Exchange 2010 Configuration Question Internal Domain for External Clients
  • Thread starter BrettFavre4President
  • Start date
We I have recently installed Exchange 2010 on a Windows Server 2008 R2 Edition Server. Everything seems to be fine, I can configure clients using Autodiscover with no errors, and if I go to testexchangeconnectivity.com it passes the tests (there is an error but not sure if it says it passed the tests.
If I configure outlook on another computer externally (ie at my house), I still can use autoconfigure using the settings, but when I view the settings in Outlook of the configuration it shows the server as being Exchange.domain.local instead of exchange.domain.com . I have been unable to find if this is a problem, and also where to fix it.
This same server name configures when I try to set it up on a mobile phone, it is successfull, but when I look at those settings it appends a .local instead of the exchange.domain.com address.
I tried to add a DNS record to the server earlier today but that did not make a difference, but I am not sure if that is something that takes a while to update.
Can someone help me with this?
Sembee [MVP]
The behaviour you are seeing is correct. Outlook will show the real server name where your mailbox is located (or the CAS server, or the CAS array, depending on your topology).
If you want to use Exchange outside your network then you should configure Outlook Anywhere. That will use a public URL.
Simon.
Simon Butler, Exchange MVP
Blog | Exchange Resources
I believe that I had tried to configure outlook anywhere, that is what we want people to use (that is the RPC over http correct?) .
Outlook Anywhere is enabled, we want people to use the rpc over http for the connection, and the settings seem to configure correctly everywhere else, if I look at connection settings after autoconfig, it shows the correct msstd:exchange.domain.com, basic authentication, so it seems like that is working, but we are unable to get the server name to show anything other than .local, and it seems like that would cause a problem for some external users.
Sembee [MVP]
As I have already said, the server name being the internal name will NOT be a problem. That is how it is designed to work.
Run the Outlook Anywhere test. If that is successful then you should be able to connect.
Simon.
Ok, that sounds good, I don't know exactly what the outlook anywhere test is, but I was just worried about the internal domain name showing up, but it sounds like it's 100% normal, so I will trust that. Thanks for the reply, I really appreciate it.
ON a side note, when I created my name yesterday, I should've chosen something cooler than Brett Favre 4 President...especially this year.
Allen Song
Yes, that's normal. It's the CAS name which configured as RPCClientAccessServer attribute on the Mailbox Database.
Allen
Allen Song
Fozzie Bear Outlook 2010 or 2013 Dual Configuration Exchange + IMAP Exchange Server Administration 6
P can't set IRM configuration in Exchange 2010 Exchange Server Administration 2
A NetBackup 7.0 configuration for Exchange 2010 SP1 Exchange Server Administration 3
K Exchange 2010 Health explorer on configuration, performace & security state is blank Exchange Server Administration 2
C Outlook 2010 configuration issue "exchange server is unavailable. Using Outlook 4
R Exchange 2010 setup failed: The application has failed to start because its side-by-side configuration is incorrect. 0x800736B1 Exchange Server Administration 3
Diane Poremsky Organizational Forms Library in Exchange 2010 New Slipstick.com Articles 0
V Recover exchange 2010 edb Exchange Server Administration 2
T Renaming an Resource in Exchange 2010 Exchange Server Administration 1
P Outlook 2010 MS Exchange Calendar to Android- ical or webdav? Using Outlook 1
H In Exchange 2010, how to block an email containing an attachment that has foreign characters Exchange Server Administration 1
N Outlook 2010 exchange - auto-move emails from @domain Exchange Server Administration 1
V Outlook 2013 cant stay connected to exchange 2010 Exchange Server Administration 5
R Exchange 2013/Outlook 2010 Slow Startups Exchange Server Administration 8
Z Outlook 2010 client to Exchange ,,,,search not working proparly Exchange Server Administration 0
M First post -help with managing two calendars Outlook 2010 /Exchange 2010 Using Outlook 0
T Outlook INBOX emails gone back 2-3 weeks after Exchange Server 2010 Restart Using Outlook 0
C Outlook 2010, two exchange mailboxes configured.Unable to see 2ndrymeeting req Using Outlook 2
C Exchange 2010 / Emails received show with display name and not email address Using Outlook 2
S Unable to send or reeceive email in new Exchange 2010 Exchange Server Administration 0
B Sharing Multiple Outlook 2010 Calendars (Exchange) Exchange Server Administration 4
B Using hosted exchange to sync outlook 2010 calendars and contacts to BB Z10 Using Outlook 4
S Outlook 2010/Exchange 2010 Multi Mailboxes (Server unavailable) Using Outlook 6
D why do exchange contacts not sync properly from outlook 2011 to outlook 2010 Exchange Server Administration 2
J Exchange 2010 free/busy shows hashmarks in scheduling tab when not organizer Exchange Server Administration 6
C Exchange 2010 - Outlook 2010 - Exchange Server Administration 4
Fozzie Bear Outlook 2010 wont remember Exchange Credentials on log off /shutdown of Win7 Exchange Server Administration 2
T Exchange 2010: 'could not save item' and 'Unknown error' when edit calendars Exchange Server Administration 1
I Shared Contacts in Outlook 2010 and Exchange Server 2010 Using Outlook 4
J OL2003 Public Folder Sync Errors w/ Exchange 2010 Exchange Server Administration 11
B Outlook 2010 won't configure exchange account, 0kb .ost file Exchange Server Administration 5
R Thousand of sync issues on Outlook clients with Exchange 2010 Exchange Server Administration 5
R Create a contacts list on Exchange 2010 Exchange Server Administration 10
T Exchange / Outlook 2010 - How to cancel meetings but retain the calendar entry Using Outlook 4
S Outlook Quick Steps - Exchange 2003 / Exchange 2010 Exchange Server Administration 2
R Sharing Exchange 2010 calendars with people outisde our organization Exchange Server Administration 17
A Exchange 2010 Outlook 2010 and Local Failures sync issue Exchange Server Administration 5
B Exchange 2010 / Outlook 2010 - Group Folder issues Exchange Server Administration 6
U Exchange 2010 & mailbox database Quotas Exchange Server Administration 1
T Outlook 2010/Exchange 2003: Meeting Organizer doesn't show Using Outlook 1
