VBA Macro for formatting multiple phone numbers in outlook contacts
P
Patrick F
Thanks to Michal Bednarz (http://www.codetwo.com), I was able to format all my contacts phone numbers the way I like. I know, perhaps not groundbreaking, lol, but there were enough people trying to do this in my search for the answer that I thought I'd throw this up to make someone else have it easier. My modifications and additions format phone numbers to: xxx-xxx-xxx, but the code can easily be tweaked to give you what you want.
One note, Outlook likes to auto-format phone numbers but I found several tips pointing to modifying the phone options in control panel - changing the area code to 99999, makes outlook stop putting the brackets around the area codes.
heres the code:
Sub FormatPhoneNumber()
Dim oFolder As MAPIFolder
Set oFolder = Application.ActiveExplorer.CurrentFolder
If Left(UCase(oFolder.DefaultMessageClass), 11) <> " IPM.CONTACT" Then
MsgBox " Select contact folder" , vbExclamation
Dim nCounter As Integer
nCounter = 0
Dim oItem
For Each oItem In oFolder.Items
Dim oContact As ContactItem
Set oContact = oItem
If Not oContact Is Nothing Then
With oContact
.AssistantTelephoneNumber = RemovePrefix(.AssistantTelephoneNumber)
.Business2TelephoneNumber = RemovePrefix(.Business2TelephoneNumber)
.BusinessFaxNumber = RemovePrefix(.BusinessFaxNumber)
.BusinessTelephoneNumber = RemovePrefix(.BusinessTelephoneNumber)
.CallbackTelephoneNumber = RemovePrefix(.CallbackTelephoneNumber)
.CarTelephoneNumber = RemovePrefix(.CarTelephoneNumber)
.CompanyMainTelephoneNumber = RemovePrefix(.CompanyMainTelephoneNumber)
.Home2TelephoneNumber = RemovePrefix(.Home2TelephoneNumber)
.HomeFaxNumber = RemovePrefix(.HomeFaxNumber)
.HomeTelephoneNumber = RemovePrefix(.HomeTelephoneNumber)
.ISDNNumber = RemovePrefix(.ISDNNumber)
.MobileTelephoneNumber = RemovePrefix(.MobileTelephoneNumber)
.OtherFaxNumber = RemovePrefix(.OtherFaxNumber)
.OtherTelephoneNumber = RemovePrefix(.OtherTelephoneNumber)
.PagerNumber = RemovePrefix(.PagerNumber)
.PrimaryTelephoneNumber = RemovePrefix(.PrimaryTelephoneNumber)
.RadioTelephoneNumber = RemovePrefix(.RadioTelephoneNumber)
.TelexNumber = RemovePrefix(.TelexNumber)
.TTYTDDTelephoneNumber = RemovePrefix(.TTYTDDTelephoneNumber)
.AssistantTelephoneNumber = RemoveChars(.AssistantTelephoneNumber)
.Business2TelephoneNumber = RemoveChars(.Business2TelephoneNumber)
.BusinessFaxNumber = RemoveChars(.BusinessFaxNumber)
.BusinessTelephoneNumber = RemoveChars(.BusinessTelephoneNumber)
.CallbackTelephoneNumber = RemoveChars(.CallbackTelephoneNumber)
.CarTelephoneNumber = RemoveChars(.CarTelephoneNumber)
.CompanyMainTelephoneNumber = RemoveChars(.CompanyMainTelephoneNumber)
.Home2TelephoneNumber = RemoveChars(.Home2TelephoneNumber)
.HomeFaxNumber = RemoveChars(.HomeFaxNumber)
.HomeTelephoneNumber = RemoveChars(.HomeTelephoneNumber)
.ISDNNumber = RemoveChars(.ISDNNumber)
.MobileTelephoneNumber = RemoveChars(.MobileTelephoneNumber)
.OtherFaxNumber = RemoveChars(.OtherFaxNumber)
.OtherTelephoneNumber = RemoveChars(.OtherTelephoneNumber)
.PagerNumber = RemoveChars(.PagerNumber)
.PrimaryTelephoneNumber = RemoveChars(.PrimaryTelephoneNumber)
.RadioTelephoneNumber = RemoveChars(.RadioTelephoneNumber)
.TelexNumber = RemoveChars(.TelexNumber)
.TTYTDDTelephoneNumber = RemoveChars(.TTYTDDTelephoneNumber)
.Save
nCounter = nCounter + 1
MsgBox nCounter & " contacts processed." , vbInformation
Private Function RemovePrefix(strPhone As String) As String
strPhone = Trim(strPhone)
RemovePrefix = strPhone
If strPhone = " " Then Exit Function
Dim prefix As String
prefix = Left(strPhone, 1)
Do While (prefix = " +" Or prefix = " 1" )
strPhone = Mid(strPhone, 2)
Loop
End Function
Private Function RemoveChars(strPhone As String) As String
RemoveChars = strPhone
strPhone = Replace(strPhone, " (" , " " )
strPhone = Replace(strPhone, " )" , " " )
strPhone = Replace(strPhone, " ." , " -" )
strPhone = Replace(strPhone, " " , " -" )
End Function
cheers,
Patrick Freeman
> ..will work for cheap to get my foot in the door...
Someone Hire Me!
Sudharsan V
Glad to know that your issue is resolved. Thank you for sharing the resolution in the forum which would help community users facing the same issue.
J Macro only runs within VBA Editor Outlook VBA and Custom Forms 2
D VBA macro printing attachments in shared mailbox Outlook VBA and Custom Forms 1
S Outlook 7 VBA macro for multiple filing Outlook VBA and Custom Forms 1
Philip Rose Recreating a WORD Editing Macro to use in Outlook VBA Outlook VBA and Custom Forms 4
M recover deleted items vba macro Outlook VBA and Custom Forms 2
S VBA Macro to VBScript Outlook VBA and Custom Forms 1
B Outlook vba macro Using Outlook 1
B Auto BCC VBA macro: how to add exceptions? Using Outlook 28
D VBA Macro Works in 2007 but errors in 2010 Using Outlook 2
C Outlook VBA - Create Macro Move Contact field Item to Another Using Outlook 1
N VBA Procedure (or Macro) to Stop Outlook from Closing? Outlook VBA and Custom Forms 2
M Run external program from Outlook VBA macro Outlook VBA and Custom Forms 5
D New Macro / VBA Outlook VBA and Custom Forms 7
J Specify Font Name or Face using VBA Macro in Word Outlook VBA and Custom Forms 2
S Custom VBA forms in Outlook--how to call w/macro? Outlook VBA and Custom Forms 1
S macro ist just worling wenn vba editor is open! Outlook VBA and Custom Forms 1
S Excel VBA and shared calendar issue Outlook VBA and Custom Forms 4
