Autodiscover accounts on exchange 2003 with Outloook 2010 not working
Jamie Baldanza
I have been looking at ways to get autodiscovery working within Outlook 2010 when a mailbox is stored on Exchange 2003. We have both Exchange 2003 and Exchange 2010. The mailboxes on Exchange 2010 work fine with autodiscover when using Outlook 2007 or Outlook 2010. However, if the mailbox is on Exchange 2003, Outlook 2010 does not work while Outlook 2007 does. Any reason as to why or any advice?
Allen Song
For the Outlook 2010 with mailbox on the Exchange 2003, it still uses the standard Autodiscover to run. Since it's Exchange 2003, the Autodiscover will be failed when doing the Autodiscover order, finally it will use Exchange mailbox server property.
The order of operations for Autodiscover settings discovery is summarized as follows:
1.Automatically retrieve e-mail address from Active Directory if domain joined machine (Outlook AutoDetect Mechanism)
2.Retrieve Exchange Server name if found and store for later.
3.Look for SCP objects or SCP pointer objects that correspond to user"s e-mail address, and find the correct Autodiscover server to connect to; then connect and retrieve settings.
4.If previous step fails, attempt DNS discovery of Autodiscover XML (allowing for 10 redirects).
a.HTTPS POST: https://DOMAIN/autodiscover/autodiscover.xml
b.HTTPS POST: https://autodiscover.DOMAIN/autodiscover/autodiscover.xml
c.HTTP GET: http://autodiscover.DOMAIN/autodiscover/autodiscover.xml (only to follow redirects, not to get settings)
d.DNS SRV lookup: _autodiscover._tcp.DOMAIN (only to follow the redirect the SRV record points to)
5.If previous step fails, attempt local XML discovery and use XML found on the local machine if applicable.
6.If previous step fails but an Exchange Server name is found in step 2, configure Exchange account based on Exchange Server name.
Now what do you mean Outlook 2010 doesn't work like Outlook 2007 does? Are the user account and email address come up automatically?
Allen
Allen Song
Jamie Baldanza
When testing, I found that Outlook 2007 with an account on Exchange 2003 autodiscovers and inserts the correct account and email address fine. However, if its a new PC with Outlook 2010 and my account on Exchange 2003 it fails and errors out asking for users to insert the server and user name.
Allen Song
Is this issue only occurred on the new PC? If that is, that should be the PC issue.
To fill up the information with the user name and email address, it uses the Outlook AutoDetect mechansim not Autodiscover. Outlook looks up the Active Directory contact object for the user who is logged in, then extracts the primary SMTP address. This information – if available – is pre-populated in the Outlook Add new e-mail account dialog box.
This feature is the below registry:
KEY: HKEY_CURRENT_USER\Software\Microsoft\Office\12.0\Outlook\Preferences
DWORD: ExchangeAddressDetect
Values: 1 (or missing DWORD) =perform AD lookup
0=no AD lookup
Allen
Allen Song
Jamie Baldanza
That was not the issue. I am unable to come up with a solution so I created a custom script that runs during startup to import an outlook.pcf file into that propagates the Exchange 2003 server and username.
Thanks anyway.
B AutoDiscover Forensics Exchange Server Administration 0
EXChange2013 Exchange 2013 AutoDiscover Tweaks? Exchange Server Administration 0
M Outlook 2007 AutoDiscover Using Outlook 0
A Exchange Autodiscover SSL issue Exchange Server Administration 7
M Initial Outlook Configuration with AutoDiscover populates wrong email address Using Outlook 5
N Outlook 2007 Clients Pointed to Wrong Domain Name for Autodiscover Using Outlook 2
K testing autodiscover and exchange coexistence Exchange Server Administration 2
C The Autodiscover service couldn't be located. Exchange Server Administration 8
C Exchange server 2010 error "The Autodiscover service couldn't be located." Exchange Server Administration 1
Z Autodiscover Points to defunct Exchange 2010 Server Exchange Server Administration 5
M Autodiscover not configuring Outlook Anywhere Using Outlook 10
B Autodiscover error 0x800c8203 and encrypted connection is not available Exchange Server Administration 3
P Autodiscover URLs Exchange Server Administration 15
C Autodiscover Exchange Server Administration 6
I Exchange 2010 Profile AutoDiscover not working for some users Exchange Server Administration 1
S Exhcange 2010 autodiscover virtual directory Exchange Server Administration 4
D External Autodiscover Exchange Server Administration 3
S Exchange 2010 Autodiscover Problems, cannot connect Outlook clients using Autodiscover / Outlook Any Exchange Server Administration 4
G Exchange 2010/Outlook 2007 Can't get autodiscover to work for some users, but others work fine Exchange Server Administration 3
S Autodiscover issue Exchange 2007 Using Outlook 4
P Autodiscover will not work Exchange Server Administration 13
K Exchange 2010 Autodiscover Exchange Server Administration 1
P Autodiscover fails (Exchange 2010) Exchange Server Administration 7
P Autodiscover issues on Exchange 2010 Exchange Server Administration 7
S Exchange 2010 Outlook 2010 Autodiscover fails Exchange Server Administration 22
C Getting Autodiscover to work with other web servers ... Using Outlook 4
C Autodiscover Service Configuration Exchange Server Administration 5
B move mailbox- autodiscover Exchange Server Administration 25
T Autodiscover authentication Exchange Server Administration 2
A autodiscover issue with OL2010 but no issue with OL2007 Exchange Server Administration 10
K Autodiscover and SRV records Using Outlook 10
S Autodiscover redirected Using Outlook 2
C Autodiscover Exchange Server Administration 5
S Autodiscover two AD sites two cas arrays Exchange Server Administration 4
O Autodiscover Exchange Server Administration 4
S Autodiscover FQDN certificate for secondary domain email? Exchange Server Administration 1
K Remove AlternativeMailbox - Autodiscover Exchange Server Administration 5
S Exchange 2010 autodiscover Exchange Server Administration 4
R Autodiscover virtual directory - recreation fails Exchange Server Administration 1
A share one record for autodiscover between exch 2007 and exch 2010 Exchange Server Administration 4
O SSL certificate needed for autodiscover.domain.com Exchange Server Administration 12
C Windows 7/Outlook 2010 vs Windows XP/Outlook 2007 - Autodiscover authentication looping Using Outlook 1
