How do rename a recovered folder after repairing using scanpst.exe
Russ Valentine
Renaming a folder would never help. Stating the problem you are having and the steps you've used might permit someone to help. Do you back up your data?Russ Valentine
C How to rename subject line and forward the email Outlook VBA and Custom Forms 2
D Autosave Attachment and Rename Outlook VBA and Custom Forms 1
F Rename Contacts Greyed Out Using Outlook 0
N Rename Subject Line with Email Content Outlook VBA and Custom Forms 3
K IMAP Server Wants to alert you to the following: cannpt rename system folder Using Outlook 1
Diane Poremsky Rename Email Accounts and Data Files in the Folder List New Slipstick.com Articles 0
S VBA code to rename a task (flagged message) Outlook VBA and Custom Forms 1
C Save outlook attachments and rename/append files with identifier from subject line Outlook VBA and Custom Forms 3
D VBA script to auto download attachments and rename file according to subject line Outlook VBA and Custom Forms 23
B Your IMAP server wants to alert you to the following: cannot rename system folders Using Outlook 8
L IMAP server wants to alert you to the following: cannot rename sytem folders Using Outlook 14
T Rename Outlook 2010 .PST Files Using Outlook 14
B IMAP server wants to alert you to the following cannot rename system folders Using Outlook 3
M Outlook Today. How to rename IMAP inbox accounts to something else than inbox? Using Outlook 4
A Rename resource Exchange 2003 Using Outlook 2
O Run Rule to Rename Email and Add to Tasks Using Outlook 4
M Rename CCR 2007 Cluster Exchange Server Administration 1
1 'Sent Items', 'Deleted Items', & 'Junk Items' Folders; Want to Rename Them to Just: 'Sent', 'Deleted Using Outlook 1
R Rename Outlook .pst folders Using Outlook 1
F Rename option greyed out when trying to rename folders under favorite folders Using Outlook 2
T Rename Archive Mailbox Exchange Server Administration 5
S Rename NETBIOS name in windows 2003 AD with Exchange 2003 Exchange Server Administration 6
D How to rename the display name of the primary outlook mailbox in Outlook 2010 / Exchange 2007 Using Outlook 1
T Rename CAS array Exchange Server Administration 4
K Rename Server with Exchange 2010 Exchange Server Administration 2
W Outlook folder rename (right click 'rename' option) issue Using Outlook 9
S Is there a configuration or setting in Outlook (2007 or 2010) that allows users to rename "shared" c Using Outlook 3
O How to rename folder name within favorities under Outlook? Using Outlook 3
M Rename Database BCM (Business Contact Manager) 1
J how do i rename the default fields in MS Business Contact manager BCM (Business Contact Manager) 1
D Command line to Copy or Rename Mail Profile Using Outlook 1
T Retore a recovered PST file Using Outlook 1
A Recovered Folder 8082 Using Outlook 1
G Following a crash - recovered outlook 2007 PST but Contacts shows 1884 but when I try to view these using the 'Business Card' view I 's Using Outlook 3
R Office 2007 Outlook running on Vista, Recovered Folder Using Outlook 1
U Recovered PST file "Cannot move item" error when trying to move e- Using Outlook 6
B Spam folder not showing in Outlook Using Outlook 5
J Moved many emails to Outlook external folder, need to delete on Gmail server Using Outlook 13
B Outlook 2016 Auto-archive creates new folder Using Outlook 4
