User not shown in Adressbook but is shown in Adressbook using OWA
L
LA1976
I have a new created user that is not shown in the OAB. It is shown in OWA!
I changed his email in the console..
I used this command to see if that would solve the issue (http://support.microsoft.com/kb/936197)
Set-Mailbox <var>user@fabrikam.com</var> -EmailAddressPolicyEnabled:$False -PrimarySmtpAddress <var>ju@domain.com</var> -WindowsEmailAddress <var>ju@domain.com</var>
<var></var>
Output showed that it changed nothing. I recreated the OAB. Downloaded the OAB with full details..
I have expert level logging enabled (Set-EventLogLevel -Identity &ldquo;MSExchangeSA\OAL Generator&rdquo; &ndash;Level Expert)
I can see the user passing in the logs.
I have updated the GAL.. would not know what else to check..
L
LA1976
I had a similar issue but this is now not the case as the user is new
H
HereToHelp
is cache mode enabled in outlook? if yes then try disabling it and downloading OAB again.
MCSE | MCITP - Server 2008 | MCITP - Exchange 2007 | MCTS - Exchange 2010
L
LA1976
That worked. I remember I have read somewhere what is the difference but cannot remember what.. Another thing We want users cached how to make it worked for cached users?
DeaconZ
Yes, in cached mode Outlook can take up to 24 hours to update itself with the latest copy of the GAL. You can download the latest address book from your Send/Receive menu.
Wayne Hetrich MCITP
L
LA1976
I copied the OAB using send receive ... I deleted it first and selected to download full details nothing helped. I manually updated the GAL with update-globaladresslist powershell command ... I think there is more going on. I still have no user in the OAB.
L
LA1976
Don't know what I could have done to speed this up but suddenly it seems to be in the OAB.
D Outlook 2010 Outlook in Windows 10 keeps asking for user name and password repeatedly Using Outlook 14
icacream Enter your user name and password for the following server. Using Outlook 5
R Creating a user defined function Outlook VBA and Custom Forms 3
M How to export Voting Results with user names and their responses Outlook VBA and Custom Forms 13
G <mailto:user@domain.com<mailto:user@domain.com<mailto:user@domain.com>>> Using Outlook 5
F MAPI, User Defined Fields and perspective after 20 years Outlook VBA and Custom Forms 0
A Created a new user account and the local account cannot see email Using Outlook 3
Daniel Schunk User-defined form arrives empty at the recipient Using Outlook 3
C Changed By field not displaying individual user's name in O365 Shared Mailbox Using Outlook 9
M other user's mailbox won't open, forms disappeared Using Outlook 42
R Prompt asking the user to send email to folder as *.msg file Outlook VBA and Custom Forms 1
N Select a folder in a user account Outlook VBA and Custom Forms 2
S Outlook User defined date field (UDF) not syncing Using Outlook 2
M Multiple User Defined Fields that can be added, changed, updated using VBA and user form Outlook VBA and Custom Forms 0
S how to set user properties to a newly created appointment Outlook VBA and Custom Forms 12
S VBA with User Defined fields Outlook VBA and Custom Forms 9
D Unable to Send On Behalf of Another User Exchange Server Administration 0
M Exchange 2013 On premise set MessageRateLimit for User has no effect. Exchange Server Administration 0
A Block user to send emails to specific set of email ids Using Outlook 1
A UID field in iCal files - unique per-event or per-user or both? Using Outlook 2
G how can Apply User-defined Field to all Sub Folder and Other Using Outlook 14
C Custom Application Form send Email to Another User Using Outlook 1
Mark Foley Outlook prompts for IMAP user/PW when domain PW changes Using Outlook 0
M Map Outlook user defined fields onto a Sharepoint list ??? Outlook VBA and Custom Forms 1
L A realtime Outlook user inbox count Using Outlook 5
