Insert clip art, shapes, smart art, chart and screenshot greyed out in OUTLOOK 2010
marknj100
Installed office home and student 2010 then installed outlook 2010. previously the machine had office 2003(including outlook 2003). I uninstalled office 2003, then installed office 2010.
Everything works except all buttons under the insert illustrations area of the ribbon are greyed out with the exception of the " picture" button. This problem only occurs in outlook, the same functions work in all other office programs. New messages are in HTML format and I am putting the cursor in the text area.
I tried:
repairing all office programs uninstalling all office programs and reinstalling creating a new mail profile in outlook running outlook in safe mode.
Cannot fix the problem. I would greatly appreciate any ideas here. machine is anHP Pavilion dv4t-1000 CTO laptop with win vista 32
thanks
marknj100
Thank you for your response. However, I have a second machine (Gateway D4831) with Windows 7-64 that I have installed Office 2010 home and Student and a standalone copy of Outlook 2010 and these features work!
There must be some way to fix on my second machine.
K Outlook insert clip art, no results found...address book contacts only show up Using Outlook 5
witzker Outlook 2010 Insert Date & Time at the button of an OL contactform in red Using Outlook 2
L Automatically Insert Recipient Name from To Field Outlook VBA and Custom Forms 33
Diane Poremsky Create Task or Appointment and Insert Selected Text New Slipstick.com Articles 0
B Insert Hyperlinks for attachments in Userform Outlook VBA and Custom Forms 5
D Outlook task insert Outlook VBA and Custom Forms 3
K Insert screenshots issue Using Outlook 2
makinmyway Recent Files Not Updating when Using Insert Hyperlink in Outlook 2013 Using Outlook 0
L Insert Photo to Contact Using Outlook 23
K OL2010 Button to Insert First Name Outlook VBA and Custom Forms 6
K OL2010 Button to Insert First Name Using Outlook 1
witzker insert Date & Time (HH:mm) no (ss) in userform Using Outlook 6
A insert Date & Time in userform Using Outlook 3
K Macro to insert attachments Using Outlook 1
C Insert a Date Picker for Send Mail Subject Using Outlook 1
C Insert date in Subject through date picker Using Outlook 0
mrje1 Opening a task the Insert Tab Option is not showing up and organizing Tasks Using Outlook 9
H Insert Specific Text before Subject for New mails and reply Using Outlook 3
R insert picture tab grey Using Outlook 1
J Form design - how do I insert an automatic date/time field? Using Outlook 2
M Can I insert pictures from a url address (from web) without downloading ? Using Outlook 1
T My Outlook 2007 - (Public folder-Calendar can't insert to My Favourite)but other calender can insert Using Outlook 1
R Outlook 2003: Insert, Item: Unable to insert an old email into a new email Using Outlook 2
L Outlook 2010 Insert file issue Using Outlook 1
J How do I view the ruler in an Outlook message and/or insert tabs? Using Outlook 7
L Forward Email and Insert Sender's Email address in body Outlook VBA and Custom Forms 3
D Insert Text and Send Outlook VBA and Custom Forms 1
D Re: How do i insert radio buttons in an email Outlook VBA and Custom Forms 1
G How to insert a json array into a calendar events Outlook VBA and Custom Forms 1
K insert text into current position of pointer in mailcompose Outlook VBA and Custom Forms 1
J Insert File Outlook VBA and Custom Forms 2
M Insert a File Outlook VBA and Custom Forms 3
G Task / Insert / Attach Item / Business Contact BCM (Business Contact Manager) 1
M Forward email as insert from button Outlook VBA and Custom Forms 1
B Simple way to insert file text - macro? Outlook VBA and Custom Forms 1
S How to insert a picture programatically Outlook VBA and Custom Forms 12
C insert a picture Outlook VBA and Custom Forms 1
J How do I scan and insert into Outlook 2007? Using Outlook 3
B Insert information to MailItem Outlook VBA and Custom Forms 1
D RE: How do you change the default insert file path in outlook? Using Outlook 11
D Insert Text via Macro in Outlook 2007 Outlook VBA and Custom Forms 2
T Is it possible to INSERT a string into email body via Shortcut. Outlook VBA and Custom Forms 2
J Command Button to insert Email Signature Outlook VBA and Custom Forms 2
