Exchange ActiveSync HTTP 500 Exchange CAS/HUB 2007 and Exchange 2003 BE & MBX CCR 2007
MaliStane
Exchange ActiveSync HTTP 500 Exchange 2007 $ 2003
OWA and related services work ok, only ActiveSync, does not work ?
If I run : testexchangeconnectivity.com
Test-ActiveSyncConnectivity -MailboxCredential $cred | fl
ScenarioDescription : Issue an HTTP OPTIONS command to retrieve the Exchange ActiveSync protocol version.
PerformanceCounterName : DirectPush Latency
Result : Failure
Error : [System.Net.WebException]: The remote server returned an error: (500) Internal Server Err
Set-EventLogLevel 'MSExchange ActiveSync\Requests' -Level Expert
Set-EventLogLevel 'MSExchange ActiveSync\Configuration' -Level Expert
No logs !
Users are not in any special AD group, and all have inherited… I create new user in new OU, no help…
Status :
At the morning I have remove FE Exchange 2003 server, I uncheck these is front end Exchange server. Rebooted server. After rebooted some services does not start, but I do not thing that is related. DNS points now to Exchange 2007 . OWA work perfectly, auto discovery for outlook work externali and internal. But ActiveSync has stopped. Users have setup with their mobile phone direct VPN link in to internal network. They use IP of Exchange 2003 BE server where mailbox reside. Til these morning it works, but now it doesn't. If I setup new mailbox in new Exchange 2007 server, Activ sync does not work. Error is the same as for users on BE exchange server, that has mailboxes ther.
I have become little stuck, with solution ?
Have any one any idea, where I`m missing a hint.
I had redirection so HTTS:\\webmail.maydomin.com point to https\\webmail.maydomain.com\exchange, so that solution work perfectly with Exchange 2003 servers, but problem is the same if redirections active or is not.
PMR0001 Exchange cf Exchange ActiveSync Exchange Server Administration 1
A Unable to send with attachments in Outlook 2013 (Exchange ActiveSync) Using Outlook 2
B Outlook syncing -- Outlook 365 and Sky Drive and Exchange ActiveSync Using Outlook 0
J Exchange 2010 + Disable ActiveSync/Outlook Anywhere/POP/IMAP/ By Default Exchange Server Administration 5
O Exchange Activesync gives support code: 0x86000c01 after Exchange Server Migration Using Outlook 4
M Startcom SSL certificate not working for Exchange 2010 Activesync Exchange Server Administration 3
R Outlook support for Exchange ActiveSync protocol Using Outlook 1
C Help Configuring Exchange Server 2003 SP 2 for ActiveSync with a Droid X Using Outlook 11
R ActiveSync Not Working with Exchange 2010 Using Outlook 3
K Exchange 2003 SP2 OWA error 500 / unspecified on Frontend, while OMA and ActiveSync is working, even Using Outlook 3
G MS Exchange ActiveSync 2007 Denying Select Devices Exchange Server Administration 2
S exchange 2010 activesync not proxying to 2003. "TiSyncStateLocked_Mbx:" Exchange Server Administration 4
M Exchange 2010 sp1 ActiveSync not working for HTC Desire (Bravo) Anrdoid 2.1 with Telstra firmware (A Exchange Server Administration 39
M SendMail problem with ActiveSync 14.0 (Exchange Server 2010) Exchange Server Administration 3
D ActiveSync Error : 0x85010014 - Exchange 2010, TMG 2010, WM6.5 Exchange Server Administration 7
I outlook 2016 manual exchange config Using Outlook 0
