archiving - not working
famreeks
HI,
I want to archive old mail - stuff longer than 1 year old.
I clicked on file/ archive and placed the date in the 'Archive items older than' box and then clicked OK -
Noting happened.
My in box is still the same .
I also went to Tools/options/ other/ and made necessary changes in the auto archive settings and still nothing?
What am I doing wrong?
Mike
larry
Did you import the mail within the last year? Archive uses the last modified date and importing changes the last modified date to the date of import. Other actions (like flagging) can change the mod date, but importing is the most common cause.
There is an archive utility that uses the received date, but unless you use a lot of folders, you could search for messages received a yr ago and move them yourself.
P Manual Archiving 2016 Using Outlook 7
L Calendar archiving policy Exchange Server Administration 1
R Archiving into 1 archiving folder only Using Outlook 4
CWM030 Archiving ON the imap server Using Outlook 3
GaryW88 2016 Archiving IMAP keeping mail on Gmail Server Using Outlook 1
G Outlook 2016 Archiving Outlook VBA and Custom Forms 1
Diane Poremsky Archiving Tools for Exchange Server New Slipstick.com Articles 4
J Search and In-Place Archiving Using Outlook 0
M Archiving by year Using Outlook 1
Fozzie Bear Wishlist A built in Archiving system that allowed storage of messages on a normal file server Outlook Wishlist 1
J Opening/Archiving/Import/Export PST files Using Outlook 4
T BCM 2010 Archiving Communication History BCM (Business Contact Manager) 2
J Joint mail folders over network and archiving Using Outlook 1
gemini9189 Archiving Emails Into Folders Using Outlook 1
V Archiving Sent Items Using Outlook 1
O Calander archiving problems Using Outlook 4
B Archiving of emails doesn't work anymore Using Outlook 3
Z Outlook and gmail, cloud storage and archiving Using Outlook 2
L Save vs Archiving Using Outlook 0
J archiving deleted e-mails on Microsoft Exchange Exchange Server Administration 7
Fozzie Bear Archiving Emails Using Outlook 2
S Previously flagged messages not archiving Using Outlook 3
V Archiving & IMAP Using Outlook 4
B archiving outlook 2010 Using Outlook 6
H Archiving problem in OL 2003 Using Outlook 5
D Outlook Archiving sent emails which have been moved to inbox folders Using Outlook 1
B Outlook Calendar Archiving Using Outlook 1
N Archiving folders outside of Outlook to reduce PST file size Using Outlook 2
K Archiving function Using Outlook 1
D Archiving in Outlook 2007 - Archiving tab has completely disappeared in File menu. How do I get it back. Using Outlook 2
H Have lost 'buttons/word clicks' for archiving data Using Outlook 1
P Problems archiving emails Using Outlook 3
P Archiving function and menu item disappeared in Outlook 2007 Using Outlook 2
J I don't appear to have archiving in Outlook 2007 Using Outlook 2
D Personal Archiving Based on Mailbox Quota Exchange Server Administration 2
A Archiving with SP1 Exchange Server Administration 1
I Outlook 2010 Archiving Assign Policy Greyed out Using Outlook 1
Z Patch / hotfix enable Outlook 2007 to work with Exchange 2010 Archiving Exchange Server Administration 2
T Archiving. Using Outlook 1
J Easy archiving certain message in online archive? Outlook 2010 and exchange 2010 sp1 Exchange Server Administration 5
C Archiving Outlook - is this necessary? Using Outlook 4
D Archiving in Exchange 2010 SP1 Exchange Server Administration 1
B Exchange / Outlook archiving Using Outlook 6
B No longer Archiving; Getting prompted to locate the Archive.pst each time user logs in Using Outlook 3
S archiving Using Outlook 1
S Exchange 2010 Archiving and Outlook 2007 Exchange Server Administration 12
D Outlook 2003 Archiving Outlook VBA and Custom Forms 2
M Archiving Outlook Wishlist 0
