Exchange 2010 RPC Over HTTPS, outlook keep trying port 135
N
nick kouk
Hello Exchange Experts.
I have an exchange 2010 server running on win 2008 R2 64 bit and i can access the owa from everywhere intranet and internet
so we have the following names
Internal domain: company.local
Internal exchange name: msrvr.company.local
external exchange domain: mail.company.com
i have no problem to access the owa from everywhere, i just need to install my certificate first because i use my own CA.
I can access the pop3 and imaps with thunderbird for example from everywhere.
now i configure the Outlook Anywhere with NTLM authentication to be able to access exchange through outlook with RPC over HTTPS.
from internal network i can use the exchange option on outlook and works fine.
when i try from internet i can't and getting at the add new e-mail account window when i press check Name button i get
" The connection to microsoft exchange is unavailable. outlook must be online or connect to complete this action"
and when i press ok
a smaller window appears with microsoft exchange title and i press again the check Name button and getting the following
" The name cannot be resolved. the connections to microsoft exchange is unavailable. outlook must be online or connected to complete this action"
if i do a netstat the time i press the check name button i can see that outlook trying to connect to mail.company.com at port 135 and after a while i get the messages.
according to netstat there is no request to 443 port.
any ideas??
thanks in advanced.
E
Ed Crowley [MVP]
You have to configure Outlook to use Outlook Anywhere for it to use port 443. If you have Autodiscover properly configured, Outlook should figure out the settings automatically.Ed Crowley MVP " There are seldom good technological solutions to behavioral problems."
E
Ed Crowley [MVP]
It is my experience that Outlook will always try port 135 to see if you are connected to the internal network. It's a desirable thing, really. You want your laptop users to use TCP internally and Outlook Anywhere (HTTPS) externally, and for Outlook to figure out the appropriate one to use. So the fact that your client is testing port 135 is not an indication that something is wrong. What apparently is wrong is that your Outlook Anywhere isn't configured properly, or Outlook itself isn't configured properly.
You might consider trying the Microsoft Exchange Remote Connectivity Analyzer:
https://testexchangeconnectivity.com
N
nick kouk
Ed i try to test it with https://testexchangeconnectivity.com but i use my own CA as i said before so my CA is untrusted for https://testexchangeconnectivity.com.
any other ideas how to find out what's wrong.
also i don't care if it tries 135 port, my problem is that don't try anything on 443.
i forgot to mention that i have try outlook with /rpcdiag and i can see every time i press the " Check Name" button that try to request the internal FQDN of my exchange server msrvr.company.local
where does it found that domain the outlook??
E
Ed Crowley [MVP]
How do you have RPC-over-HTTPS (Outlook Anywhere) configured?
N
nick kouk
yes, with outlook anywhere and with the mail.company.com domain....
Dave Stork
Which version of Outlook do you use? And which OS?
Do you use Autodiscover and is your certificate trusted by the client computer? Especially Outlook 2010 is picky in that regard.
Have you set the correct common name of the certificate with Set-OutlookProvider? Something like:
Set-OutlookProvider EXPR -CertPrincipalName msstd:mail.company.com
Technical Specialist / Infrastructure Architect @ www.OGD.nl - MCSE 2003 Messaging - MCITP Enterprise Messaging Administrator 2007 & 2010
Brian Day MCITP
Did you using the same FQDN for your internal client access array (MAPI/RPC access) and your external access point (OWA, OLA, EAS, EWS, etc...)? The client access array name should never be resolvable via DNS externally.Microsoft Premier Field Engineer, Exchange
MCSA 2000/2003, CCNA
I Exchange 2010 sp1 Address Book service won't start after static RPC port reconfiguration Exchange Server Administration 2
C Exchange 2010 SP1 "RPC can't be started because of the EMSMDB interface is already registered by Exchange Server Administration 4
K Error Contacting RPC/HTTP Service error in Exchange Server 2010 Using Outlook 8
K Ourlook 2010 RPC via HTTP to Exchange 2003 Using Outlook 3
Z Exchange 2010 SP1 -- DAG Add-DatabaseAvailabilityGroupServer fails (RPC error) Exchange Server Administration 3
Diane Poremsky Organizational Forms Library in Exchange 2010 New Slipstick.com Articles 0
V Recover exchange 2010 edb Exchange Server Administration 2
T Renaming an Resource in Exchange 2010 Exchange Server Administration 1
P Outlook 2010 MS Exchange Calendar to Android- ical or webdav? Using Outlook 1
Fozzie Bear Outlook 2010 or 2013 Dual Configuration Exchange + IMAP Exchange Server Administration 6
H In Exchange 2010, how to block an email containing an attachment that has foreign characters Exchange Server Administration 1
N Outlook 2010 exchange - auto-move emails from @domain Exchange Server Administration 1
V Outlook 2013 cant stay connected to exchange 2010 Exchange Server Administration 5
R Exchange 2013/Outlook 2010 Slow Startups Exchange Server Administration 8
Z Outlook 2010 client to Exchange ,,,,search not working proparly Exchange Server Administration 0
M First post -help with managing two calendars Outlook 2010 /Exchange 2010 Using Outlook 0
T Outlook INBOX emails gone back 2-3 weeks after Exchange Server 2010 Restart Using Outlook 0
C Outlook 2010, two exchange mailboxes configured.Unable to see 2ndrymeeting req Using Outlook 2
C Exchange 2010 / Emails received show with display name and not email address Using Outlook 2
S Unable to send or reeceive email in new Exchange 2010 Exchange Server Administration 0
B Sharing Multiple Outlook 2010 Calendars (Exchange) Exchange Server Administration 4
P can't set IRM configuration in Exchange 2010 Exchange Server Administration 2
B Using hosted exchange to sync outlook 2010 calendars and contacts to BB Z10 Using Outlook 4
S Outlook 2010/Exchange 2010 Multi Mailboxes (Server unavailable) Using Outlook 6
D why do exchange contacts not sync properly from outlook 2011 to outlook 2010 Exchange Server Administration 2
J Exchange 2010 free/busy shows hashmarks in scheduling tab when not organizer Exchange Server Administration 6
C Exchange 2010 - Outlook 2010 - Exchange Server Administration 4
Fozzie Bear Outlook 2010 wont remember Exchange Credentials on log off /shutdown of Win7 Exchange Server Administration 2
T Exchange 2010: 'could not save item' and 'Unknown error' when edit calendars Exchange Server Administration 1
I Shared Contacts in Outlook 2010 and Exchange Server 2010 Using Outlook 4
J OL2003 Public Folder Sync Errors w/ Exchange 2010 Exchange Server Administration 11
B Outlook 2010 won't configure exchange account, 0kb .ost file Exchange Server Administration 5
R Thousand of sync issues on Outlook clients with Exchange 2010 Exchange Server Administration 5
R Create a contacts list on Exchange 2010 Exchange Server Administration 10
T Exchange / Outlook 2010 - How to cancel meetings but retain the calendar entry Using Outlook 4
S Outlook Quick Steps - Exchange 2003 / Exchange 2010 Exchange Server Administration 2
R Sharing Exchange 2010 calendars with people outisde our organization Exchange Server Administration 17
A Exchange 2010 Outlook 2010 and Local Failures sync issue Exchange Server Administration 5
B Exchange 2010 / Outlook 2010 - Group Folder issues Exchange Server Administration 6
U Exchange 2010 & mailbox database Quotas Exchange Server Administration 1
