Is there a way to turn off "group by conversation" by default in OWA Exchange 2010?
DonNels
As most are well aware, Exchange 2010 OWA has the " group by conversation" view turned on by default. While some users might find this view useful, we do not want it set this way automatically because it will be confusing to many users expecting the old normal means of email. I'd done some searching, and found that the ability to change the default behavior was supposed to be added in with SP1. I have SP1 installed, but can not find any way to change this behavior using web app mailbox policies. Did this ability get included with SP1, and if so how can I make use of it? If not, does anyone know of a way to change this default behavior through any means at all?
G
Gen Lin
I searched for this problem but cannot find a method to disable the " group by conversation" . I also wanted to use OWA policy to disable this feature, but there is no option to do this.
N How to turn off autocorrect in contact notepads Using Outlook 2
A Stop Rule (not turn off) that Delays Outgoing Items Outlook VBA and Custom Forms 1
A Emails automatically forwarding but no rule to turn off Using Outlook 2
O How to turn off the prompt to permanently delete messages upon exiting? Using Outlook 2
J Turn off reminders for appointments that have already happened Using Outlook 1
R Turn off greetings in auto attendant Exchange Server Administration 1
A Can I turn off Word as the email editor in Outlook 2010? Using Outlook 2
J Any way to turn off message count in Deleted Items folder (Outlook 2010)? Using Outlook 1
I Turn off auto- delete Using Outlook 2
W Turn off "Replace text as you type" in Outlook 2010 Using Outlook 2
K Does anyone know how to turn off auto capitalization in Outlook 2007 running on Windows 7? Using Outlook 6
S How do I turn off logging in 'Sync Issues' folder in Outlook 2007? Using Outlook 2
W Outlook Desktop alert, notification, popup - turn off programattic Outlook VBA and Custom Forms 1
E Turn application visibility off Outlook VBA and Custom Forms 2
R How do I turn off the Business Contact Manager startup in Outlook BCM (Business Contact Manager) 1
H How turn off outlook security warning dialog box from outlook Outlook VBA and Custom Forms 1
V turn off shared calender reminders/leaving personal calender remin Using Outlook 7
K Appointments turn into meeting requests Using Outlook 0
D Can't find folders that turn up in search Using Outlook 3
K Outlook 2010 won't work with FSNET/Orange service? Turn to MS Mail Using Outlook 4
J email Folders, needing to have main folders turn bold when subfolders receive mail. Using Outlook 1
C SQLDUMPER library does not turn on correctly when the computer isturned on each time. BCM (Business Contact Manager) 1
A turn Outlook into a Drag-and-drop application Outlook Wishlist 2
N Wishlist Opening Outlook where we left off Outlook Wishlist 0
P Appointment times are off by one minute Using Outlook 1
J Leave mail on server when Outlook off Using Outlook 0
P printing weekly calendar in Outlook 2013 cuts days of week off Using Outlook 1
Dan Badur How can I keep indenting OFF on replies in Outlook 2013? Using Outlook 1
V Open Outlook Calendar and Tasks views with Folder pane off Using Outlook 2
R Email Send & Receive Turned off but sends automatically anyway Using Outlook 1
S categories are being cut off after selecting from category pop up form Using Outlook 3
B email getting cut off Using Outlook 9
V Using Outlook 2013 Off Line Using Outlook 5
M Turning on/off Rules from VBA Using Outlook 2
M My Outlook notifications are off by 25 minutes Using Outlook 0
J OL2010 Create a new task while off line Exchange Server Administration 3
B Looking for an add-in or a way to send automatic replies based off a list Using Outlook 2
T Calendar sync off by 1 hour - outlook 2010 / icloud 2.1 / ipad Using Outlook 2
J Outlook 2010 - Use off line Using Outlook 2
Fozzie Bear Outlook 2010 wont remember Exchange Credentials on log off /shutdown of Win7 Exchange Server Administration 2
B Fonts cut off when composing new email on outlook 2007 Using Outlook 1
J CPA cuts off left edge of printed Calendar. Ex. January the J is cut off. Calendar Printing Assistant 11
P Time Off Request - not posting to public folder once approved Using Outlook 0
B Recurring meeting times off by several hours Exchange Server Administration 5
