Getting Autodiscover to work with other web servers ...
C
ckoeber
We have a Microsoft Exchange 2007 setup and everything works great except for Autodiscover.
When an external client tries to connect to domain.com/Autodiscover/autodiscover.xml, a problem arises since this doesn't exist on our main web server. Our autodiscover URL is (autodiscover.domain.com/autodiscover/autodiscover.xml)
So, in turn, clients (especially PDAs and Smartphones) cannot connect without using the manual setup.
Does the main web system just need to host the files from the Autodiscover directory on Exchange? Or is there another route to set up clients so that when the PDA/Smartphones perform an autodiscovery that they get sent to the right place?
Regards,
Christopher Koeber
Regards, Christopher K.
Sembee [MVP]
Autodiscover should go through a number of URLs before failing completely. The root domain is just one of them. Certainly I have the root domain pointing to my public web site and autodiscover works fine. There is no need to have the autodiscover content on the main web server - you couldn't do that even if you wanted to because the file is generated on the fly from the Exchange information.
Do you have autodiscover.example.com in your SSL certificate as one of the additional names?
Run a test account through the autodiscover test at exrca.com.
Simon.
Simon Butler, Exchange MVP
Blog | Exchange Resources
C
ckoeber
Simon.
I ran the test through the exrca.com service and it passed.
However, when I try and add an account through my PDA (for Andriods, as an example) the mail server field defaults to the main web server.
Is there a redirection file I can put on may main web server to point to my Exchange installation?
Sembee [MVP]
I don't know if the Andriod devices properly observe the autodiscover process. I know Windows Mobile devices do, but third parties do not always implement the full ActiveSync protocol.
The only redirect method that Microsoft have provided is this:
http://technet.microsoft.com/en-us/library/bb310764(EXCHG.80).aspx
However that is unlikely to be possible for you to implement.
If things work though the Microsoft test then it must be a limitation of the Andriod.
Simon.
C
ckoeber
Simon.
Thanks. I discovered via two threads which I will list below that the problems are indeed limited to the devices and not my setup.
I'll just send people within my organization a set of instructions for now and wait for the other devices to be fixed via patches on their end.
Link one: http://arstechnica.com/phpbb/viewtopic.php?f=17&t=1115589 (This is marked Exchange 2010 but applies to Exchange 2007 as well)
Link two: http://www.stevieg.org/2010/01/solving-iphone-and-exchange-20102007-coexistance-issues/
Regards,
Christopher Koeber
P PST file is getting huge under POP 3 Using Outlook 2
D Close Oulook after sending emails via vba without outbox getting stuck. Outlook VBA and Custom Forms 1
C im getting a type mismatch error Outlook VBA and Custom Forms 3
William getting custom form to load category colors Outlook VBA and Custom Forms 4
C Getting back previous computer owner Outlook email Using Outlook.com accounts in Outlook 1
B Recipient of a forwared message getting multiple emails Using Outlook 2
S Mails getting downloaded multiple times Using Outlook 1
Rory Campion Not getting a warning when a shared calendar item has been updated by someone else Using Outlook 2
E Getting IMAP email into existing pst file Using Outlook 6
J Just installed Outlook 2010 on computer and user is getting a 0x80004005 error Using Outlook.com accounts in Outlook 1
R Getting a colleagues appointments and calendar entries Using Outlook 1
E Getting Outlook full name correct with AddressLayout Using Outlook 1
P I'm getting an error when opening Outlook "Mobile me stopped working Using Outlook 1
D Help Getting Started? BCM (Business Contact Manager) 4
P I am getting an error msg = cannot open file access denied Using Outlook 3
K why is a user getting email respond for invite respond that she didn't set up. Using Outlook 3
B email getting cut off Using Outlook 9
L Need help getting calendar/contacts/tasks/notes back! Using Outlook 3
M Email Format getting changed to Plain Text Using Outlook 1
M Getting messages from multiple email address Using Outlook 1
B not getting email from people Using Outlook 3
L Outlook 2010 - Keep getting "Corrupted File" Msgs Using Outlook 4
Commodore Why some RSS feeds stop getting updates? Using Outlook 12
M All e mails seem to be getting blocked BCM (Business Contact Manager) 7
J Send/receive getting stuck Using Outlook.com accounts in Outlook 1
R Getting my Claendar additions to appear in Outlook Today Using Outlook 7
J Getting Contact Name to show on Calendar Using Outlook 2
D outlook getting stuck receiving Using Outlook 1
K Getting default beep when permanently deleting email even though sound is turned off Using Outlook 1
C IN MY 2007 OUTLOOK. Problem getting OUTBOX to SEND E-Mails Using Outlook 2
B Getting: Your Out of Office settings cannot be displayed, because the server is currently unavailable. Try again later. Using Outlook 0
T PST file keeps getting corrupted Using Outlook 3
S I keep getting a not responding message and a gray screen__when i change folders Using Outlook 3
O I suddenly can't open Outlook after getting a microsoft automatic update. Using Outlook 2
H getting error code 0x800ccc18 when sending/receiving e-mails Using Outlook 2
M Upgrading HUB 2010 to SP1, getting error "There should only be a single RMS Shared Identity user" Exchange Server Administration 1
L I am getting error code OX800CCC78 when I try to send and email in Outlook 2003 Using Outlook 1
S Outlook 2010 Meeting Requests getting stuck in drafts folder Using Outlook 1
S Email are getting saved in to draft folder while send from OWA 2010 runing on exhange server 2010 Exchange Server Administration 4
E Getting all items in Outlook contact activities to display properly Using Outlook 2
X Not getting new move request exchange 2010 Exchange Server Administration 1
D Outlook 2003 is getting an error when trying to open an exchange 2010 mailbox Exchange Server Administration 5
Y MICROSOFT OUTLOOK 2007 - i KEEP GETTING THE "ENTER NETWORK PASSWORD" BOX POPPING UP - IT IS ALREADY Using Outlook 4
