Outlook 2007 Custom Form does not display in 2003
bXdhcmU
I have designed a custom form (based off of default Message form) in Outlook
2007, and published the form to the Personal Forms Library. When i fill out
the form and send to other users using Outlook 2007, and they can see the
form results/contents (in the format I set up in the Read Pane) just fine.
However, anyone using Outlook 2003 does not see the Read Pane form view or
any of it's contents.
Is there a backwards-compatibility issue, or have I missed something?
Sue Mosher
The other users, regardless of version, need to publish the form to their
Personal Forms Library with the same MessageClass that you're using, e.g.
IPM.Note.MyForm. Or, in an Exchange environment, publish it to the
Organizational Forms library. Also make sure the "send form definition with
item" box on the (Properties) tab in the form design is not checked before
publishing. If you're not using Exchange, users may also need to add the
custom fields to their Inbox folder in order for the form to work 100%. That
would be true for both Outlook 2003 SP2 and Outlook 2007.
Sue Mosher
bXdhcmU
Thanks for the quick response.... I was afraid you were going to say that.
I was able to create the same form in Outlook 2003, and send to 2007 users
who could view the form without publishing, but not vice-versa.
Looks like I'll have to go another route.
Thanks again.
> > Sue Mosher
Sue Mosher
FWIW, that doesn't make any sense to me. It should be 2003 SP1 or earlier
that can display a form regardless of whether it's published, not 2007.
Baffling.
Sue Mosher
> Thanks again.
L Outlook 2007 Custom Form and Toolbar Not Working Using Outlook 5
divan Outlook 2007 - Replace email body with custom text Using Outlook 9
Z outlook 2007 - opening a contact from the search results doesn't use the custom form Using Outlook 10
M Workarounds for sharing custom Outlook 2007 forms? Using Outlook 3
D Custom Tool Bar and/or Commands do not remain when re-opening Outlook 2007 Using Outlook 3
D Outlook 2007 Custom Form - Dual Addresses and Mailing Address Using Outlook 6
B Reply to All custom action doesn't work with attachments in Outlook 2007 Using Outlook 1
S How to call a procedure from a custom command bar in Outlook 2007 Outlook VBA and Custom Forms 1
J Making custom Outlook 2007 folders emptiable like "Deleted Items" Outlook VBA and Custom Forms 1
P outlook 2007 - custom buttoms with hyperlinks to oft files Outlook VBA and Custom Forms 1
B Importing Contacts Does Not Use Defined Custom Form in Outlook 2007 Outlook VBA and Custom Forms 1
R Build custom ribbon in Outlook 2007 Outlook VBA and Custom Forms 3
J Extra text on an Outlook 2007 custom form Outlook VBA and Custom Forms 2
K Accessing contact's custom properties in a Outlook 2007 form region Outlook VBA and Custom Forms 1
S Make field searchable in custom form in outlook 2007 Outlook VBA and Custom Forms 1
J Outlook 2007 using custom form created for Outlook 2003 Outlook VBA and Custom Forms 2
