exchange management consoles has stoped working and yes I have read the above article and tried the troubleshooter and spent days reading and trying d
P
Peter Labelle
I'll tell you what I did to cause the problem. I installed Sharpoint 2007 on my exchange 2010 server and my exchange management consoles has stoped working. I have read and read articles on line. to no availe. below Ill post some meesages. I have spent days pouring through web sites checking variables from paths of the power shell vdir to eviornmental varialbles. I have ran the trouble shooter and even tried everything listed in http://technet.microsoft.com/en-us/library/ff607221(EXCHG.80).aspx.
I am at a loss. What am i missing.
first will be a test app results. the powershell vdir looks ok to me. second ill post the acutaul error.
Welcome to the Exchange Management Troubleshooter!
We recommend that you run the troubleshooter after making changes to
IIS to ensure that connectivity to Exchange Powershell is unaffected.
Checking IIS Service...
Checking the Exchange Install Path variable...
Checking the Powershell Virtual Directory...
Checking the Powershell vdir SSL setting...
Checking the Powershell vdir path setting...
Testing for errors...
VERBOSE: Connecting to Seaway-CHC-Shar.SeawayCHC.local
[seaway-chc-shar.seawaychc.local] Connecting to remote server failed with the following error message : The WinRM client
+ CategoryInfo : OpenError: (System.Manageme....RemoteRunspace:RemoteRunspace) [], PSRemotingTransportExcep
+ FullyQualifiedErrorId : PSSessionOpenFailed
The Exchange Management Troubleshooter successfully completed connecting to:
Failed to connect to any Exchange Server in the current site.
Problem found:
Looking for error...
The Path of the Powershell virtual directory has been modified. The PowerShell virtual directory must point to the
"\Exchange Server\v14\ClientAccess\PowerShell"
directory or you will encounter problems.
After each error is resolved, close this window and re-run the tool to check for additional problems.
[EMTS] C:\Windows\System32\WindowsPowerShell\v1.0>
now the error.
t cannot process the request. The WinRM client tried to use Kerberos authentication mechanism, but the destination comp
uter (Seaway-CHC-Shar.SeawayCHC.local:80) returned an 'access denied' error. Change the configuration to allow Kerberos
authentication mechanism to be used or specify one of the authentication mechanisms supported by the server. To use Ke
rberos, specify the local computer name as the remote destination. Also verify that the client computer and the destina
tion computer are joined to a domain. To use Basic, specify the local computer name as the remote destination, specify
Basic authentication and provide user name and password. Possible authentication mechanisms reported by server: Neg
otiate For more information, see the about_Remote_Troubleshooting Help topic.
eption
D Outlook Add-on for Exchange Spam Management? Exchange Server Administration 2
S Exchange Management Shell closes on command failure Exchange Server Administration 5
G Latest Exchange Rollup - Management Console Error - Exception calling "GetSteppablePipeline" Exchange Server Administration 1
A Exchange 2010 Management Console Initialization failed Exchange Server Administration 2
D Resolving WinRM errors and Exchange 2010 Management tools startup failures Exchange Server Administration 0
H Exchange 2010 cannot open exchange management console Exchange Server Administration 5
M Exchange management console error Exchange Server Administration 4
I Exchange 2010 Management Console "Initialization failed" troubleshooting Exchange Server Administration 16
M Unable able to initialize Exchange management (EMC and EMS don't work) - Access Denied Exchange Server Administration 16
L Exchange Management Console - Initializtion failed on Logon Failure: unknown username or bad passwor Exchange Server Administration 4
I outlook 2016 manual exchange config Using Outlook 0
Fozzie Bear Office 365 Home Premium with Exchange Online email accounts Using Outlook 3
S What is /O=FIRST ORGANIZATION/OU=EXCHANGE ADMINISTRATIVE GROUP(***************)/CN=RECIPIENTS/CN=... Using Outlook 5
Commodore Microsoft Exchange Add-in Using Outlook 2
D Winmail.dat with MS Exchange Personal and Outlook.com Using Outlook.com accounts in Outlook 5
I Outlook 2013 Transition to Exchange - weirdnesses Using Outlook.com accounts in Outlook 4
