Outlook Anywhere is not showing freebusy informayion and User not able to open shared calender while
manjurainbow123
Hi all,
One user in our environment is not able to open free busy info and shared calender while on Outlook anywhere
any settings from server side is required or tuning in client side ????
Please expers advice
Manju
L
leo chui
Dear,
You can try to change the registry of outlook.
HKEY_CURRENT_USER\Software\Microsoft\Office\12.0\Outlook\Options\Calendar
Value Type: DWORD
Value Name: UseLegacyFB
Values:0
C outlook 2016 and outlook anywhere Using Outlook 1
B Outlook Anywhere vs Activesync and Enterprise Security Exchange Server Administration 8
R Outlook anywhere Using Outlook 1
M Outlook Anywhere not working for Exchange Server 2007 Using Outlook 7
X Exchange 2007 Outlook Anywhere Clients unable to retrieve GAL Using Outlook 9
J Exchange 2010 + Disable ActiveSync/Outlook Anywhere/POP/IMAP/ By Default Exchange Server Administration 5
S Exchange 2010 outlook 2010 outlook anywhere cached mode Exchange Server Administration 2
S Outlook Anywhere two AD sites recirection or direct connect Exchange Server Administration 1
M SRV records to enable auto discover for Outlook Anywhere Using Outlook 8
D outlook 2010 and outlook anywhere Exchange Server Administration 6
T Re: Outlook Anywhere in Outlook 2010 and Exchange 2007 Using Outlook 3
T Outlook Anywhere in Outlook 2010 and Exchange 2007 Using Outlook 1
J Using roaming profile wiht Outlook Anywhere Using Outlook 3
M Autodiscover not configuring Outlook Anywhere Using Outlook 10
C Outlook Anywhere keeps prompting for credentials Using Outlook 4
A Problem Setting up Outlook Anywhere for Exchange 2010 Exchange Server Administration 17
G Win 7 Outlook 2007 unable to use Outlook anywhere Using Outlook 8
A TMG 2010 - Exchange 2010 - Outlook Anywhere - 503 Service Unavailable Exchange Server Administration 2
C Prevent clients outlook anywhere URL from being changed by autodiscover? Using Outlook 4
D Outlook anywhere SSL trust problem Exchange Server Administration 10
witzker print-list-of-outlook-folders with sort posibility Outlook VBA and Custom Forms 3
witzker Open Contact missing in Outlook 2019 Using Outlook 2
B Outlook 2016 Retail C2R keeps logging since update? Using Outlook 0
M outlook 365 trying to finish my sentences Using Outlook 0
D Outlook Address Book Using Outlook 0
V Outlook 2016 Does Outlook-2016 (64 bit) work with iCloud for Windows ? Using Outlook 4
R Microsoft Outlook 2016 - Gmail not sending, asks for password for SMTP, tried different ports Using Outlook 23
V Outlook 2016 Outlook-2016 and iCloud for Windows - Problems Using Outlook 2
K Imap PC Outlook + Android phone Using Outlook 1
C All Gmails don't show in Outlook 2019 Using Outlook 3
D Outlook 2010 Outlook in Windows 10 keeps asking for user name and password repeatedly Using Outlook 14
