 5
J Exchange 2010 / 2003 OWA Problem Exchange Server Administration 2
K Some user cannot delete email in OWA Exchange 2010 SP1 Exchange Server Administration 5
A Cannot delete mail in OWA only after upgrading Exchange Server 2010 to SP1 Exchange Server Administration 30
J Unable to access public folders in Outlook 2007 on Exchange 2010. OWA PF works fine Using Outlook 7
M No more blue OWA default theme (Exchange 2010) Exchange Server Administration 8
E Java script issue OWA Exchange 2010 Exchange Server Administration 5
R Exchange 2010 RC OWA can't login Exchange Server Administration 29
1 mobile OS or apps for sync of all OWA/exchange PIM functions Exchange Server Administration 3
G Installing an email cert into Exchange OWA Exchange Server Administration 6
T OWA No Longer Accessible from outside my Exchange Server Using Outlook 5
M Inbox is not syncing correctly between OWA and Windows 7 Client with Exchange 2003 Using Outlook 4
S OWA in Exchange 20120 not working after installing a new certificate and applying SP1 Exchange Server Administration 1
P Blank page opening document through Direct Access in OWA from Exchange 2007 SP3 Using Outlook 3
A cannot access OWA or connect to exchange 2007 via outook. Using Outlook 5
